Question about HP Pavilion zd8000 Notebook
Overheating keyboard, wrist rest around mousepad, sides and bottom feel hot. I want ot open the case to clean internally. How do I safely open and reassemble it?
  • Cryovox Apr 14, 2008
    so far ive tried to keep a fan blowing open breathing room for it everything, cold rooms, some times it will stay on for hours no problem others i cant even check my email. ive tried opening it but seem to get stuck it wont open all the way its like its glued or something how did u open it past that part?
Please send me a mail too. [email protected]
Posted on Apr 16, 2008
I have the same problem
this is my e-mail
[email protected]
please I need your help.
Posted on Apr 11, 2008
  • 36 Answers
Its a wierd problem... actually it might be the heat radiated of your CPU.. if u're sure that this is not the reason, then chk whether the place where u've kept the kbd gets heated even if the keyboard is not kept there.. if u wanna open ur kbd, u must be careful.. first of all lemme tell u that though it is a simple process, i'm in no way responsible for anything that happens when u do it if u do things other than what i say.. i'll tell u how to do it if its ok for u.. send me a mail..
Posted on Apr 08, 2008
6ya staff
SOURCE:
How can i unfreeze the mouse from an acer labtop
You are actually talking about a external mouse ot the mousepad at the bottom of yout keyboard.
Feb 02, 2015 | Acer ku.01650f.006 - Black Desktop Dvdrw...
REPLACE POWER JACK
http://www.ebay.com/itm/pcg-41217L-sony-vaio-DC-JACK-POWER-JACK-FOR-Input-Port-Socket-vpcsc-VPCEL-VPCF-V-/370628762815
Has two channels on the sides, to slide down into a channel formed in the outside edge, of the laptop Base Enclosure. (Bottom Cover)
Wires are soldered to it. Two of them. If there is a Red wire it goes to the Center terminal on the back of the jack. The Center hole is the Positive connection.
The Black wire goes to the outside terminal on the back of the jack.
(Negative)
Use good de-soldering/soldering skills. Do not make a cold solder joint. (Solder connection)
There are no exact Service Manuals listed for the Sony VAIO PCG-41217L Notebook PC. (It is also part of the VPCSC series. It is a VPCSC31FM)
However after you disassemble 100 laptops, or so; you find disassembly of all laptops follows a basic pattern.
http://www.ebay.com/itm/Sony-Vaio-vpcsc1afm-pcg-41217l-s-series-laptop-I5-blu-rau-MS-OFFICE-installed-/271101863505?pt=Laptops_Nov05&hash=item3f1eee2651
This shows me different key views of the laptop. I have also opened a separate window, with the User Guide from Sony eSupport.
The Ebay link shows detail of the Palm Rest Cover.
Shows it to be one piece with no separate Switch Cover.
(Switch Cover: Flat plastic strip above Keyboard, and below Display Assembly.
Usually has the Power On button, LED indicator lights, speakers, etc in it)
Also shows me a Bottom View.
1) Remove ALL power. Remove the AC adapter (Charger), and Battery.
2) Lay the notebook on a clean, static free cloth, on your table.
Helps protect the table, and the laptop from scratching.
Lay the notebook bottom side up, Battery Compartment facing away from you.
Use a multi-compartment container, and label each compartment for the area the screw/s come out of.
SOME screws look VERY similar to other screws. Advise DO NOT mix them up.
You should be wearing an ESD wrist strap, and have it's alligator clip attached to a good ground source.
Average cost is around $3 to $6. Do not wear it, and/or connect to a good ground source, and when you are finished you can use your laptop for a doorstop.
Static 'kills' computers.
Example of an ESD wrist strap,
http://www.radioshack.com/product/index.jsp?productId=2103245
I connect to an unpainted surface, of the metal frame of an open, empty desktop computer case. I feel an Anti-Static Mat is unwarranted.
You can set a large metal serving tray (Unpainted), on the table you're working on, and connect to it.
Or a large metal knickknack. (Unpainted)
You are going deep into the laptop, and the Static sensitive Processor, and other hardware components could be 'zapped'.
Use ESD wrist strap.
All screws are removed from the bottom of the laptop. All around the perimeter (Outside), and the inner ones.
