Question about Rinnai Vent Free Gas Heater/: 6,000 BTU RCE-229A
The economy setting on my 25TR heater does not seem to work. When I set the desired temperature to 19 degrees the heater stays on full evne though the recorded room temperature is 22 degrees. What can I do?
    Novelist:
  • 120 Answers
The sensor for these is inside at the rear near the filter. Choices are really limited to just turn it on and off when you want heat or spend the money on getting it to an agent. If you have never had it serviced I would reccomend getting this done. Maybe whilst it's being cleaned out you can get some adice on got of part replacment. Likely to be either the sensor or the control board itself (ouch on the latter)
Posted on Jul 20, 2010
Bonaire gas ducted heating not reaching set room temperature anymore...
has the system air filters been serviced lately
is the system circulation fab been cleaned to allow full air circulation of the system
call in a technician to check for vermin infestation preventing the system from working properly
Jun 20, 2016 | Heating & Cooling
Why does the unit keep on switching off after running for 2 minutes
Do not know what brand or model your aircon unit is? Sounds as if the temperature you want your unit to run at has already been reached. You need to follow these steps:
- select the temperature you want
- select the icicle icon for cool or thermometer icon for hot.
- select "auto" for your unit to cut in, or to cut off to keep your desired room temp.
For example - hot day 26 degrees and you want the temp in the room to drop to 19 degrees - the unit will shut off once it reaches 19 degrees if it is set to "Auto". Hope this gives you some clues to get it working. Please tick my this helped me box if my tips work. Good luck Gerri.
Nov 27, 2015 | Heating & Cooling
My spa is at 89 and its set for 104 and the pump will not cut on what is the problem
You may be in economy mode. Economy only heats the water during a programmed filter cycle. You want it to be in standard mode which turns on the hot tub once the water is 2 degrees below the desired temperature. There should be a mode or program button on your topside. One some systems you'll have to hit prog/mode button then the temp up button to change the mode. There is also a sleep mode. Never used it not sure what it's for.
Apr 12, 2015 | Dream Maker Spas Dream Maker Ez Spa Hot...
What does economy button mean? When it is not on economy it goes above the desired temperature setting but when it is on economy it never reaches the desired setting. Can you help??? Do others have th
According to the owners manual, the "Economy" mode is designed to reduce the temperature setting by 2 degrees every hour. May not be what you were expecting... On the too hot issue: Check the thermostat setting - it can read either Celsius or Farenheit - Make sure you are setting it to what you think you are... Recommendation: if it is heating higher than set temperature is 1) set the temp lower and see how it does or 2) call a repair man to check and calibrate the thermostat.
Jan 15, 2015 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Why the hot water temperature couldn't reach the set temperature (130 degree) in Amtrol WHS80Z indirect water heater?
I have a couple of thoughts. You may have air in the boiler water circuit at the loop that feeds the tank. You'll have to find the vent in the loop to get it out. Second, the automatic valve that opens for hot water may not be opening fully. Have you felt both the boiler water lines that go in and out of the tank? If the water going in is hot and the line out is very cold you have very little boiler water going through the loop. Make sure the isolation valves on the loop are open. Is your boiler full of water? If the boiler loop lines are hot going in and coming out, the tank is full of rust or debris and no water can get to the fins on the internal tubing to pick up heat. If that's the case there is no repair and its time to get a new tank. Hope this helps good luck.
Nov 04, 2014 | Amtrol WHS-80Z - WHS-80Z 80Gal Hot Wtr...
The heater will not kick on. It's a programable 7 day that reads 69 degrees and if I arrow up to 72 degrees, nothing happens
Change Temperature Setting Until the Next Program Period (Temporary Change)
? Press UP Arrow or DOWN Arrow until the screen shows the desired temperature setting.
NOTE: The temporary temperature setting is displayed for about 3 seconds and then the room temperature is displayed.
Temporary appears in the display. The setting cancels when the next program period starts or when
you press RUN PROGRAM.
Change Temperature Setting Indefinitely (Hold)
? Move the System switch to the desired position (Heat or Cool).
? Press HOLD TEMP then UP Arrow or Down Arrow to change your setting if desired. (The display changes from showing the setpoint
temperature to room temperature after approximately three seconds).
? To cancel Hold press RUN PROGRAM.
The downloadable manuals for this t-stat are here, and the addendum, here. Page 17 and 18 detail thermostat operation I have copied above. It has graphic representations of keys that do not copy over very well, so if you have questions about the steps above, you should view the manual in the links provided above.
I hope this helps! Please take a moment to rate my reply - thanks!
Dec 23, 2010 | Honeywell CT3600 7 Day Electronic...
I have a Rinnai 1004F, no manual. Vent Contol Button is in open position, its winter, should vent be closed at all? Economy button, whats it for?
Not sure about Vent Control however the Economy button is like a night time set back. Over a 2 hour period it will decrease the temperature up to 6 degrees from set point. In morning, just take off economy and unit will come up to temp. Go to www.rinnai.us for on-line manual.
Nov 28, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
My Samsung Refrigerator can not keep the set temperature.
Normally your fridge is set +2 degrees C. with a differential of 3 so when it reaches +5 it should switch back on. if this is not doing this then a new thermostat may be in order.
Apr 16, 2010 | Samsung RB2155 Bottom Freezer Refrigerator
Cannot set heat setting by using "hold" feature
make sure it is not telling you room temp, some of the Honeywells, will display room temp over desired temp. check that, if it wont let you switch temp than buy a new one, if you dont have a heat pump a new cheap stat is around 20.00.
Dec 31, 2008 | Honeywell Programmable Thermostat Heater
1004F Rinnai Gas Heater
I found the manual online... I have the same thing, and had a couple of problems with it. I'll try to paste the link here: http://lib.store.yahoo.net/lib/hectors876/1004om.pdf It's 60 pages, so I wouldn't advise printing it, but save it to your favorites list ;)
~Bethany~
Oct 05, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Open Questions:
See all Rinnai Vent Free Gas Heater/: 6,000 BTU RCE-229A Questions
Heating & Cooling Logo
97 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
