Question about Kodak EasyShare C653 Digital Camera
My Lens is out and the camera is off and can't switch on what's my problem
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 29, 2010
Autofocus lens frozen
What do you mean with autofocus lens frozen?
What lens do you use, and what are the settings on your camera. Even when you have chosen automatic on the main dail, to the left of the lens is a switch on the camera, that can be set to manual. Even on a lot of AF lenses, are switches that can be set to manual.
In your camera only modern AF lenses with Nikon F connection will work with AF. The older AF lenses (Mechanical focus) need a focus motor in the camera body, only found in the camera's that also have a little LCD screen on top of the camera. (Not in 3x00, or 5x00 models)
But if you are sure this lens worked in your camera before, please check the switches on the camera and on the lens.
Still problems? tell me what lens you are using and how is the switch AF / M on your camera now?
Dec 01, 2013 | Nikon D3100 Digital Camera
How do I switch the lens on my Olympus evolt e500
1. Switch off the camera
2. Prepare the lens you want to put on
3. Remove the rear lens cap by turning it anticlockwise
4. Put the camera in your left hand's palm so you can press the lens release knob wit the finger, and press it down.
5. rotate the lens anticlockwise, and remove it
6. immediately put another lens on the camera. The both red dots, on the camera and the lens must be aligned
7. Rotate the lens clockwise.
8. Put the rear protectiv cap on the lens you just removed.
9. Now yuo can turn the camera on and take the photos.
May 02, 2011 | Olympus EVOLT E-500 Digital Camera
Autofocus is not working
Could you please precise the circumstances?
What lens are you using? Is there a switch (A)uto/(M)anual on the lens?
What are the positions of the switches on the lens and on the camera body(C/S/M)?
My guess either your camera or the lens are switched in the M(manual) mode.
But, sure, it could be also caused by using the old manual lens or camera/lens malfunction.
So please be as precise as you could. And we will find a solution ) Thanks
Mar 21, 2011 | Canon EOS Rebel XSi Digital Camera
My camera says lens error and the lens is not coming out
While your camera is switched on, remove the battery. Wait for at least 30 seconds and reinstall the battery (make sure it´s charged). Switch on the camera. The lens should open and pop out.
Mar 12, 2011 | Canon G12 Digital Camera
Lens error When the camera is switched on the lens does not open out and the lens cover does not open. The camera then displays a "lens error" message and suggests that the camera be restarted ten...
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Aug 09, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Lens error restart camera
open your camera battery lid of bottom and on the lft hand bottom u'll find a switch........pressing and holding that switch try to on the camera......it'll work.......then insert some junk material to hold that switch in that position forever
Jun 20, 2009 | Canon PowerShot SD600 Digital Camera
The lens cannot automatically focus
Hi pablo_cornel, One simple question, is the camera in manual focus mode. On the right of the lens mount, as you look at the camera is a switch that reads AF and M. If that switch is set to M you are in manual focus mode. Also, does the 18-55 mm lens have a manual override switch?
Apr 25, 2009 | Nikon D80 Digital Camera with 18-55mm Lens
Problem at switch on
The problem was caused by fine particles getting trapped between the sections of the lens. I tore off a thin strip of paper and wrapped it around the inner barrel of the lens. By rotating the paper, I dislodged the particles, switched on and the camera functioned normally.
Mar 22, 2009 | Kodak EASYSHARE M1063 Digital Camera
L2 Lens Error
I just gave it a very hard tap against my dinning table and it became alright!
Jul 07, 2008 | Nikon COOLPIX L2 Digital Camera
"00" Apparture
If an aperture of "00" is displayed on the camera's LCD panel, perform the following steps in order. Check after each step to see if the problem remains, and proceed to the next step if it does. (In some cases, you may see "Err 01" displayed on the LCD panel.) 1. Check if the lens is correctly mounted on the camera. If no lens is attached to the camera, "00" will be displayed for the aperture value. 2. Clean the lens contacts. Turn the camera's power switch to OFF, and then detach the lens from the camera to clean the contacts. Use a blower to blow away dust on the lens. Do not touch both the camera's or lens' electrical contacts with your fingers while cleaning the lens. Turn the power switch to ON again and check the aperture value displayed on the LCD panel. Refer to the Instruction Manual provided with your camera for instructions for detaching or mounting the lens. Also, prevent any foreign materials or dust from getting into the camera through the lens mount, and be sure not to damage the contacts. 3. Remove the battery pack. Turn the camera's power switch to OFF and remove the battery pack. Then reinsert the battery pack, and then turn the power switch to ON again.
Aug 29, 2005 | Canon EOS-1D Mark II Digital Camera
Kodak EasyShare C653 Digital Camera Logo
77 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
