Question about Canon imagePROGRAF W6200 InkJet Printer
Printhead error - Canon imagePROGRAF W6200 InkJet Printer
    Scholar:
  • 94 Answers
Just check your printedhead that could be not inserted properly of just clean the printerhead with a piece of cotton with alcohol then insert it back to the printer after you clean it. Then try to print if the problem are not solve just replace the printerhead.
Posted on May 29, 2010
Why will my printer not print. shows error 3802. just prints blank page. do have ink.
Error: "Printhead Failure" (105-3802) - Kodak
support.en.kodak.com/.../error%3A-printhead-failure-(105-3802)
KodakAug 25, 2010 - How do I resolve the error message "Printhead Failure" (error code ...If you are not prompted to calibrate the printhead, turn off the printer, wait ...
Error: "Printhead is missing, not installed correctly, or has ...
support.en.kodak.com/.../error%3A-printhead-is-missing,-not-inst...
KodakAug 25, 2010 - How do I resolve the error message "Printhead is missing, not installed correctly, or has come loose" (error code 105-3513) on my ESP or HERO All-in-OnePrinter? ... If the printhead and ink cartridges are not installed in the printer, install them: ... If the error continues, restart the printer and try to print.
Jan 18, 2016 | Kodak ESP5 AllInOne InkJet Printer
There's a problem with the printhead
Try this approach to fix the printhead problem:1. Open the printer cover > remove the ink tanks > open the printhead latch > remove the printhead > close the printhead latch.2. Visit the Lexmark website to download and install the Lexmark Pro700 Series Firmware Update.3. After the update is successful, open the printer cover > open the printhead latch > re-install the printhead > close the printer cover > if no error appears, continue with normal installation steps for cartridges. If error still appears, try to remove and re-insert the printhead firmly.
4. Try to print again to verify that the problem is fixed.
Should the error persist, it could be that the printhead itself is faulty. If that's the case, please contact Lexmark Technical Support for further assistance.
Feb 08, 2012 | Lexmark Prevail Pro705 Wireless All-In-One...
Lexmark c782 ps printer has printerhead error..108.10
hi
If this is the firsttime the error has occurred, try turning the printer off. Let it sit turned off for atleast 20 seconds before powering it back on. If powering the printer offand back on clears the error, continue using the printer but watchit to see if any printhead errors return. If your printer continues todisplay a Printhead Error message, make sure it is plugged straight tothe wall and not through a surge device or power strip. Power strips anduninterrupted power supplies can cause a low amperage problem in your printer.This can trigger a printhead error even if the printer has worked on this surgedevice for months.
If theprinter continues to post a 930 Printhead Error, it thinks thewrong printhead unit is installed. If the printer was recentlyserviced, make sure the correct parts were used. This is especially true if theparts replaced were either the printhead unit or the printer's engine/systemboard. It is in one of these two parts that the printer is detecting theproblem. Note: If you are the personrepairing such a printer, please be aware that parts from different,though similar, printer models may not be compatible with this printer.Also make sure to check the laser cable going from the printer's engine boardto the printhead unit, as it reads that signal. If the printer was notrecently serviced before this error occurred and powering the printer off andon does not help, the printhead unit and possibly the laser cable or theengine/system board to this printer may need to be replaced.
If the printer continues topost a 931 Printhead Error, it thinks there is an error in the signalgoing to the laser or the Hsync part of the printhead assembly. If the printer continues topost a 932 Printhead Error, it thinks there is an Hsync error occurringin the printhead assembly. If the printer continues topost a 933 Printhead Error, it thinks there is a failure in either theHsync signal or with the mirror motor unit of the printhead. If the printer continues topost a 934 Printhead Error, it thinks there is a "lock"failure with the mirror motor assembly within the printhead assembly. If the printer continues topost a 935 Printhead Error, it thinks the mirror motor unit within theprinthead unit cannot reach its operating speed.
If powering the printer offand on does not clear any of these errors and it is alreadyconnected directly to the wall, your printer may require service. Itcould have a defective printhead unit or there might be a problem with theengine board or one of the printhead cables. Note:If you are the person repairing such a printer, check all of the cablesgoing from the printer's engine board to the printhead unit for any damage.Also check the continuity across these cables.
May 31, 2011 | Lexmark Office Equipment & Supplies
What is 931 service error
Hello my friend,this is printhead error,check connections at both ends of cable for corosion or oxidation,reconnect them.Also can be system board error.You can check the operation of
the printhead shutter and clean the printhead window with a lint-freecloth folded over a cotton swab; do not use a bare swab and do not use any cleaning fluids or water on the printhead window if you see the defect on the photo conductor.Good luck:)
Feb 03, 2010 | Lexmark T642 Laser Printer
Replaced HP 88 Printheads, still receive same
You either got a defective printhead or you are using generic inks, HP got real smart and added chemicals to their ink, if the printer doesn't see the right chemical makeup it will give that error and you need to flush the printhead and the pump and hoses with HP ink or the error will stay.
Jan 13, 2010 | HP Officejet Pro K550dtn InkJet Printer
Error message u052
That is a printhead error, sounds like you will need that new printhead.
Aug 12, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Error message re printhead.
To resolve the error condition:
  1. Open the printer access door.
  2. Remove the color and black ink cartridges.
  3. Remove, then reinstall the printhead
To reinstall printhead follow the link.