The optical drive (CD/DVD drive) will slide out.
After the optical drive is removed, look to see if there are any hidden screws on the outside edge of the laptop, that may have been covered by the optical drive. Remove them if so.
Remove the Harddrive.
Remove the Ram Memory.
Remove all peripheral components. (Dummy PCI card, etc)
I don't know if the Palm Rest Cover removes on this model, or the Bottom Cover. (Base Enclosure)
Bottom Cover removal style,
http://www.insidemylaptop.com/take-apart-sony-vaio-vgn-cs215j-laptop-replaciong-dc-jack-harness/
Yes. The bottom cover access panels are different than yours.
Posted for Keyboard removal, and Bottom Cover removal.
NOTE*
The Keyboard Cable STAYS attached to the Keyboard. It removes from the motherboard. There is NO plug connector on the end of the Keyboard Cable.
The Keyboard Cable is a FFC. Flat Flex Cable,
http://en.wikipedia.org/wiki/File:Flat-Flex-Cable.jpg
It ONLY plugs in, in one direction. Must go back the same way it was originally. Even if it was originally twisted.
For this reason you may wish to make a mark on one side of the cable, and a matching mark on the same side of the motherboard connector. (Sharpee?)
The motherboard connector is a type of ZIF connector.
Zero Insertion Force.
It is composed of two separate pieces, but DOES NOT come completely apart.
There is a larger rectangular Bottom part. This is the Body, and it is stationary. Mounted to the motherboard, and doesn't move.
There is a smaller rectangular piece on Top.
This is the Locking Bar.
There are two styles presently used;
1) This style slides. Slides up towards the LCD screen.
ONLY slides about 2mm. That is a little more than 1/16th of an Inch.
A) Closed, or can be said as Locked;
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-C650-C655/body-big/disassemble-toshiba-c655-11.jpg
B) Open, or Unlocked;
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-C650-C655/body-big/disassemble-toshiba-c655-12.jpg
The Locking Bar is barely seen on top, and the sides. The 'tabs' of it on the sides, are eased towards the LCD screen, with the thumbnails.
2) This style flips up,
A) Locked;
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L645D-L640D/big/laptop-disassembly-13.jpg
2) Unlocked;
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L645D-L640D/big/laptop-disassembly-14.jpg
IF, the Locking Bar is removed from the Body, it is broken; or the Body hinge pins are broken.
EITHER way means MOTHERBOARD REPLACEMENT, and why I am being so detailed. Use care.
Here is what the Keyboard looks like,
http://www.ebay.com/itm/SONY-PCG-41217L-Keyboard-Silver-/261121017591?pt=PCA_Mice_Trackballs&hash=item3ccc0686f7
Put your mouse in the middle of the photo, and slide to the right side of the Keyboard.
See that half-moon tab sticking out, that looks to have a threaded hole in it?
Screw comes up from the Bottom of the laptop, and goes into this tab.
Looking closer at the open laptop view of the Keyboard, it almost looks like the Keyboard is under the Palm Rest Cover, and cannot be removed until the Palm Rest Cover is removed.
May just be the view, or my eyes.
That is about as far as I can take you.
Post the problems you run into in a Comment, and we'll try to work them out together.
Regards,
joecoolvette
[ Just in case it will help,
http://www.insidemylaptop.com/category/7-sony-laptops/
Nov 11, 2012 | Sony VAIO Computers & Internet
How to open casing and upgrade the RAM in Gateway LT2811u?
A) No, the case does not lend itself for easy access to the Ram Memory.
B) 'Other site' is full of beans. Impossible to replace, or upgrade the Ram Memory? Must not be a professional product support website, and does not have computer techs.
1) Work on a table. If the table is on a carpeted floor, refrain from swinging your legs. Observe Anti-Static Precautions.
[ Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
With a desktop computer you can relieve your body of Static by;
Computer on a table, computer unplugged from power, computer case open.
TOUCH an unpainted surface, of the metal frame of the open computer case.
This action will relieve your body of Static.
IF, you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return.
No such luck when working on a laptop/notebook/netbook/tablet.
An ESD wrist strap should be worn, and it's alligator clip connected to a good ground source.
