Question about Thomas and Friends Wooden Big Rig Trucks Melissa and Doug Train Cars
302 Ford engine purchased used-fires up ok, idles like it has cam, runs/drives normal, but when shifted from park or neutral to drive or reverse it stalls. All vacumn systems have checked out ok, Timing, distributor ok. Must bump idle up past normal to keep idling and to go into gear. Is carburator faulty in idle circuit?
  • Brandon Bruce
    Brandon Bruce Jun 06, 2010
    Is this fuel injected or carburated?
  • 30 Answers
My '79 F150 had a 302 cammed to .498. I had to jack the idle up to keep it running, idled to high is chirped tires going into gear
Gotta love a C6
Posted on Oct 08, 2011
    Genius:
  • 1,970 Answers
Mcdevito75 here, If you do have a cam in the engine idle will have to be higher than factory specs. anyway. Double check for vacumn leaks at the intake manifold, check the EGR valve and the portsit recieves vacumn from, if the EGR valve is operateing after the car is warmed up it can cause stalling at idle, at a stop the car will be staedy, then progessive shake and stall, if so suspect EGR vave and unit it recieves vacumn from. Also check any solinoids, dashpots on the carburetor linkage to aid in idleinmg such as when the A/C is on for proper adjustment.
Posted on Jul 13, 2010
85 ford f150 302 v8 2val carb stall when put in gear
How long since a tune-up? Have you checked the timing? How many miles on engine? How is your cylinder compression?
There isn't much load on engine in park or neutral. When you put it in gear, there is a load on the engine. With carbed engine 6--8 psi fuel pressure. Crub idle in drive, 575 rpms. With a high mileage engine, that idle speed may not work. Is there an idle screw on the carb, where you can up the idle to keep it from stalling, in gear? Of course if you do that, when you put it in park or neutral the idle is going to go high, I know it's a pain. If your engine is in poor shape, your probably going to have a tough time, getting it to run correctly. Just my opinion.
May 17, 2018 | Ford Cars & Trucks
After ideling a while i try to shift into reverse or to drive and it always dies .......any tips or ideas?
engine dies when shifting into reverse or drive - Third Generation ...
www.thirdgen.org/forums/tbi/346079-engine-dies-when-shifting.html
Feb 11, 2006 - engine dies when shifting into reverse or drive ... After it dies it starts right up and idles fine in park or neutral. ... these ignition items because you weretrying to cure the stalling, or, did the stalling occur after you replaced these items? ...The only thing that kept the car running was adjusting the Idle screw up.
Engine Dies When Placed In Gear***Split from Spittybug...EFI ...
dmctalk.org > ... > MAIN FORUMS > Custom DeLoreans/Mods > EFI
Jul 5, 2012 - 18 posts - ‎4 authors
Just to give an update on my car - I've been having an issue with the car stalling when moving from Park into Reverse or Drive (I have automatic). ... I have been playing with the idle advance trying to get more ... I put in the remainder of the AT fluid I had on hand and the car never died on shifting after that.
starts but dies when shifted into drive or reverse - Suzuki Forum
Jan 26, 2016 | Cars & Trucks
1991 camry v6 - auto tranny shifts hard going into reverse and drive but otherwise shifting normal through the gears while driving.
Make sure your transmission fluid is fully topped up. If the transmission has to speed to build up fluid pressure there will be jolt as the drive is engaged from neutral. Make sure you fill up with the right fluid (use the transmission dip stick tube as the fill point). Also when measuring transmission fluid level have the engine running in 'park'.
Jun 15, 2011 | 1991 Toyota Camry
2005 Ford Freestar. Started car, pulled out backwards turning 90 degrees for about 30 feet at end of driveway, shifted into drive, drove 100 feet to the street end of driveway, stopped, looked both ways,...
These are common for stripping the splines in the torque converter for the pump shaft. If it did this when you check the fluid with the engine running it will read overfull. To fix it you would have to remove the transmission and replace the torque converter.
Feb 09, 2011 | Ford Freestar Cars & Trucks
What is the spark plug firing order for a 1989 Ford Bronco with a 302 Cu. In. V8 engine?
There are three kinds of 302s made from 1982-2001. 5.0L HO This engine was used in 1983-1995 Mustangs, Mark VII Lincolns, and some T-birds and Cougars. All Explorer 5.0L engines are 5.0L HO engines as well. They use the 351W firing order, 1-3-7-2-6-5-4-8. Except for the 1983-84 Mustangs, all of these engines are roller cam equipped. They use a reverse rotation water pump and front cover. The 1994-5 Mustang and all Explorers use a unique front cover and water pump. 5.0L Full Size Car This engine was used in 1982-1990 Crown Victoria and Grand Marquis. They use the 289-302 firing order, 1-5-4-2-6-3-7-8. Most of these cars are not roller cam equipped, however sometime in the early 1990s they started using roller cams but retained the 302 firing order. They use a standard (clockwise) rotation water pump and front cover. 5.0L Truck (except Explorer) These engines are similar to the Full Size Car engines, except they use different intake manifolds and camshaft profiles. They also use the 289-302 firing order, 1-5-4-2-6-3-7-8. They also began using roller cams sometime in the early 1990s. They use a reverse rotation water pump and front cover.
Good Luck
Nov 12, 2010 | 1989 Ford Bronco
1988 Ford Bronco Transmission Issues
is the idle speed correct? do you shift into second before trying to engage reverse?, is the clutch ok, this is most likely not the trans at all but one of the above issues, the clutch is my guess.
Sep 14, 2009 | 1988 Ford Bronco
1991 Caprice No reverse. Moves in neutral. All forward gears OK.
shift linkage needs adjusting,,could be bent, easy fix, located along firewall to fram beneath the column, ask your son wut he ran over and didnt tell u about... hope i could help...:)
Mar 22, 2009 | 1991 Chevrolet Caprice
What engine? Rear wheel drive ?Sounds like shift linkage or cable out of adjustment slightly. Have a look at where cable or rod attaches to transmission for adjustment. If not sure of what your looking for get back to me with info.
Mar 21, 2009 | 1993 Nissan Maxima
1990 Ford Probe 2.2 automatic stalls in forward, reverse OK
Sounds like a bad IAC (idle air control valve/sensor) that controls your idle when going from throttle to idle. If bad your idle will act crazy and can cause stalls easily. Pretty sure that's it.
Dec 20, 2008 | 1993 Ford Probe
Thomas and Friends Wooden Big Rig Trucks Melissa and Doug Train Cars Logo
112 people viewed this question
Top Thomas and Friends Toys Experts
Tom Chichester
Bill Boyd
Are you a Thomas and Friends Toy Expert? Answer questions, earn points and help others
