Question about Sony Cyber-Shot DSC-S500 Digital Camera
I can't get the power button to stay on and the camara keeps shut
My camara battery door wont close all the way and the power to the camara keeps going out is it because of the door not closing or is it something else ?
  • 10,594 Answers
Battery lid will be replaced as its tabs could be broken that hold and lock it in its place. I'm talking about Sony DSC-S500 camera.
It can be replaced easily, let me know if you need part number info.
Thanks.
Posted on May 30, 2010
  • blitz50 Jan 20, 2011
    Need info on the battery door part number. The tab for locking is broken as you said. How is the door removed? I'm pretty good at fixing things and thought I would give it a try.
  • Shahid Electronics
    Shahid Electronics Jan 20, 2011
    Part number is as follows..
    269948301 ... LID, Battery Case
    Pull broken battery case outward with little force to remove it from metallic part, slide new cover on metallic part, job is done.
  • Sony Master
  • 3,866 Answers
Most likely we got a bad door or one of the battery tabs inside is making it where it cannot close and thus looses power. Your right the battery door must be secure to gain the charge needed for the camera's function. What I would do is take it into a camera shop have the look it over sounds like a easy fix nothing that is going to break the budget.
Thanks hope this info helps please do leave your feedback and ratings for this free answer today.
Posted on May 29, 2010
Drivers door wont catch and can shut or lock car.. all others are fine. Any ideas?
Car Door Won't Close or Stay Shut - JamesMaurer.com
https://www.jamesmaurer.com/car-door-wont-close-or-stay-shut.asp
If your car door won't close or stay shut then this quick free fix is just for you! ... It's a great day when you can prove to your child your not as old as they think you are :) .....It's pouring outside and my rear passenger door latch messed up. .... two doors and I couldn't shut them.. was worried I would have to catch the bus until we ...
Repairing a stuck latch on a car door - YouTube
? 4:24
https://www.youtube.com/watch?v=tQYWOK1q_iQ
Dec 22, 2012 - Uploaded by backyardmech
Fixing a stuck latch on a car door. Video shows that the door won't close, how to release the latch, the ...
Ford recalling 390,000 cars over door latch woes - Autoblog
Jan 16, 2016 | Cars & Trucks
Battery door won't stay closed on Sony Cyber-Shot DSC-S90 Digital Camera
The battery door latch is most likely damaged/broken. Try using a piece of duct tape to keep it closed. I've done this on several cameras with battery door latch issues & the doors stayed shut just fine.
May 20, 2014 | Sony Cyber-Shot DSC-S90 Digital Camera
Key fob wont re set on my ssan yan rexton
I recently changed the battery on my key fob for my ssanyong rexton. I then did the following for the key fob to make it work. 1. Enter vehicle and close all doors.
2. Put seatbelt on (or clip it into the buckle) to shut the warning buzzer off.
3. Put key in ignition, turn to run position but don't start it.
4. Press and hold both buttons on key fob until red light on fob stays on. Then let go of both buttons. Then pressed the alarm button then the panic button, somthing like that. To be fair the button sequence after the red light came on is a bit vague. The alarm was blaring so i was happy when it just stopped.
May 23, 2012 | SsangYong Rexton Cars & Trucks
My laptop screen will not shut off. I have a Sony Vaio about 6 years old. When I power down the screen shuts off while everything is shutting down but then when everything is off the monitor turns a light...
if u r using vista sure check the shutdown button.
or press once power button it automatically shutdowns
or hold power button until it shut down
when u close the door it only standby..
Oct 22, 2009 | Dell Inspiron E1405 Notebook
Cd door wont shut
this is possible but can lead to more frustration. The cd door usually has a plastic tab that depresses on a button or blocks the opto sensor to indicate it is closed. I presume that your cd door is missing this tab or the circuit that activates when the door is closed is faulty. Block the opto sensor manually using paper or keep the button depressed that the door tabe closes on. You will not need anything to keep door closed unless it is reqiured to play the cd then just use a brick
Aug 15, 2009 | GPX Karaoke Party Machine CD+G Portable...
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
Door wont stay shut
The door latch could be closed, in other words, the door thinks it shut into the striker. Take and hold the door handle open, like your trying to open the door, hold the handle out or up and at the same time open the latch, it may be stuck or closed...If that's not it, you may have to re-align the latch to the striker, the striker will come loose with a torx bit. Loosen it up, and move it around and re tighten, it's a trial and error deal, just keep trying different positions until if works right...
Feb 25, 2009 | 1998 Chevrolet K1500
Lens problem
If you've replaced the batteries with fresh ones, it probably has a broken zoom assembly. It'll have to be replaced by a repair shop.
Dec 13, 2006 | Canon PowerShot A520 Digital Camera
Sony Cyber-Shot DSC-S500 Digital Camera Logo
361 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
