Question about NEC AccuSync LCD223WXM Monitor
Monitor won't turn on after moving it to another computer.
After moving the lcd223 wxm from a computer which was connected via dvr lead, I plugged it in to my other computer and it won't even power up. i plug it into the power and the stand by light does not come on. Is there anyway of resetting or starting it? It was a little dusty where it was before. any help would be much appreciated.
    President:
  • 1,851 Answers
Try a different power cord.
You can check the internal fuse too. Most repair shops will pull it apart and look for the fuse. If the power cord is bad you should see that it doesn't power up at all. Try powering it up un attached - just plug it in and look for some light - if no - replace or try to swap cables with the pc power cable as they are the same thing on the ends.
Best of it
Posted on May 29, 2010
Zosi 500 gb harddrive connected via ethernet displayed on HDTV via HDMI. the dvr has an app that you can check your DVR via moblie monitoring. for three weeks it worked fine but now i cannot view the
Sounds like maybe your IP address changed from what it was for the first three weeks. Unless you pay your ISP extra for a static IP address, they are subject to periodic changes. I don't know how your mobile monitoring app finds your IP address but you should investigate what your IP address is currently and whether this needs to be updated somewhere.
Nov 14, 2014 | Computers & Internet
Hooking dvr up to tv with a 15pin svga tv says change source resolution?
I have several DVRs, and have had similiar problems. I would first plug the DVR into a monitor and make sure it works. If so, then while you can see the menu, change the resolution.
Oct 27, 2017 | Philips Lm181e06 Lcd Panel Grade A Lg Dell...
How to upload videos on my computer using a Vivitar DVR 880HD
The best way to download videos from your camcorder to your computer involves removing the memory card from the camcorder and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camcorder to the computer, and won't run down your camcorder's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy videos from the card to the computer's hard drive, the same way you copy any other files. Or you can use any video cataloging program, such as iMovie and Windows Movie Maker.
Feb 07, 2012 | Video Cameras
I just moved my Acer 19" monitor and everything went off. I checked all the connections but it is not turning on. any suggestions?
Check the VGA lead, it is possible that when moving the monitor, you damaged one of the pins that connects in the socket on the monitor, remove the lead and also inspect the socket if there is a broken pin inside it remove this and try a new vga lead.
If no pins are broken and / or the power is not even reaching the monitor, check the kettle lead, look for signs of damage to the rubber / plastic plug and the socket on the monitor (assume this one is fed directly from the mains?), If you have been unfortunate enough to have damaged one of the pins that is in the socket you will need a TV repairman to fix this.
Check also the condition of the lead itself, for breaks and whether the fuse in the plug has blown.
After that, your problem will need to be looked at by a qualified TV repairman, as the fault must lie on the board itself
Jul 26, 2011 | Acer Computers & Internet
Need help! My Samsung 2232bw monitor wont start the screen! On/Off button light, turns on and off all the time, but no picture! I've tried, to unplug and plug in the DVI, but nothing. It even wont show...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
one bad lead will end with a computer error
hope this will help
Mar 27, 2011 | Computers & Internet
Speaker connection for LG W2053TX monitor
This model of monitor does not come with speakers. In fact very monitors have speakers. You will need separate speakers for sound. Some monitors do come with external speakers which hook onto the monitor at the sides but they are still connected to the PC via a lead with a 2.5mm stereo plug into the sound output..
Dec 12, 2009 | Computers & Internet
I see a black screen when I turn thw computer on
The first thing to do is to check the lead from the monitor to the computer is correctly plugged in at both ends.
If this is OK then perhaps you try another monitor, if an other monitor works OK then yours may be broken.
If another monitor does not work then you will need to check your computer hardware and software.
Oct 30, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
Connecting sky box to to non scart reysis tv,via scart plug cable
This lead is usually coloured yellow and looks like the red and white leads you use to connect the tv speaker OUT sockets to an amplifier or external speakers. The input on the tv should be coded yellow also.
Jul 18, 2009 | Relisys RLT-1500 15" LCD Monitor
Missing Power Cord for Vivitar DVR 550
For
The power outage is 5 volts @ 0.75 amps DC
try connecting the camcorder to a PC (turned ON) via the USB lead and see if it will take power from the computer
Aug 05, 2008 | Video Cameras
NEC AccuSync LCD223WXM Monitor Logo
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
