Question about Frigidaire FRS23H5AS Side by Side Refrigerator
Frigidaire FRS23H5AS side by side. condensor fan runs, no voltage to compressor
Noticed freezer defrosting, food thawing. condensor fan as well as the evaporator fan in the reezer but compressor is not running. checked voltage to compressor and none present. ohmed out compressor and what little knowledge I have I think it's ok. anywhere from 4 to 8 ohms. Is there a relay or defrost control somewhere that may be bad? where would it be located and how can I check it?
  • robert samples May 11, 2010
    its the black box you pulled off the compressor check there for voltage if none is there replace it
I replaced the control-defrost adaptive timer pc board after lighting storm and it worked fine for ten days then i turn off may power to my house to reground the house and my frig is doing the same thing fan not running evap freezing fan not running what is going on
Posted on Aug 22, 2008
SOURCE:
Code H1 on my frigidaire ffhs2622mwla refrigerator
HI is an error for freezer temperature detected as too warm... Look for frost on the back wall of freezer (defrost failure), or a failed evaporator fan (you should hear it running in the freezer compartment), if the food in the freezer is beginning to thaw, check the compressor to see if it is running. If the compressor is running, but the freezer isn't cold enough, and the evap fan is good with no frost build-up, you may have a sealed system leak (refrigerant charge is low). Frigidaires really suck in recent years and have lots of leak issues...
Jun 20, 2016 | Frigidaire Refrigerators
Why isnt my frigidaire side by side refrigerator cooling and compressor is working?
you need to put a set of gages on the unit and check the Freon amount
Jun 12, 2014 | Frigidaire Refrigerators
My ge refrigerator model pss26sgpa is not cooling in fridge or freezer
make sure the condensor fans are clean they are prob. full of dust. bottom rear of unit.
Apr 18, 2012 | GE PSS25NGM Side by Side Refrigerator
I have a sub zero 361rfd. The freezer portion is no longer cooling, however the fan still runs. Also, The refrigerator is set to the coolest temperature but I suspect it's not sufficiently cold....
Check the temperature setting Assure that there is enough room for air flow in the freezer or freezer Check for air flow restrictions in vents Test the temperature control Clean the condensor coils Check the door seals Test the door switch Test defrost heater Test defrost timer Test evaporator fan Check for a clogged drain tube Check for refrigerant leak Freezer is too cold
Check the temperature setting Test the temperature control Freezer is noisy
Hissing and popping is normal, it is the defrost heater. Check that the freezer is level Check the drain pan Check the condensor fan Check the evaporator fan Inspect the compressor mounts Freezer runs continuously
Defrost the freezer Clean the condensor coils Check the door seals Freezer starts and stops frequently
Clean the condensor coils Check the outlet voltage Test the condensor fan Test the compressor relay Test the overload protector Test the compressor motor Freezer does not defrost automatically
Test the defrost timer Test the defrost heater Test the defrost thermostat Freezer has an unpleasant odor
Remove spoiled food Clean freezer interior with a solution of h Clean freezer interior with a solution of hot water and baking soda Clean the door seals Remove breaker strips and check for wet insulation Water on floor outside of freezer
Check the drain pan If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve Water inside the freezer
Check for a clogged drain tube If you have an ice-maker, check freezer and ice-maker for level
Hoping that this will help to solve the problem....
Aug 18, 2011 | Refrigerators
Freezer not cold.
Test defrost heater
Test defrost timer
Test evaporator fan
Freezer is too cold
Freezer is noisy
Check the drain pan
Defrost the freezer
Remove spoiled food
Check the drain pan
Hope this will help in solving the problem.....
Oct 07, 2010 | Frigidaire Refrigerators
The freezer side is not keeping food frozen. Every three minutes I hear something turn on and it runs for about xx seconds. The model number is ASD2626HES. The refrigerator side seems fine.
Test defrost heater
Test defrost timer
Test evaporator fan
Freezer is too cold
Freezer is noisy
Check the drain pan
Defrost the freezer
Remove spoiled food
Check the drain pan
Hope this solved the problem, Take care....
Sep 19, 2010 | Amana ASD2626HE Stainless Steel Side by...
Maytag side by side issue: Refrig works normal. However the freezer defrosted itself, food is thawed. I'd like to repair myself, what's your recommendation i.e. troubleshoot, what to look for prior to...
Pull the refrig out , and remove the back panel . Is the compressor running ? Is it hot ? Is the fan cooling the compressor , running ? If the compressor is not running , the piece on the side , with 2 or 3 wires going to it , is bad . If the fan is not running , replace the fan motor . The part number for the compressor piece ( overload/relay kit ) is 12002784 . It is easily replaceable . If the compressor is running , check the square black coil box ( condensor coil ) , to make sure it is clean . Is clean , check the fan in the freezer , to make sure it is working .
Nov 22, 2009 | Maytag MSD2454G Side by Side Refrigerator
Frigidaire FRS23H5AS refrigerator - freezer not cold
Humming noise would be your compressor going bad. The noise from the fan is because they are over working to try and keep everything cool
Feb 12, 2009 | Frigidaire FRS23H5AS Side by Side...
Fresh Food & Freezer Warm
CHECK AND MAKE SURE YOU CAN HEAR YOUR EVAPORATOR FAN RUNNING (INSIDE MOTOR). IF IT IS NOT RUNNING ... AND YOUR COMPRESSOR IS RUNNING. THE MOTOR OR DEFROST TEMENATION SWICTH COULD BE DEFECTIVE. IF NOTHING IS RUNNING ... TRY TO LOCATE THE DEFROST TIMER(USUALLY LOCATED WHERE YOUR COLD CONTROLS ARE) YOU SHOULD SEE A SMALL HOLE WHERE YOU CAN MANUALLY TURN THE TIMER WITH A SCREW DRIVER.IT CAN ONLY TURN IN ONE DIRECTION. IF THE MOTOR IS RUNNING. CHECK TO SEE IF COMPRESSOR IN THE BACK IS RUNNING ... IF IT ISNT AND IS "HOT" (BE CAREFULL) SEE IF THE CONDENSER MOTOR NEAR THE COMPRESSOR IS RUNNING ... IF NOT ... THE COND. MOTOR IS BAD ... THAT MOTOR RUNS IF POWER IS GOING TO THE COMPRESSOR ALWAYS. IF COMPRESSOR IS HOT AND NOT RUNNING AND COND. FAN IS RUNNING .... UN PLUG FRIG AND WAIT TILL COMPRESSOR IS COOL TO THE TOUCH. THESE COMPRESSORS HAVE AN INTERNAL T-STAT THAT PROTECTS THE COMPRESSOR IF IT SHORT CYCLES.IT SOMETIMES GETS SO HOT IT DOES TAKE HOURS TO COOL OFF. THERE IS ALSO A DEFROST-TERMINATION SWITCH THAT CAN GO BAD. CONSULT A LICSESED FACTORY CERTIFIED COMPANY TO GIVE YOU A FIXED-PRICE DIAGNOSTIC TEST.
Apr 24, 2007 | Frigidaire FRS23R4A Side by Side...
Frigidaire FRS23H5AS Side by Side Refrigerator Logo
293 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
Thomas F. Schneider
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