{ Average cost of a Electro Static Discharge wrist strap, is around $3 to $6.
Example,
(It isn't just a piece of wire connected to an alligator clip, and to your wrist. The wrist strap has a metal plate which contacts the skin of your wrist. The metal plate is connected to a 1 Mega Ohm resistor, which in turn is connected to the wire going to the alligator clip,
http://en.wikipedia.org/wiki/Antistatic_wrist_strap )
I connect to an unpainted surface, of the metal frame of an open, Empty desktop computer case ]
It may be argued that you are just replacing Ram Memory, and an ESD wrist strap is not needed.
In this instance I will agree.
There is a metal static shield under the Keyboard, and next to the Ram Memory. The Processor is under the motherboard. (To the right of the Fan Assembly, when looking down from the top)
Also, ram memory modules ('Stick') are coated with a see-through plastic coating, on the Body of the module.
(Refrain from touching the gold plated contact pins on the bottom)
I would place a clean towel on the table, to protect the table, and the Netbook, lay the closed netbook upside down on it. (Bottom side up)
2) Remove ALL power. Remove the AC adapter (Charger), and Battery.
3) Turn the netbook over, open it as far as possible.
Remove the Keyboard
4) Removing the Keyboard:
At the top of the Keyboard, (LCD screen side) there are 4 Tabs to release.
They are from Right to Left;
Above the DELete key, F12, F8, and F4 keys.
If you look close you will see four thin rectangular pieces of plastic, above the noted keys.
These are depressed down.
I c-a-r-e-f-u-l-l-y press down on them, with a flat tipped Jewelers screwdriver.
Start on the left side with the release tab above the F4 key.
Once depressed the Keyboard will be released from this tab.
Go to the next tab, and so on.
Once all release tabs are released, the top of the Keyboard should pop up, a little.
S-T-O-P!
The Top of the Keyboard is lifted s-l-i-g-h-t-l-y up. Do Not raise it too high.
There may be side tabs also. These will pop loose once the top of the Keyboard is raised up slightly.
There is also a Keyboard Cable attached to the Keyboard.
It is Not needed to disconnect this cable, and I STRONGLY advise against it, as the plastic tabs of the connector on the motherboard, will break VERY easily.
Leave the Keyboard Cable attached.
The Back of the Keyboard may have plastic tabs protruding from it.
This is why the Keyboard is only raised to a slight angle, also.
With the Keyboard in an approximately 45 degree position, move it forward a little, then roll it over, and lay it down.
(Top of Keyboard lays down)
The bottom of the netbook has a Door. This Door is removed for access to the Ram Memory, and Harddrive.
Keyboard removed there are 5 screws marked with Door next to them, to remove.
Push on Door Release (Pretty hard) to ease the Door out.
Then go around, and gently pry the Door off.
Each ram memory module has a spring clip on the side. Each side.
The top of the clip is gently moved to the outside, just a little.
The top of the spring clip has a 'bump', or protrusion, which fits in a Side Notch, on the Ram Memory module.
Once both spring clips are eased out, the Ram Memory module will slightly spring up.
DO NOT remove a Ram Memory module in a straight up position!
You will bend contact pins down in the ram memory slot on the netbook, and damage the contact pins on the Ram Memory module.
The Ram Memory module is brought out in a 45 degree position.
It is installed back in the same position.
Handle the Ram Memory module by the Body. The body is coated with a see-through protective plastic. (The gold plated contact pins are on the bottom, of the Ram Memory module. The rest of the module is the Body)
When the protrusions of the spring clips are fully seated in the Side Notches of the Ram Memory module, the Ram Memory module is fully seated in the ram memory slot.
(Note*
The spring clip protrusion, and the Side Notch, are not a perfect fit.
A little leeway is allowed )
The Gateway LT2811u Netbook PC uses DDR3 Sdram ram memory, that operates at a maximum frequency rate of 1066MegaHertz.
(1066MHz)
It is PC2-8500 that is SO-DIMM.
The Maximum TOTAL Amount of ram memory is 1GB.
There is 1 ram memory slot.
