Question about Dishwashers
How do i remove the decor door from my integrated dishwasher. The instruction manual refers to a small tool that I can't find (we moved into the house with the dishwasher already here) thanks for your help
  • 269 Answers
I do not know the make or model of your Dishwasher but on most makes the screws on the inside edge of door are utilised.Normally the bottom edge and top edge,sometimes you can tell by the type of screw head or rust.Some model may have a small plastic plug in the side edge of door and if removed you will gain access to the screws.
Hope this helps.
Posted on May 29, 2010
    Champion:
  • 246 Answers
I found a great site where they have decorative covers for your appliances without all the hassle of removing any panels. The covers simply fit over the existing. Worth checking out.
www.applianceart.com
Posted on Feb 18, 2011
How can I adjust the weight on the integrated door
there are springs with cables in most dishwashers i never had that problem but i did replace one spring that had broken. making it fall to fast. its no to hard if your handy. most appliance parts stors if there good should be able to help if they can be adjusted
. Contact Us - Kenmore
http://www.kenmore.com/customer-care/nb-100000000410025
not sure why but i can,t see brand of your dishwasher
Mar 08, 2015 | Dishwashers
How to remove door to an integrated dishwasher
Good Morning Friend,
I understand that you want to remove the door to your integrated dishwasher, model# ESL6114. This appears to be a UK Electrolux dishwasher. I suggest contacting the manufacturer directly. They will be able to better assist you in removing your dishwasher door.
-Best Regards-
WP
May 20, 2014 | Electrolux 23 in. ESL6114 Built-in...
Door springs on Fisher & Paykel 920 dishwasher not working at all .How can they be replaced?
Hi - heres the instructions for you - have fun.....
Removal of Cabinet
(Do not use decorative panel to move the machine)
1. Isolate power supply.
2. Remove service and decorative panels (refer Section 6.1).
3. Ease machine forward for all round access. Be careful not to damage floor coverings.
4. Remove two screws from bottom sides of cabinet rear.
5. Remove the top screws on left and right hand sides of the cabinet rear.
6. Remove two screws securing the rear bottom panel.
7. Remove five screws securing the stainless steel frame to cabinet wrapper at front of machine. These are located behind the sound gasket and service panel.
8. Withdraw the cabinet assembly away from the machine.
Refitting: Refit in reverse manner. Fitting the top centre screw in the cabinet wrapper first, makes fitting the cabinet easier.
6.9 Removal of Door Tension Springs
Location: The door tension springs are located either side of the machine and are
fitted to the chassis base and door quadrants by means of the end hooks of
these springs.
After isolating the machine from the power supply:
1. Ease machine forward for all round access.
2. Remove service panel (Refer Section 6.1).
3. Remove two screws in the cabinet wrapper exposed by the Service Panel.
4. Remove the springs from the quadrants and the chassis base using pliers.
6.10 Removal of Hinge Assemblies
(Do not use decorative panel to move machine)
Location: The hinge assemblies are located either side of the door and retained by means of two rivets on each side to the inner door panel.
1. Remove service & decorative panels (refer Section 6.1).
2. Remove outer door panel (refer Section 6.2).
3. Remove cabinet (refer Section 6.7).
4. Remove door tension springs (refer Section 6.8).
5. Remove quadrant grommets.
6. Open door fully and drill out the two rivets from the hinge assembly on inner door panel.
7. Hinge assembly can now be removed from inner door and cabinet.
Note: Hinges should be replaced one at a time. Repeat procedure six and seven for other hinge. Hinge guide quadrants can now be removed by depressing sides and pulling free of slot if need be.
Refitting: Refit in reverse manner using 3/16 monal rivets to secure the hinges to the inner door.
Aug 10, 2011 | Fisher and Paykel 24 in. DS603H SS...
The door of my Miele G646 SCI semi-integrated dishwasher has suddenly become stiff to move up or down. I am guessing there is a problem with the spring? Any suggestions what to try or how to get access?
Most probably the decor door has swollen and catching on adjoining cabinets. removed decor door via two screws down the left and right hand side of door and see if that helps. If springs snaps then the door will drop very quickly and take the skin off you shins
Jan 14, 2011 | Miele 24 in. G646SCi Plus Free-standing...
CDA CW497 Integrated Dishwasher. Please advise how to connect the door as I do not have the installation manual and have changed all my kitchen doors, but now cannot get the door on the dishwasher.
Hi
Thanks for using FixYa. Please click on this link to download the installation instructions for your Dishwasher. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 02, 2010 | Dishwashers
Need to remove decorative door panel
There are two main ways to remove it.
  • There should be screws on metal trim the side and or bottom of the dishwasher door. Take those out and it should come right off.
Or
  • There are screws on the back of the door screwed in to the front of the door. Remove the screws and it should come off.
Now this is say IF it was installed properly and not clued or screwed on by just anyone.
Good luck. I hope this helps.
May 30, 2010 | Bosch SHV68 Built-in Dishwasher
Decor door help for Whirlpool ADG 7560/1 integrated dishwasher
call for service to change the outer panel.it takes about 15min.
Feb 24, 2010 | Whirlpool 24 in. ADG7540 Built-in...
We have a bosch integrated dishwasher with a broken handle. We can't get the cover off to replace it! There are no visible screws on door front and I am unsure about unscrewing the metal panel door in case...
On mine there is a 5mm hole on each side of the metal part of the door, about one third of the way down. Inside is a torx screw. Loosen these off a few turns and you should be able to pull the top of the decor panel towards you, (away from the door, not up). Then lift it up to release it from the lugs at the bottom of the door.
That works for mine - yours may be a different model, but it's likely to use a similar mechanism.
Jan 12, 2010 | Neff 24 in. S5443X2 Built-in Dishwasher
Removing decor door
With the door open all of the way you should see a series or torx 20 (small star shaped round head) screws around the perimeter of the inner stainless steel door panel. The outer door is usually held on by the topmost 2 screws on the outer corners and 1 on either side of the door in the second position up from the bottom of the door. There may also be a catch under the panel which will require the door to be slid upwards a little.
Be careful when the panel releases as there is about 15 to 20 pounds of spring pressure and the door may want to snap shut.
There may also be a small plastic cap on either side of the door panel about 8 inches from the top. Under these caps is a screw which clamps the door panel down. It will have to be loosened or removed if there.
There is no danger in removing all of the torx screws from the inner panel if the door still will not release.
This is for the standard installation but bear in mind that not everyone follows the instructions when installing the panels...
I
Aug 05, 2008 | Bosch 24 in. SHV55M03GB Built-In...
Dishwashers Logo
834 people viewed this question
Top Dishwashers Experts
Owen Barnes
