Question about Samsung HCL4715W 47" Rear Projection Television
I have a buzzing noise from inside the TV
I have a buzzing noise from inside my samsung rear projection TV
    President:
  • 1,961 Answers
Immediately check your plyback connectors and wirings.there is a leak in your high voltage and this is dangerous so be carefull..to locate the leak,open the back cover of your tv enough to see the inside components...specially the plyback transformer..power on the tv and look for the arking of the high voltage.it is like a lightning strong light that produces the buzzing sound..once you see the source of the leak..power of the the tv.use a silicon adhesives (silicon gel) a silicon that is use by the glass intallers to bond the mirrors use on the display show room..apply the silicon on the leak area .apply a large amount of it to be sure there is no leak...once it is bonded you can power the tv right away...to check whether the leak is cured...
good luck hope this helps you..
please rate my help tnx.
Posted on May 29, 2010
I have a SAMSUNG HLP5674W and it has begun to make a Loud buzzing/humming noise from the rear of the tv... It sort of sounds like a fan and when i listen closely, that area is exactly where the noise is...
pull the light assembly out clean it with a vacuum and some pressurized air spray and place it back in the TV, while it is out check the fans on either the inside or in the removable assembly for damage or other interference in operation...If this doent help dissemble/remove the rear of the enclosure ( 6-10 screws) and clean the insides carefully and then turn the tv on - being careful not to be touching ANYthing and see if you locate the culprit.....
Oct 24, 2013 | Samsung HCM5525W 55" Rear Projection...
Hl-r4667w/hl Bought the tv 2005 and just started a buzzing noise
Buzzing noise on that model is usually caused by a fan or the color wheel.
May 18, 2012 | Samsung HL-R4667W Rear Projection...
I have a Samsung HLN617w that has an awful buzzing noise that seems to be continuous and maybe from the lamp fan. Any suggestions on a fix?
This tv have a colors wheel is dying and worn out.The sound u hear buzzing,squiling or lound motor noises.The colors wheel require changing,because it dying and spinning off of it motor axis.Hire a tv Tech. to change the colors wheel,because it sit way inside near the Light Projection Engine it self,require take out many machanical parts even can come to the colors wheel itself to change it.
Nov 28, 2010 | Samsung HLN617W 61" Rear Projection HDTV
Loud buzzing noise
sounds like a color wheel problem, I can send you a DIY File with pictures if you wish. Contact me at techman32K@ yahoo.com. Good Luck!!
techman
Sep 05, 2009 | Samsung HCM5525W 55" Rear Projection...
Samsung 4663w rear projection tv loud buzzing
Hai,
Buzzing can be caused by a bad ballast, colorwheel, or cooling fan... Nothing else makes a noise, unless it's comming from you speaker.
Hope it Helped U!
Aug 04, 2009 | Samsung Televison & Video
Poor picture quality and loud buzzing noise
Sounds like your color wheel is failing they make a loud sqeauling noise when they begin to fail.Run you somewhere around $300-400 to have a tech repair it.
http://the-tv-dude.blogspot.com
May 03, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Buzzing noise
COLOR WHEEL OR COOLING FANS
Mar 28, 2009 | Samsung HLN507 50" Rear Projection...
Loud buzzing noise
sounds like the color wheel needs to be replaced very easy repair on that model Samsung.
Jul 05, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung LE26R74BD plasma sreen tv sound problem
To Fix.. The Buzz.. The noise comming from one of the Board Inside. Open it and see..Or call a tech..
RezaKhan
Apr 13, 2008 | Sony KP-57WV600 57" Rear Projection...
Samsung HCL4715W 47" Rear Projection Television Logo
113 people viewed this question
Henry  Thomas
Henry Thomas