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/AiOPrinters/printhead/AUR1780-9_UE_RevC.pdf
Nov 15, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Lexmark C510 - 930 Printhead Error
93x Printhead Error
Each printhead error has its own error code number. The error codes and their respective meanings are listed below, together with some actions you can take to resolve the problem.
ALL printhead errors:
If this is the first time the error has occurred, try turning the printer off and on.
Let it sit turned off for at least 20 seconds before powering it back on.
If powering off and on the printer clears the error, please continue using the printer but watch it to see if any printhead errors return.
If your printer continues to display a Printhead Error message, make sure it is plugged straight to the wall and not through a surge device or power strip. Power strips and uninterrupted power supplies can cause a low amperage problem in your printer. This can trigger a printhead error even if the printer has worked on this surge device for months.
If the printer continues to post a 930 Printhead Error, it thinks the wrong printhead unit is installed.
If the printer was recently serviced, make sure the correct parts were used. This is especially true if the parts replaced were either the printhead unit or the printer's engine/system board. It is in one of these two parts that the printer is detecting the problem. Note: If you are the person repairing such a printer, please be aware that parts from different, though similar, printer models may not be compatible with this printer. Also make sure to check the laser cable going from the printer's engine board to the printhead unit, as it reads that signal.
If the printer was not recently serviced before this error occurred and powering the printer off and on does not help, the printhead unit and possibly the laser cable or the engine/system board to this printer may need to be replaced.
If the printer continues to post a 931 Printhead Error, it thinks there is an error in the signal going to the laser or the Hsync part of the printhead assembly.
If the printer continues to post a 932 Printhead Error, it thinks there is an Hsync error occurring in the printhead assembly.
If the printer continues to post a 933 Printhead Error, it thinks there is a failure in either the Hsync signal or with the mirror motor unit of the printhead.
If the printer continues to post a 934 Printhead Error, it thinks there is a "lock" failure with the mirror motor assembly within the printhead assembly.
If the printer continues to post a 935 Printhead Error, it thinks the mirror motor unit within the printhead unit cannot reach its operating speed.
If powering the printer off and on does not clear any of these errors and it is already connected directly to the wall, your printer may require service. It could have a defective printhead unit or there might be a problem with the engine board or one of the printhead cables. Note: If you are the person repairing such a printer, check all of the cables going from the printer's engine board to the printhead unit for any damage. Also check the continuity across these cables.
Source: Lexmark KnowledgeBase
Jul 28, 2008 | Lexmark C510 Laser Printer
Infronprint 1352 93x Printhead error
Basically this is a Lexmark printer.
Try these if no result replace printhead ( can be expensive will try to find the comparable to the lexmark.
93x Printhead Error
  1. If this is the first time the error has occurred, try turning the printer off and on.
  2. Let it sit turned off for at least 20 seconds before powering it back on.
  3. If powering off and on the printer clears the error, please continue using the printer but watch it to see if any printhead errors return.
  4. If your printer continues to display a Printhead Error message, make sure it is plugged straight to the wall and not through a surge device or power strip. Power strips and uninterrupted power supplies can cause a low amperage problem in your printer. This can trigger a printhead error even if the printer has worked on this surge device for months.
    • If the printer continues to post a 930 Printhead Error, it thinks the wrong printhead unit is installed.
      • If the printer was recently serviced, make sure the correct parts were used. This is especially true if the parts replaced were either the printhead unit or the printer's engine/system board. It is in one of these two parts that the printer is detecting the problem. Note: If you are the person repairing such a printer, please be aware that parts from different, though similar, printer models may not be compatible with this printer. Also make sure to check the laser cable going from the printer's engine board to the printhead unit, as it reads that signal.
      • If the printer was not recently serviced before this error occurred and powering the printer off and on does not help, the printhead unit and possibly the laser cable or the engine/system board to this printer may need to be replaced.
    • If the printer continues to post a 931 Printhead Error, it thinks there is an error in the signal going to the laser or the Hsync part of the printhead assembly.
    • If the printer continues to post a 932 Printhead Error, it thinks there is an Hsync error occurring in the printhead assembly.
    • If the printer continues to post a 933 Printhead Error, it thinks there is a failure in either the Hsync signal or with the mirror motor unit of the printhead.
    • If the printer continues to post a 934 Printhead Error, it thinks there is a "lock" failure with the mirror motor assembly within the printhead assembly.
    • If the printer continues to post a 935 Printhead Error, it thinks the mirror motor unit within the printhead unit cannot reach its operating speed.
  5. If powering the printer off and on does not clear any of these errors and it is already connected directly to the wall, your printer may require service. It could have a defective printhead unit or there might be a problem with the engine board or one of the printhead cables. Note: If you are the person repairing such a printer, check all of the cables going from the printer's engine board to the printhead unit for any damage. Also check the continuity across these cables.
Jul 02, 2008 | IBM Infoprint 1352 Laser Printer
Error 41 shows
Error 41 is a printhead failure. The only way to fix it to replace the printhead there unfortunately is no way to recover the printhead. If you decide to replace the printhead please do not leave the machine of for extended periods of time (causes the printhead to dry out as it can not do its cleaning cycles), use only genuine ink (I see a lot with this failure with non-genuine inks or refills) and do not cheat the ink system by running empty inks (Dries out the printhead). Just a few tips to extend the life of your printhead.
Mar 06, 2008 | Brother IntelliFAX 1820C Plain Paper...
Canon imagePROGRAF W6200 InkJet Printer Logo
246 people viewed this question
old marine
old marine
