How to uninstall deep breeze if it is active
How to uninstall deep breeze if it is in active mode. i forgot the password
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 121 Answers
Vista comp :-uninstall from the prog and feature option going to control pannel..//
xp comp: goto add and remove prog in control pannel//
Posted on May 29, 2010
I forgot my deepfreeze and i need to delete it tho it can't be deleted without unfreezing my pc i tried antideepfreeze and it failed for me ....what can i do ?
There's no possible way to recover a lost/forgotten Deep Freeze password. But there are several ways to possibly disable/uninstall DeepFreeze.
Enterprise Version :
Deep Freeze Enterprise users can generate One Time Passwords (OTP) to gain access to deepfreeze. To generate an OTP,
  1. Open the Deep Freeze login dialog on the system for which you need to generate the One Time Password.
  2. Write down the Token code. It is located at the top of the login dialog.
  3. Open the Deep Freeze Configuration Administrator and click the One-Time Passwords tab or open the Enterprise Console and click on Tools > One Time Password.
  4. Enter the code you recorded into the Token field and click Generate OTP. Another code will appear in the OTP field. The second code is the password for the workstation.
The newly generated One-Time Password can then be used to disable, uninstall, and re-install Deep Freeze with the correct password.
For Deep Freeze evaluations (with no License Key entered) :
  1. Restart the computer.
  2. Enter the system BIOS settings.
  3. Advance the clock by at least 60 days and then restart your computer. This will disable the software.
  4. After the system has started, run the Deep Freeze installation program to uninstall Deep Freeze.
  5. After the computer reboots, re-enter the BIOS and reset the clock to the current date. You can then re-install Deep Freeze after restarting.
If you are running a licensed copy of Deep Freeze Standard submit a ticket and we can look into the issue further to see if there are any other options avalalbe to assist you.
Feb 14, 2013 | Computers & Internet
Tip
How to uninstall deep freeze
To uninstall the software Deep Freeze must first be disabled and then uninstalled.
To disable Deep Freeze:
1. Hold down the shift key and double-click on the Deep Freeze icon. Alternatively, you
can press Crtl-Alt-Shift-F6. You should now see a password dialog.
2. Enter your password and click OK. If you have not yet entered a password you should be
able to click OK without entering anything. You should now see a dialog with boot options.
3. Select "Boot thawed" and click OK. This will disable Deep Freeze on the next reboot.
4. Reboot your machine. After the machine reboots you are ready to uninstall Deep Freeze.
To uninstall:
1. Locate the installation file you used to install Deep Freeze to this machine. By
default the name of this file is called "DF5Std.exe" for versions 5.X and "DF6Std.exe" for
versions 6.X.
2. Run the installation file (DF5Std.exe or DF6Std.exe).
3. Select the option to "Uninstall"
4. The software should uninstall and reboot the machine. When the machine reboots, Deep
Freeze should be uninstalled.
on Mar 15, 2010 | Computers & Internet
Uninstall deep freeze, forgot password
If you are licensed for Deep Freeze Standard and have forgotten your password, please email technical support at support@faronics.com for further information. Include your license number and organization details.
If you are running a 60 day evaluation version of Deep Freeze and have forgotten your password, then enter the computer s BIOS and forward the system clock 60 days & restart.
I hope this helps, if it does, give me a big thumbs up!
Jun 28, 2011 | Computers & Internet
Cannot uninstall deep freeze
uninstall it using administrator password
May 10, 2011 | Computers & Internet
I installed my deep freeze software in my laptop.now i forgot that password. so really i cant store anything in my laptop.
Hi!
Sorry I was unable to provide you exact help on this one as I don't know the deep freeze version you are using but you may want to try these steps, if it doesn't work out, please coordinate with us with the version of the deep freeze.
For Deep Freeze Enterprise:
  1. Open the Deep Freeze login dialog on the workstation for which you need to generate the OTP.
  2. Write down the Token code which is located at the top of the login dialog.
For Deep Freeze evaluations (with no License Key entered):
If you are running a licensed copy of Deep Freeze Standard submit a ticket and we can look into the issue further to see if there are any other options available to assist you.
Or if you may want, you can also back up all your files then reformat the computer. Thanks for reading my suggestions.
Hope this helps even a bit.
Apr 17, 2011 | Computers & Internet
How to uninstall deep freez software frm my pc
From the DeepFreeze FAQ:
  1. Hold down the shift key and double-click on the Deep Freeze icon. Alternatively, you can press Crtl-Alt-Shift-F6. You should now see a password dialog.
  2. Enter your password and click OK. If you have not yet entered a password you should be able to click OK without entering anything. You should now see a dialog with boot options.
To uninstall:
  1. Locate the installation file you used to install Deep Freeze to this machine. By default the name of this file is called "DF5Std.exe" for versions 5.X and "DF6Std.exe" for versions 6.X.
  4. The software should uninstall and reboot the machine. When the machine reboots, Deep Freeze should be uninstalled.
Second method (if you don't know the password) is to use a program called Deep Unfreezer v1.6
Nov 24, 2010 | Computers & Internet
How to uninstall deep freeze 6?
You havent mentioned the O/S you are using, try this if its XP
Here the small tricks to disable or unintal Deep Freeze ver 6 without password:
  1. Boot your computer from Windows XP Installer
  2. After appear “Enter to Setup” option, Press Enter then press F8.
  3. Selected R to repair Windows system ( Repair Setup)
  4. Continue repairing/installing windows untill finish.
  5. Prepare the Deepfreeze v.6 installed, open the file like you want to install the software.
  6. it’s will show “Uninstall Deep-freeze” options. Uninstall the software, after uninstall finished reboot your computer.
  7. Now the Deep-freeze has removed from your computer.
FOR VISTA / WIN 7
Power Off the PC
Start the PC and Press F8 key till you get Boot options,
Start the PC is SAFE MODE and try to uninstall it.
Jul 06, 2010 | Computers & Internet
I forget the deep freez password and i want to uninstall deep freez but the dep freez are frozen. it is not disable
Oh!!
You have to Re Install your Operating System now. There Are no More Options left g\for your after forgot ting password. If you using license product then contact deepfreeze Devlopers to get help.
Thanks.
Happy to help you.
Apr 24, 2010 | Computers & Internet
How to uninstall deep freeze from your pc?
how yto uninstall deep freeze, password forgotten
Mar 21, 2009 | Amana 16.8 cu. ft. / 476 liter Upright...
To uninstall:
Apr 08, 2008 | Computers & Internet
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
