Question about RCA P52937 52" Rear Projection Television
RCA R52WH77 convergence missing from menu
Tv just went haywire out of the clear blue. Well I did change my colors from personal to vibrant to adjust the flesh tones in an older movie yesterday. The colors and pic went crazy. I tried auto convergence and the tv turned off and back on. Now there is a bow of colors at the top and bottom. pic still stinks. Most of all the auto convergence option is no longer available on the menu and I did try to reboot the tv twice per the manual. can u please help?
  • ozlover311 Apr 10, 2009
    The convergence went out on our TV and when I went to the remote the convergence is missing. We had this problem once before and were able to fix it and now the same problem happened it the remote doesn't have the convergence listed any more. TV is only 3 years old.
  • Anonymous Apr 23, 2009
    I have the same problem but with P52923 chassis PTK195K2B and the fuse is not located beside the flyback coil on the left board. Problem is - Where is the fuse on the PTK195 chassis ?
    Genius:
  • 1,030 Answers
THis is very common on these sets. there is a special fuse thats cause this.. kinda hard to get rca part number 259213.. .4 amp. the reason this blows is there is bad solder connections on the flyback. so when you replace this fuse you have to resolder these connections. so if you know how to solder and can find this special fuse. it is a fast and easy repair
Posted on Apr 09, 2008
How do you fix the convergence on a big screen television? R52WH77 Picture showing red, blue, and green lines on top of the screen.
Projection TV sets have two very common problems oulined below.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • No Audio/Video - TV Makes Chirping Sound
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc
Dec 24, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hey there recently my screen just went haywire and i am seeing double and the second picture is red in colour,also the bottom of the screen is curved....what causes this and is it worth fixing?
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Aug 23, 2010 | Hitachi 50UX57B 50" Rear Projection...
I have an RCA model #HD61W66 flat screen. This morning when I turned it on it went all 3d like and there was red/green/blue lines at the top of the screen, there was also outlines of the people on the...
  • Screen looks 3D
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Using your original remote go-to the settings menu then goto the convergence section.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 14, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
I have a RCA R56WH78YX53 tv that made a pop or click noise and now the picture is bowed and the colors look like you need 3D glasses. I tried to do a convergence but the tv went blank and now it will not...
  • Screen looks 3D
Feb 27, 2010 | RCA HD52W59 HDTV Projection Television
My tv went multi colored take it as it looks like a 3d television
  • Screen looks 3D
Feb 20, 2010 | RCA HD61W66 61" Projection HDTV
RCA R52WH77 ITC222A chassis convergence problem - FL231 changed!
did you hear an arch before it went if so , one of your crts is arching
and sorry they are not avail anymore
Sep 20, 2009 | RCA Televison & Video
How to adjust the convergence on my RCA R52wh77 tv there is no convergence button on system anywhere. TV is only 2.5 yr old and I really don't want to pay $300 to have them come and adjust tube when I can...
you have to go into the menu,sometimes convergence is listed in the video section.
the chasis number is ITC222.
some had manual convergence then you have to adjust red onto green,blue onto green DO NOT MOVE GREEN
if it has autoconvergence activate it.do not do anything until its done.
Sep 18, 2009 | RCA R52WH73 Projection Television
Tv help!!
ALright. you might have a simple inexpesive problem...MIght... first question If you go into setup menu do you have convergence option.. if you dont this it is a small special fuse that blows because of bad connections... can you solder electronic components. the parts about 5 bucks and takes less than 30 min to replace. Let me know if this is the case.
May 15, 2008 | RCA P52937 52" Rear Projection Television
Blue, green, and red colors all off
I would suggest having a repair person come out to your place to fix this problem. I believe the convergence IC are going or have gone bad. I would estimate a $300 - $400 dollar repair bill.
Sep 22, 2007 | RCA P46921 46" Rear Projection Television
RCA P52937 52" Rear Projection Television Logo
1,145 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
