My NEC fuzzy logic 6.5kg washing machine will not go into rinse or spin cyle. It shows ''DE'' on display
  • 12,061 Answers
Http://www.agent99.net.au/docs/nfl1265_user_manual.pdf
Have a look in your manual above.
Posted on May 29, 2010
I have a top lg fuzzy logic washing mechine, it stops at rinse position , display lights , gear are all working. whats the fault please ?
this usually happens when the water pump or the hoses are clogged and it cannot drain, it stops there and does nothing
Feb 10, 2015 | LG Washing Machines
My toploader machine is not rinsing or spinning the model is a LG Fuzzy logic WF-T7014pp
if it does not rinse its a different case,,,,,nd if it does not spin is another ,,,check on the door lid,its a magnet,,,,,,,,,,,,,,,,,attached the washer pic ,,,so i can tell u what to do............
if u have a magnet tryputting it between the door and its main program board,,,centre nd try
Jan 23, 2015 | LG Washing Machines
Lg Fuzzy Logic 5.5kg Turbo Drum with I-sensor, Model WF-T552TH Washing machine goes through initial fill up, when changing to spin/wash works for 2 seconds, then stops spinning back and forth and shows dE...
There is a small magnet at the front of the lid that triggers the door error, mine was corroded and the lg people wanted $80 for a service fee.. Ha I went to my local hobby shop and got a small earth magnet and some super glue $1.50 later and she's fixed.. tadAaa.
May 11, 2011 | Washing Machines
Hi i have an LG 5kg Fuzzy logic top loader and it will wash and fill the water but wont rinse or spin it does not beep or anything it just stops and the time displays stays on the same numbers and i can...
Need to check during the wash cycle that the power goes to the motor during the rinse or spin cycle. Try and see if you can manually go to the spin cycle without the fuzzy logic. If so the program controller unit is a suspect as the microprocessor internal memory is faulty and executes the program with error or no output.
Jan 21, 2011 | Washing Machines
Spin cyle does not come ,but water drain
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 24, 2010 | Maytag PYE2300AY Electric Dryer
LG Top Loader Fuzzy Logic 5.5. The water
No you just need to get the drain hose up higher...the water is siphoning out and is either caused by the end of the drain hose still in water and not having an air gap or the hose is not going up higher then the top of your washer...
Lifting the hose up should give you an air gap and get the hose high enough to stop the siphoning...
heatman101
Apr 27, 2010 | LG WFT1071TP Top Load Washer
Smeg s750 washing machine -how to rinse only?
Advance the timer to rinse/spin part of cycle.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 16, 2009 | Washing Machines
Washing Machines Logo
336 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
