How to reset ink pad on epson rx425 - Computers & Internet
  • 12,061 Answers
Http://www.fixyourownprinter.com/forums/printer/43150
Go to that above address and it directly addresses your issue.
Posted on May 29, 2010
Epson RX420 needs resetting, lights flash and PC can't detect it.
In most cases, it's a waste ink pad full problem (the sponge that sucks wasted ink is full). But it probably isn't full yet (Epson claims it's full long before it really is!).
You'll have to download the service program for Epson printers (which gives you access to service functions of your printer):
http://www.eserviceinfo.com/downloadsm/22895/SEIKO%20EPSON_EPSON%20RX420-425-430.html
Run the exe file (it doesn't work in Windows Vista or 7 - you'll need old xp for that). Then Select Sequential Adjustment Mode. Select your printer model and then Waste ink pad replacement. Press Ok.
You might have to try a bit.
After you suceed, you need to turn off the printer and turn it on again. If all went well, you won't be seeing all the blinking lights on your printer ;)
Nov 08, 2009 | Epson Stylus RX425 Multifunction...
EPSON RX425 RED INK LIGHT STAYING ON
Try to find "EPSON RX425 Resetter Software" at google
Sep 06, 2009 | Epson Stylus RX425 Multifunction...
Printer Epson R230
Replace the ink pad on the printer.
log on to epson.com to get the ink pad reset utility software. It runs on win xp and win vista only.
May 02, 2009 | Epson Stylus RX425 Multifunction...
All lights flashing
You need to replace the ink pad of your printer.
Please visit epson.com/ipr to get the ink pad reset utility. The software runs on win xp and win vista.
If you need help in replacing the ink pad, please log on to epson.com to find an epson certified servicer near to your area.
Apr 27, 2009 | Epson Stylus RX425 Multifunction...
Stopped printing service required? how to get around
Ok, the key problem here is that your printer has indicated the waste ink pads in the printer need changing because they're full of waste ink.
Resolving this is a two pronged attack.
1. Download the SSC utility from here:
http://www.ssclg.com/epsone.shtml
Install then run.
Under configuration choose you RX425 printer then in the "printer model" field choose the "Epson Stylus CX4600(4500)/CX36x0(3500)/RX42x(430)/MP-A700" option.
Click on the top right X as if you were closing the utility and you'll see a little printer icon appear in the system tray (series of icons in the bottom right hand corner of your screen usually).
Right click on this and locate the "Protection Counter" and under this the "Reset Protection Counter" and "Clear counter overflow"
Then turn off your printer and turn it back on again. You should be able to print again now.
2. BUT... You still have a printer with close to full waste pads so you need to deal with that. WARNING: Ignore it and expect to get a puddle of waste ink flowing out of your printer at some point!
Various instructions for dealing with this are available here:
http://www.continuousink.info/forum/viewtopic.php?t=4128
... and you can opt for a pre-built kit or just do a DIY with parts you've sourced yourself.
Hope that helps :)
Jan 18, 2009 | Epson Stylus RX425 Multifunction...
All lights flashing, Reset code wanted?
The answer to my problem was to download ssc service facility it not only resets my reset problem, it also resets inks as well. Download is free and i rate it first class. It covers many epson printers.
Dec 21, 2008 | Epson Stylus RX425 Multifunction...
Error message on epson rx425
Follow this link.
At the bottom of page agree to terms and install.
On the "configuration page" and in the 1st drop down screen select your printer.
On the 2nd drop down screen is where I was getting confused as I have a Epson Stylus Photo RX425 but couldn't see it in the listings, it is there, look for:-
"Epson Stylus CX4600(4500)/CX36x0(3500)/RX42x(430)PM-A700" and select.
Next click this page off and in the botom right quick launch panel right click the multi coloured printer icon.
Select the "Pretection Counter" then "Reset Pretection Counter"
There you have it, switch off and back on the printer and all should be well.........
May 21, 2008 | Epson Stylus RX425 Multifunction...
Problem with my printer Epson Photo Stylus RX425
This indicates that the waster ink chamber is getting full. To clean it out means dimantling the whole machine bacuse it sits in the base of the machine and is a series of absorbant pads.- they need rinising and drying. However this waring is an electronic fudge based in the number of pages. Using SSC right click on the taskbar icon and click on 'Reset All counters' You can also resetby pressing a combination of the buttons whilst switching the machine off then back on. Which buttons? Good question - different models differnt button combinations to you will have to work through them. You may find some help at www.fixyourownprinter.com
Sep 19, 2007 | Epson Stylus RX425 Multifunction...
EPSON RX425
Hi all you rx425 owners with the flashing light and E problems. I have found a fantastic program to solve this. go to this link http://www.eserviceinfo.com/downloadsm/22895/SEIKO%20EPSON_EPSON%20RX420-425-430.html
there is a great download called rx430.
personally when i ran program i only had to choose the waste ink pad option and clicked replace. Now all is fine. don't bother with the SSC download program it just don't work.I really hope this program helps you all, the best thing is it's FREE!
Jan 23, 2007 | Epson Stylus RX425 Multifunction...
Computers & Internet Logo
335 people viewed this question
David Payne
David Payne