Regards,
joecoolvette
[ Mega = Approximately 1 Million
Hertz = Cycles per Second
The above ram memory, can operate Up To 1066 Million Cycles per Second, frequency rate. ('Speed')
Dec 11, 2011 | Gateway Computers & Internet
My Kenmore side by side Refrigerator Model No. 253.55679403 will not freeze or cool, ice is melting and food is thawing. Light comes on and I can hear a fan or something, but I'm n ot sure. Can you help?
if you hear a fan in the freezer section when the door is open. feel the bottom of the fridge for hot air blowing. if you dont feel any hot air at the bottom, the condenser fan is the problem. if you do feel hot air then you have a defrost issue.
Jul 24, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
How do i disassemble to access motherboard and DC jack
Me too, need to get inside to clean and remove dust and see why my video is gone after about 10 minutes of operation or so, good chance it is an overheating problem, but I cant get the case open.
May 19, 2010 | E-Machines M5414 Notebook
My daughters Dell d800 ..mouse problem
Boy, It's been awhile since I took mine apart, but rest assured, all Dells come apart with ease, so try and assemble again but watch carefully that ribbon cables are secure! I would just reassemble or plug in and test before the case is assembled. Dell motherboards work fine without a case for testing
Mar 14, 2009 | Dell Latitude D800 Keyboard
Spilled Grape Juice
To give it a good cleaning, you will need to remove the keyboard and clean anywhere you can see juice or feel stickiness. You can buy the expensive computer cleaners, but I suggest 50/50 rubbing alcohol and Q-tips. Remove the battery and C-mos battery to make sure there is absolutely no power to the machine what so ever. After cleaning inside, you will want to give it a good 24 hours to dry, ensure that there is no moisture before applying power. If the juice reached the bottom of the machine, you may need to remove the screen, split the cases, and take the motherboard out, in order to clean the bottom side of the board. If you leave juice anywhere on the board it will gum up, and the acids in the juice will corrode and detierate the circuitry on the board causing a motherboard failure. Now the keyboard, in order to thoroughly clean the keyboard, I suggest that you spray a good amount of the rubbing alcohol in the keyboard, shake it or blow it out with air, then take paper towels and daub up the rest. Repeat this two or three times, then let it dry approx 24 hours. Sometimes the keyboard won't recover after a spill and will need replaced. If it works properly, then, after using the keyboard for a while, you will notice if any of the keys are sticking. Take the sticky key or keys off and clean them individually. I know it's alot of work, but it'll teach you not to keep open drinks around your laptop. It did me, I've ruined one machine, two keyboards, and thoroughly cleaned a third very expensive machine of mine to keep it working, but I finally learned to drink from a sippy around my laptops.
Jul 21, 2008 | Dell Inspiron E1505 Notebook
Keyboard and mousepad
check the function and F keys on my system the <FN><F9> is the mouse and F5 is the keyboard.
Jun 16, 2008 | Acer Aspire 5100 Notebook
The button under my mousepad on my laptop keeps sticking bad. i spilt some pop on it a few week ago what can i do? can i sort it myself?
If you are good enough in opening the casing of a laptop & then safely closing it back,then you may try opening the casing & the keyboard.The mouse touch pad is usually a seperate unit attached with MB with a thin film cable.You have to carefully remove it from its connector & then try cleaning it with any cleaning spray.I am not very optimistic about it as usually the "touchpad" is a sealed unit & the tiny microswitches will be sealed inside the housing!
Apr 16, 2008 | Computers & Internet
GE wireless optical mini mouse
Not sure if it could be a mouse issue or a surface issue. Some things to keep in mind: 1. Most mice have a "channel" buttof on the bottom used to pair it with the wireless base. Try pressing this a few times to see if you get the desired effect. 2. Surface has a lot to do with quality of the mouse tracking beacon. I suggest dropping $10 on a mousepad. I have a mouse pad with a wrist rest I paid $15 bucks for and even though the mouse doesn't move as fast as on the desk, simple changes in the Control Panel for mouse tracking solved this issue. 3. I am not one to harp on a particular mouse manufacturer but I have had a great deal of good experiences with Logitechs line of mice and keyboards. Hope this helps. D.
Sep 19, 2007 | GE Optical Mini Mouse ho98094
HP Pavilion zd8000 Notebook Logo
88 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
