Question about Wharfedale Diamond 9.4 Main / Stereo Speaker
My child has damaged the cone on the woofers of my Wharfedale Diamond 9.1 speakers. Can I replace these?
    President:
  • 1,851 Answers
Of course you can replace them, if you can find the woofers at your area. Unscrew the 6 screws that are securing the woofer (I suggest to unscrew the top-middle screw at the end of all in order to keep the woofer in it's place). Pull the woofer out and disconnect the 2 wires, paying attention which collor is at which side of the woofer. Replace with the new one. Connect the 2 wires. Screw it up (first of all the top-middle screw) Never tighten to the end each screw, tight one after the other, little by little.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on May 29, 2010
Wharfedale Modus one six - one woofer cone is cracked. It still plays, but needs to be replaced. Where can I buy a replacement, or is it possible to repair the cone?
Yes, you can bring it to electronic repair shop to rewind the coil. or buy it in the electronic shop. if they don't have same brand you can replaced it with other brand same size and same watts of speakers. thanks
Apr 30, 2011 | Wharfedale Modus One-Six Speaker
Hello, I have a woofer from a set of diamond 8.3 Wharfedale speaker. The woofer sounds like the coild is rubbing and emits a scratching sound. Looking for possible repir solution and the model no. for the...
Hello
The voice coil of your speaker is scratching with its magenet body inside. It can't be repaired. Whatever we do will go in vein. there is no possibility other than replacing this speaker. Some people will recone it, but qulaity cannot be assured. it will sound; but with respect to the other speaker, it won't match. Coil position, resistance, number of turns per unit length ete are determining the magnetic strenth of the coil, and therby sound. Wharfedale eill have its secret, and they wont give it out, as they have gained it with tremndous reserch.
So in my opinion, it will be best for you to replace the damaged speaker with and other one of same type and number. All details will be printed on its body. Buy the original one. Do not compromise. Woofers are the heart of any sound system. Keep this in mind. OK.
Mar 31, 2011 | Wharfedale Diamond 8 Cinema System
Diamond 8.4 serie are there 2 way or 3 way
These speakers are 3-way there are 2 woofers and 1 tweeter per speaker. Here are the technical specifications of each speaker:
Two 6.5-inch Kevlar woofers and 1-inch silk-dome tweeter per speaker
86 dB sensitivity
20 to 150 watts recommended power (per channel)
6 ohms impedance
30 to 20,000 Hz frequency response
Please rate my answer if this helps.
Many thanks,
Chris
Mar 02, 2011 | Wharfedale Diamond 8.4 Main / Stereo...
Speaker cone separation
Boston Acoustics have long been known for having this problem. For about $25 you can purchase new foam surrounds form several places online. I personally purchased mine from simplyspeakers.com or you could spend about $70 and have them refoamed professionally.
Feb 28, 2010 | Boston Acoustics MediaTheater Speaker
Sub-woofer driver rattle/buzz.
Bad news! It sounds like the coil is rubbing inside the magnet of the speaker! There's no cure, when the cone is warped it it knackers it up. Had the same problem some years ago with a Wharfedale speaker. Someone told me you can hit it on the part where the cone joins the magnet -with a hammer!
Anyway it didn't make a bit of difference! And the speaker was chucked.
Feb 09, 2010 | Polk Audio PSW150 Speaker
Pioneer 4 way ts a6970 what are their wattage
  • 330W MAX.
  • 6" x 9" (16 x 24cm) woofer / 66mm cone midrange / 18mm dome tweeter
  • IMPP composite cone woofer
  • Butyl rubber sound for smoother response
  • Glass-imide voice coil bobbin for higher power handling capabilities
Oct 06, 2009 | Pioneer TS-A6970E Car Speaker
Speaker connection from Denon AVR 2105 to Wharfedale suround
The spkrs sound like they are bi-amp spkrs, meaning you have multiple terminals on the backs of each spkr, the jumpers on the spkrs should be connected as such. Now you just connect the spkrs according to the Denon spkr conection diagram. Do not use the surround back unless you have 6 or 7 pair of spkrs
Jan 27, 2009 | Denon AVR-2105 Receiver
I have a pair of Wharfedale Diamond 7.2 Anniversary speakers and one of them has a blown woofer - how do I get into the speaker - there are no apparent screws to access into the cabinet? Help Also,...
On the back of the speaker are six deep holes that screws the back panel to front baffle.There are six sponge plugs normally.You have to dig these out with
a long standard screwdriver or however you can get them out to expose the 6 Phillips head screws below them.Remove the 6 Phillips head screws and the whole speaker comes apart,leaving just the box.Good luck.
Jan 27, 2009 | Wharfedale Diamond Anniversary Main /...
Wharfedale 8.3
Is it old ? Is it making a rattling noise inside ? Completely lost its sound as in completely stopped sounding like a woofer and has higher frequencys coming out of it or as in no sound at all coming out of it ? I would say it's probably the crossover, perhaps a burnt resistor.
Aug 05, 2008 | Wharfedale Diamond 8.3 Main / Stereo...
Wharfedale Diamond 9.4 Main / Stereo Speaker Logo
278 people viewed this question
Top Wharfedale Audio Players & Recorders Experts
jason
Are you a Wharfedale Audio Player and Recorder Expert? Answer questions, earn points and help others
