Question about Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R, 4.8v 1700mAh NiCd 2-Way Radio
Reset vx 5 - Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R, 4.8v 1700mAh NiCd 2-Way Radio
    Master:
  • 623 Answers
Turn your VX-5 off, then press Band + HM/RV + TX PO and turn on.
Posted on Oct 30, 2013
How to reset vertex 426
Maybe this will help: Vertex standard vx-426 owner manual Download Vertex standard vx-426 owner manual :
https://vwjqovoy.files.wordpress.com/2015/08/vertex-standard-vx-426-owner-manual.pdf
Jan 31, 2017 | Vertex Radio Communications
Does the lg 5200 have a master reset
  1. Press OK key for MENU, Right Navigation key two times, 5 key, 5 key.
  2. Enter 4 digit lock code. The default lock code is the last 4 digits of your phone number.
  3. Press 5 key (Reset Default).
  4. Press OK key, select Revert and then press OK key.
Dec 21, 2012 | LG Verizon Vx5200 Camera Flip CePhone...
I BOUGHT A POCKET PC VX 6700 USED I HAD MY CHANGE OF EQUIPMENT DONE BUT I CAN PROGRAM IT BECAUSE THE PHONE HAS A PERSONAL BLOCK A 4 DIGIT PASSWORD ..HOW CAN I GET AROUND IT BY THE WAY ITS A A VERIZON...
Soft Reset
1. Power off the device.
2. Locate the small reset button on the bottom of the phone.
3. Press and hold "Reset" with your stylus until the device restarts.
4. Release the button once the phone restarts. The Today screen will appear on the display.
Hard Reset
5. Press and hold both soft keys.
6. Press and hold "Reset" with the stylus while still holding both soft keys.
7. Press the "Y" when the prompt appears to initiate the hard reset.
Feb 19, 2011 | Cell Phones
Wat order do my ignition leads go in? i have a holden commodore vx ss. Thanks
firing order is 1-2-7-8-4-5-6-3
and as said above point it to no 1 on cap, in a clockwise direction place the leads 1 2 7 8 4 5 6 3 etc..
1 3 5 7 drivers side, 2 4 6 8 passenger side.
Mar 27, 2010 | Palm Vx Handheld
Reset lamp timer runco vx-5000
There is a service reset "button" located on the input panel on the bottom of the projector. This should be what you are looking for you can also download the manual at this link.
http://www.runco.com/legacy_prods/legacy_manuals/VX-5000ci-DHD_6-07-04_v2.pdf
If you need further assistance please let me know. Also please take a moment to accept and rate my solution accordingly.
Thank you,
Lee
May 07, 2009 | Runco VX-5000ci Multimedia Projector
Hot Synch an existing PalmVx data to a replacement palmVx
HI,
The first thing you want to do is to do a Hard Reset on the used PDA that you bought as a replacement. To do that follow these steps:
1. Hold down the power button and then depress the small hole in the back with the tip of your stylus.
2. Continue to hold them both in until you see the Palm logo.
3. Let go of both of them and then follow the onscreen directions. You will want to answer yes and use the 5 way navigation button on the bottom of your pda and hit up so that is completes the reset. After that you will have to set up your touch screen and go through the tapping the target. After you have gone through all this then do a hotsync2.gif. It should clear up your problem. Best wishes.
Dec 12, 2008 | Palm Vx Handheld
Using the remote control for your projector, turn the unit on, then select 'menu' on the remote. On the menu that pops up in the screen, select 'SERVICE', then 'DISPLAY DEVICE', then 'INSTALLATION'... once you select that, scroll over to the "RESET" under the lamp hours... this should reset it.
Here is a link to the owners manual for your unit.
http://runco.com/legacy_prods/legacy_manuals/VX4000d_5000d_manual-v3-1.pdf
Nov 01, 2008 | Runco VX-5000ci Multimedia Projector
Service menu passcode for runco vx-1000d
I understand you have a VX-1000d.
You only want to reset if the projector doesn't turn on because it is a safety feature so the lamp does not explode. They get really hot and need to be replaced when due. You can buy one from the supplier or online.
There is a reset button on the inside of the
RGB connection bay(look deep) for a reset button, hold it down until the lamp light turns blue.
If flipped over on it's back, you would see it straight down beyond the connectors. Of course this will reset to factory settings.
Do you have the processor?
Normal 0 MicrosoftInternetExplorer4
Aug 21, 2008 | Runco Reflection VX-1c Multimedia...
Will not reset to the easy menu as to change DVD 1 setting
Try putting fresh batteries in the remote and then:
1. Push and hold "Enter"
While
2. Push and hold "1"
Keep them down for about 5 sec.
Your remote is now in mode 1 and will talk to your RDR VX-525.
In the EZ Setup are you can change the unit back to remote command mode 3 if you wish. The remote will stop working again, but you just have to repeat the setps above using button "3" instead of "1".
Aug 17, 2008 | Sony RDR-VX525 DVD Recorder/VCR
Code
PIN CODE RESET - UNPLUG SET FOR 2HOURS, VOL TO MIN. PRESS VOL- ON SET & "7" ON R/C FOR 5 SECS WHEN "PROTECTED"
Jan 05, 2008 | Aiwa VX-T1470 14 in. TV/VCR Combo
Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R, 4.8v 1700mAh NiCd 2-Way Radio Logo
203 people viewed this question
Top Vertex Radio Communications Experts
enb54
Level 1 Expert
Steve
eradiostore
eradiostore
Are you a Vertex Radio Communication Expert? Answer questions, earn points and help others
