Question about Gestetner DSm645 Digital Imaging System
I have gestetner 645 i installed in windows xp machine with network.now inside the computer priner is on ready condition and i am able to ping printer. but when i print some document so its not display any print or not receiving any print.plz help
  • 313 Answers
Check you have the correct port set up in the printer properties.. the default is usually parrallel or usb if connected with network cable open the printers faxes page on your computer and right click on your printer open the ports tab and check if it is set to TCIP you will have to enter the ip address here. you can get this by going to the copier press the 123 button at top left then press for printer and print the config page..hope this helps A
Posted on Jul 19, 2010
Cannot connect to wireless network
does it have wireless capability? most ricoh/savin/lanier/gestetner machines must have an option installed.
if you have it networked via lan port and have a wireless access point on the same network you should be able to ping the unit and access the gui. if so it is already "wireless" in a sense
Feb 05, 2016 | Ricoh Aficio SP C830DN - Printer - color -...
Scan to file on DSc525
The smb version on windows 7 is new than the one on XP. You will need a firmware upgrade.
Jul 29, 2013 | Gestetner DSc525 All-In-One Laser Printer
My xp wont reconise wireless networks in range any more
Well It could be a problem with the hardware or softwarefor software query , go to run > type Msinfo32 and click ok> check for the NIC ( Network Interface card ) Installed in your computeror laptop ... go to google.com and download the latest version for the relevant NIC and install it ... before installing it right click on my computer and click on properties or Press pause break button on your keyboard with the help of windows button > then do to device manager .... amongst the list of hardware click on network adopter and expand it > right click on the content and click uninstall > close all windows then install the latest updated driver
to verify thet the nic is working properly go to run and type > PING 127.0.0.1 and press ok if the ping command works your Nic is work properly if problem doesn't goes off
in computer :- buy another Nic and install it in PCI slot and install the supporting driver that comes with the new nic... if you have no idea of hardware then buy a external usb wireless NIC ... ( its plug and play ready and is compatible with win xp sp2 install it and try it .... it will definitely resolve your problem
for more queries revert back to me at any point of time
spd.sam@gmail.com
Apr 15, 2012 | Microsoft Windows XP Home Edition English...
HOW DO YOU NETWORK A canon imagerunner 1023
do You want to connect the machine on network or .... ?
First check if you on back side of copier have the network connector.
If yes, you need to connect the normal network cable if you have network switch or cross cable if you are connect directly on PC.
Then you must enter the IP adress in machine, under user mode (*) under system settings, under IP adress.Also enter subnet and gateway adress.
Free IP adress you can check on your pc under CMD and type ipconfig, to see your ip, subnet, and gateway.Then type : ping XXX.XXX.XXX.YYY The YYY marks number that you can change and must not be same as yours PC.After typing ping .......... and you have answer DATA LOST that means the ip is awailable and you can type it in copier.
Install drivers and select tcp/ip port.
If these isnt solution that you asked for, you can also contact me on emma.servis@gmail.com with more detailed description.
Hope that helps!
Sep 02, 2010 | Canon imageRUNNER 1023iF Black and White...
I can 'ping' my network printer, but XP will not install it
Under Printers and Faxes folder - Click on File and Click on Check Server Properties - Under Ports Tab check if IP of the printer is already recorded, if so Delete it and try using Add a Printer again
Jun 13, 2010 | HP Computers & Internet
How do you install an ethernet card on a gestetner DSM645 copier/
Are you trying to install an ethernet or "NIC" card in order to turn the machine into a printer? If so then you need more than a nic card. You would also need a ROM chip, Print controller, Hard Disk Drive and the buttons for the control panel.
If you are just replacing a NIC and expanding the memory then that is possible but the instructions to do so would be more than could be typed up here.
Jan 16, 2010 | Gestetner DSm645 Digital Imaging System
Hi, I ma trying to connect my gestetner DSM415f to my home network. I have the wim open and hve pinged to be sure that it os being picked up. I am trying to set the machine up to scan. I am operating...
Folder must be fully shared, (full control for everyone.) create a user name and password that has admin priviledges. Enter this info in Config>File transfer>SMB.
Enter the path to the folder in the address book, in this manner> \\name of computer folder is on\name of directory\name of folder.
Sep 07, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
I am trying to set up networking between 2 computers sharing an internet connection. The XP machine is up and running. The Windows 98 machine never had networking; I installed a CNet PRO200 PCI networking...
Have you seen this article? It may have to do with the cable setup. See #8.
Good luck...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 10, 2009 | Cnet Pro200 Network Adapter
Cant get it to see the network i ping it to an ip address and no response. both lights on the copier network port is green
Check the IP address of the priner is in the same domain as the computer. With subnet mask of 255.255.255.0 and a computer address of 192.168.1.1 the printer would need to be 192.168.1.X
Jul 07, 2009 | Canon imageRUNNER C3200 Copier
Instaling network printer from main computer
On the Vista computer, right click on printer, go to sharing tab, click on Additional Drivers button. On the next screen you need to select Windows XP.
This will ensure that whenever a print request is queued from any computer that runs on Windows XP, it will process the request on the Vista machine.
You should also try to ping the printer. You should also check if the computer is able to share files with Vista machine.
Apr 02, 2009 | Microsoft Windows XP Professional SP2 for...
Gestetner DSm645 Digital Imaging System Logo
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
