Question about LG KU990 Viewty
My friedge does not get cool - LG KU990 Viewty
LG friedge trips when plugged, how to resolve this?
If the compressor and ventilators ate running you have to charge gas on the unit. Check the accumulator if is not blocked of pure ice.
Dec 01, 2014 | LG LFX25960ST Stainless Steel French Door...
How to fix tripping LG friedge?
You didn't say what is tripping. If it's the circuit breaker could have several causes 1 too small for the unit. 2 It has been used as an on and off switch, this shortens the life of a breaker.3 the breaker is not making good contact in the panel and the terminals are burned.
Dec 01, 2014 | LG Heating & Cooling
I was de-icing my mini friedge freezer box and punctured it. I know you're not supposed to use sharp objects or obviously this will happen. How do i fix it?
sorry to be the bearer of bad news but the way to fix it is throw it out and buy a new one. to repair that coil that was puncutured and recharge the refrigerant would cost more than new one,plus its very likely possible water from the melting frost entered the tubing and has gotten into the compresser totally destroying it as well so add the cost of compresser and coil repair its way more than new one would be
A costly yet valuable lesson to never do that again
Jul 28, 2011 | Refrigerators
My fridge smells bad. We have removed everything and cleaned it out and the smell went away for a a while but it is back. What else can we do to get rid of the smell. It is worse when you open the...
yes u can try new newspaper crumpled up all in the ref. and freezer.. it will absorb the smell. but make sure to wipe it again with clorox or bleach water. also charocal u know bar-b-q char. left inside will absorb a lot of smells. ok try that.
Feb 13, 2011 | Whirlpool 25.2 cu. ft. Side-by-Side...
My GE Friedge is not cooling and making load noise
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 13, 2010 | GE Profile Stainless Bottom-Freezer...
13.7 auto defrost upright freezer, runs all the time.
nop its not normal but it will make no further problums if u turn it Off manually after 6hours running (for 30mins), and if u wanna completely solve that prob contact the warranty provider and change the Thermostate.
but i suggest if the friedge have expire to his warranty, dont take any tension it will work properly through this condition (if u manually OFF and ON it regularly).
take care.
for further assistance....
shafqatullah85@live.com
shafky
Jun 20, 2009 | Frigidaire 13.7 cu. ft. / 388 liter...
Did a cleaning cycle and afterwards turned the unit on, however when the on cycle is depressed the cleaning light comes on and it begins to both make ice and clean. The condencer runs but not enougth water...
manually drop hot water inside the freezer area, the freezer area have a little hole with a pipe laying to the tray down. as for as i concern the drainage pipe is closed due to ice. but if u drop hot water inside the freezer area it will unblock the pipe. and the friedge will work better then before..
good luck
shafky
Jun 19, 2009 | GE Monogram ZDI15C Automatic Icemaker
KIC 223l fridge - what length time reqd to let gas settle?
if it was transported upright you should be able to plug it up right away and allow it to start cooling peyton..
Jan 28, 2009 | Refrigerators
LG KU990 Viewty Logo
15 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
