Question about Akai Ewi4000s Electronic Wind Instrument
EWI4000s Hi, I got my EWI4000s back from a friend who'd used it for a recording, and now whenever I plug it into the power pack, it will only play one note, and doesn't seem to react at all to any of the front keys or octave rollers. When I used it with batteries it worked fine, but now for some reason it doesn't even turn on with any batteries, even a brand new set straight out of the box! I have a feeling my friend plugged the ewi into an input with phantom power on. Is there any way I can get my instrument to work again? Any suggestions are greatly appreciated!
    President:
  • 1,138 Answers
Try this site:http://www.patchmanmusic.com/
Posted on Jun 21, 2010
2 Suggested Answers
  • 10 Answers
SOURCE: EWI4000s only plays one note
Hello a_marechalro,
You can try to reset your instrument.
Turn off the EWI,
Press the LEVEL, FX, SETUP and TRANS buttons.
Then turn on the EWI.
This is a Factory reset.
I hope for You this is the solution.
Kind regards,
Fred Roubos.
Posted on Dec 27, 2008
Ewi 4000s cutting off
My EWI 4000s started to play by its self making a loud low note and then it stop and now it won't play at all. I Reset to Factory Preset but that didn't help. What do I need to do to get it to play again?
Feb 09, 2014 | Akai Ewi4000s Electronic Wind Instrument
Pitch bend issues
Hi, try to find how to reset it or go to default mode,find out in the users manual.Hope it will solve your problem,
Oct 17, 2017 | Akai Ewi4000s Electronic Wind Instrument
Why is my new EWI4000s must transpose to D to get the normal C key? When I turn off and TRANS BUTTON, the key is B.
Two things to check... check that the "tuning" is set to A440 as the adjustment range would reach a one note offset... Next check that the glide plate has not bent the pitch to the next note... If you are using MIDI, make sure the external device is not transposed on receive.
Sep 04, 2011 | Akai Ewi4000s Electronic Wind Instrument
Just bought the EWI4000s plugged it in but no sound.
First of all I recommend reading your entire manual cover to cover. Then read it again with the EWI in hand. Go step by step following the setup procedure. You have a complex instrument so it is very easy to miss something or make a mistake. Here is a link to the best wind synth website in North America:http://www.patchmanmusic.com/ There is an 1/8" jack on the instrument for headphones. There is also a 1/4"unbalanced jack for plugging into an amp, mixer etc. Here is a link to the manual if you didn't get one:http://www.akaipro.com/ewi4000s/?tt=5 It is battery powered ( 4AA batteries ) so don't forget them. It can be powered by an optional MP9-II adapter (use the exact model ). It has a built in analog synth so if you set it up correctly you should get sound right out of the box. Hope this helps.
Oct 26, 2010 | Akai Ewi4000s Electronic Wind Instrument
Cannot play staccato, there is latency
Consider joining the forum here:http://www.patchmanmusic.com/WindControllerLinks.html It sounds like it is a velocity setting problem but the solution should be in your manual. It may also be a setting in the sound module you are using.
Jul 04, 2010 | Akai Ewi4000s Electronic Wind Instrument
Hello a_marechalro,
Turn off the EWI,
Kind regards,
Fred Roubos.
Dec 26, 2008 | Akai Ewi4000s Electronic Wind Instrument
Ewi4000s as a controller
Adjust the VB & BR knobs if theyare turned up too much, the instrument senses that as a continuous note on signal.
Dec 25, 2008 | Akai Ewi4000s Electronic Wind Instrument
Detuning of Akai EWI 4000s
Are you shure that you aren't touching the bend up plate with your right thumb? This isn't easy detected by sax players which are used to have a thumb rest at exactly the same spot where the bend up plate is. You might switch it off (see manual). With the bend up plate on you should aways use a tight strap which helps a bit to not touch the bend up plate accidentally. I'm still struggling with this occasionally.
Oct 31, 2008 | Akai Ewi4000s Electronic Wind Instrument
Akai Ewi4000s Electronic Wind Instrument Logo
208 people viewed this question
Top Akai Music Experts
Michial Gueffroy
drivealot
Are you an Akai Music Expert? Answer questions, earn points and help others
