Question about Boating
Fitted new bearings with a crank slightly scratched,will it last?
    Top Expert:
  • 44,451 Answers
Not very long .
Posted on May 30, 2010
Kzte 3.0 turbo charged engine damaged, new rings and bearings fitted.Engine stiff and cranks slowly. engine fitted, the cranking is very slow. please advise me, what is the problem, timing or what?
If battery is in tip top condition the problem is friction. Something in the repairs is too tight and causing the hassle. Definitely not bad timing - that just causes motor to run for s--- and has no effect on cranking speed.
If car runs over time the excessive tolerances will wear. But because things are tight always make sure you have a strong battery and starter.
Jul 31, 2015 | Cars & Trucks
Fit new main bearings with out removing motor
Not easy to get away with the crank get hot and most of the time
get marked or hot spots replacing bearing maybe a short time fix
ive done it .take emery. Cloth and shine the crank up as much as you can .if bearing spun forget it replace crank .good luck
Feb 14, 2015 | Cars & Trucks
Fit replacement bushes to rear hub on CB200
Bushings on the rear hub of a CB200 motorcycle? If so you will most likely need to place motorcycle on centerstand and remove the rear axle and brake connecting assemblies. I don't recall them having bushings, but rather bearings (inside hub) and wheel spacers on outside of hub on one side and outside brake assembly on opposite side. If the bearings are worn out, retrieve replacements and also a blind bearing puller set to remove the bearings. Before removal of the old bearings, toss the new ones in the freezer as this will cause the metal to shrink (although slight) this will make installations of new ones easier. A shop press can be a handy tool for inserting new ones, but can also be done in a vice after carefully starting them with a rubber mallet. Careful not to damage the seals as these are fragile and new bearings won't last long if these get damaged. If it is the spacers, best best is to replace them with original replacements from the manufacturer.
Jun 23, 2014 | Cars & Trucks
Burning much gas
crank savers or speedie sleeve is available from most bearing retail shops ( cbc, etc)
you will need a crank shaft diameter to get one
Apr 09, 2017 | Lexus LS 400 Cars & Trucks
How to take of lefthand bearing and replace bearing to econovan 1999 ford
I take it that the van is a rear wheel drive. So remove the wheel. Remove the brake caliper and lift off the disc. Undo the axle nut and remove hub from axle. Knock out both the bearing cups and clean hub center. Fit new cups into the hub ensuring they are tight against the seat. Thaking a small amount of grease in the palm of you hand take the cone and with the most open area tend to scrape the grease from you palm so that the grease is forced between the rollers until it come out the smallest end.This grease is all thaty you will need for a properly lubricated bearing. Spread grease evenly around the outside of the rollers. Fit inner cone into hub and tap in new grease seal (lip facing bearing) Having repeated lubricating process on outer cone fit hub back on axle and fit outer cone. Fitflat washer and nut . Do nut up while turning hub so as to seat bearings. Tighten nut until a slight drag is felt when turning the hub. Now comes the difficult part. Without touching the hub undo the nut until it is slightly loose then do it back up until it just touches the bearing. THis is a no preload -no freeplay position for the bearing. Having achieved this, pin the nut . IF it is necessary to turn the nut to allow this to happen tighten the nut slightly. Refit dust cap ,calpier, wheel etc REmember to replace both bearings cups and cones and use high temp grease Safety first --place the vehiocle in stands--- not bricks
Mar 07, 2013 | Cars & Trucks
Need to know how to straighten slightly bent valves 1999 rodeo
You will be sorry to hear that there is no way to straighten bent valves. They need to be replaced with new ones, and refit to the head. This situation makes me worry about the crank bearing process: was the CAUSE of the bearing failure resolved? Was the crank repaired and turned? Was the block measured and issues resolved? and Finally was the bearing clearance measured with plasti-gauge?
Aug 09, 2012 | 1998 Isuzu Rodeo
Crank Bearings
Call Accel Fitness of North America they the distributors of Tunturi Fitness. call them @ 1-888-388-6887
Mar 13, 2010 | Tunturi T30 Programmable Treadmill
Re-grinded crank fitted and developed initial problem
While tough to say from this vantage point it would appear the wrong size bearings may have been used. Did your mechanic use plasti-gae to confirm what size bearing were needed? A newly reground crank with proper bearings and lube should be able to have been rotated.
Good luck and I hope this may have assisted,
Tom
Jan 11, 2010 | 1990 Mitsubishi Montero
I HAVE A MK2 MR2 WITH A BIG END BEARING NOISE,I HAVE BEEN TOLD ITS A SIMPLE REPAIR, AND CAN BE DONE WITHOUT INVOLVING ENGINE REMOVAL, CAN ANYONE CONFIRM?
Yes and no... The most common problem in the bottom end is with cylinder number 1. It gets oil starved. This is in the 3sgte. Not sure what motor you have. You can change the bearing without taking out the engine....But you will have to drop the sub frame and oil pan. Problem is, is that you dont know if the crank needs reground and or resized. Or if the rod is bad and ovaled. The bearings wont fit.... you can replace the bad bearings.YES! But how long will it last since it wasnt done correctly? Best case. If there is no damage to the crank and rod? Sure it can last a long time with the rite size bearings. But chances are the rod is bad, the crank needs reground/ or its bent it will need machined. good luck
Dec 27, 2009 | 1991 Toyota MR2
Boating Logo
16 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
