Digital Audio Labs CardDeluxe Sound Card Logo
Posted on May 29, 2010
CardDeluxe I develope audio recording program by using CardDeluxe Audio card. when Playing, simultanously I can't Record. help me.
Gigaware no sound
If you have audio cables from your source connected to the capture card, then your Recording device needs to be the Line In of the capture card.
If you connect the source to the Line In on the computer, then you use that as the default recording device. Until I set this, the default audio recording device was my microphone (not connected at the time). In Windows, you need the Manage Audio Devices Recording tab. (In Windows 7 and 8, it's under Control Panel > Hardware and Sound > Sound > Manage Audio Devices.)
If you are recording something playing on your computer, then the stereo mix option may work.
You should be able to use any video&audio software if the drivers are compatible. Thus the software you used for the video recording should work. (Stereo mix may be an exception - not all sound cards actually work when you try to record that content.)
I hope this helps.
2answers
What kind of sound editing would I use a multitrack recorder for?
Audacity is an all-in-one multitrack recording program. You can follow below steps to do that.
The interface of it is simple, which is very suitable for beginners to use. Its ability to record multitrack sounds excellently will satisfy you to the most. The following steps show you what you need to do.
1. First, you need to make sure you have set up the USB sound card on your computer properly and you can access stereo mix in the recording properties.
2. After that, you need to prepare the multiple audios that you want to create multitrack recording.
3. Then, you can fire up the Audacity application on your computer and then click on "Edit> Preferences> Devices" tab successively.
4. Select "Stereo Mix" as the device under "Recording" menu and then select the recording quality according to your demands.
5. Finally, you can hit on the "OK" button to begin to record the multitrack audio file. Remember to play the sound tracks on your computer at the same time to allow the software to record them simultaneously.
This USB sound recorder software is quite easy for you to handle. You can also use it to mix multiple tracks directly when necessary.
how-to-record-multitrack-with-usb-sound-card-using-audacity-6-jokjmiligbuppz0z4mo1uqvj-1-0.jpg For more details, check: How to Record Multitrack with USB Sound Card using Audacity
Where can i download a 1059 full version firmware?
Video Demo: http://www.youtube.com/watch?v=4Z8F4ip6Oy4
Want to save to your favorite songs, radio programs and audio from your Mac? Any audio or sound playing on your Mac such as: streaming music, online courses, lectures, radio programs, CD/DVD tracks, VoIP Calls, voice from microphones, etc.
AllMyMusic for Mac is designed to record any sound playing on your Mac to MP3 and M4A files without quality loss. Moreover, the program can detect muted sections and split audio tracks automatically.
* Record Streaming Audio from YouTube, Napster, Rhapsody, BBC, Pandora, Spotify...
* Record Songs from CD and DVD
* Record conversation from applications like Skype, MSN, etc.
* Record sound from microphones and other devices
* Automatically split tracks and filters out ads while recording
More Info: http://www.applemacvideoconverter.com/audio-recorder/
3helpful
2answers
Dont have audio device
Check device manager if the Audio device is detected.
Check Audio device has mark like this ! - i suggest uninstall / reinstall the audio device driver. download the driver from dellsupport.com drivers and download page.
If the audio device has ? mark it means that computer not able to recognize the audio hardware. if you are using audio onboard replace motherboard. if the audio has expansion card reseat the card then try again. if all fails then try a different audio card if passed then the audio card is faulty. if all fails using a different audio card it means the motherboard slot is faulty. replace mobo.
5answers
How i can recorde
Music or video ?????
If video you can install vlc player from here free:
http://www.videolan.org/vlc/
When installed click on show in the menu bar
and select advanced control now the player can record.
When click on the record button.
And it will create your video in your video map.
For music also for free you can install this recorder from here:
http://www.sound-recorder.biz/freesoundrecorder.html
Free Sound Recorder does exactly as it sounds -- it is an easy-to-use FREE software program that lets you record any sounds from your sound card and save the recording directly into MP3, WMA or WAV files.
Free Sound Recorder is a perfect audio recorder to record your own voice, music or any other sound by working directly with your sound card. It supports the record input/source from a microphone, streaming audio from the Internet, external input devices (e.g. CDs, LP, music cassettes, phone line etc.) as well as other applications like Winamp, Media Player, etc. With built-in advanced audio record engine, the recorder produces high quality recordings.
If you're looking for an application to help you for audio recording, you won't be disappointed in Free Sound Recorder! Main Features of Free Sound Recorder
bg_link_arrow.gif Allows you to record audio into MP3, WMA or WAV format directly.
bg_link_arrow.gif Allows you to pre-define audio recording qualities to help quickly set and manage recording parameters.
bg_link_arrow.gif Built-in advanced audio record engine to produce high quality recording.
bg_link_arrow.gif Allows you to preset/preview your audio recording device before starting record.
bg_link_arrow.gif Build-in WMA WAV MP3 decoder.
Hope this was helpfull
2answers
Recording vocals while the music tack is playing simultaniously
it's not supported on that or any earlier sony software that I know of. have you tried running the program twice (simultaniously) and playing on one while recording on the other then mixing the tracks together after??
4answers
Audio Recording Problems
try using the windows sound recorder to see if that records music? if it doesnt then you need to go into your sound recording properties and change it from mic to wave
3answers
M audio sound cards
I don't believe that is going to work, the reason being the operating system will only accept one input device recording at a time...meaning you cannot record with 2 cards simultaneously....the only way you MAY be able to pull this off is if you record with 2 separate programs , and make each program use a different input device....
Top Digital Audio Labs Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Digital Audio Labs Computer and Internet Expert? Answer questions, earn points and help others
