Question about HP Creative Sound Blaster Audigy 5.1
Speackers do not have sound from the plug in in back of computer. I have sound when I plug in to the front of computer.
  • Anonymous Apr 21, 2008
    compaq presario -c 300 tu intel core solo sound driver
  • Jakloi Apr 21, 2008
    When I connect the headphone, I still heat the sound comes out of the laptop speakers. As usual when we plug the headphone the speaker mutes automatically but I dont know what happend. Could you plz show me how to solve this?
    My laptop is Compaqnc6000
Telecharge les pilote de la carte son hsp56
Posted on May 03, 2008
Kinyo bluetooth speackers wont work
The drivers may not be established for the device mentioned. Or you may not have a Bluetooth communication device for the computer. The speakers have a BT receiver, and require a BT transmitter plugged into your source device (Computer, Radio, etc.).
Jan 12, 2014 | Audio Players & Recorders
I have a sound problem with my montgomery ward sentry sound bar , when its connected to to my tv and work great then i unpluged it moved it put back together its doesn't have sound?
Could be an internal effected by disconnecting when the sound bar when the power was still on. Always remove or connect speakers or other electronic devices at power-down (not active) as transient current can damage sensitive electronics. Check you wires, cables, and in/out ports for defects or dirty posts, etc. Perhaps the dog or cat chewed on the lines....never know.
Jan 10, 2014 | Montgomery Ward Sentry Sound Bar
I get sound from the 2nd speaker (the one without controls) but not from the 1st speaker (the one with the controls). I've tried jiggling the plug into my laptop and this has worked in the past, but now it...
theres short ether on the end of on of your speackers on dead on or the front were base of the wire is jiggle wile playing music find out were dead link is splice reatatch elec. tape it.
Feb 13, 2011 | Cyber Acoustics CA2002 2 Speakers
My polk computer speackers came from another computer. N279 and 000MA3A5-0 are on the bottom. With the volume at 100% I can hear a faint sound on one speaker. My computer (Dell W/Vista does not have a...
These are what is called line powered speakers. Some sound cards have the power to amplify the sound enough to be heard plainly, and others do not. Try adjusting the volume from the computer. If that does not work and the speakers are plugged in to the green port on the sound card, I would recommend replacing the speakers with amplified (powered) ones.
Aug 22, 2009 | Audio Players & Recorders
Same HP/pavilian speackers and low soung from gx280
save your polks,go to the nearest truck stop store and purchase a set of little loud mouths their called,i guanantee you will hear those.
Jun 15, 2009 | Dell OptiPlex GX280 PC Desktop
I cant get any sound
check you dirver is install you computer proparly and mute option is check after not solve the problem change the sound card .............ok
more info www.compudesk.in
Mar 26, 2009 | Audio Players & Recorders
How do i wire 6x9 from the back shelf to the head unit using new wire where do i wire it on the head unit?
if you are going to place the speackers into the rear shelf than you can run your wires along the underside of the shelf,then towards the back of the rear seat, then run it down the length of the seat, when you reach the bottom you will need to try to pry the backrest portion seat foward just enought to get the wire thru to the front, then you will need to get either a phillip or slotted screwdriver, open the back door and at the bottom unscrew the trim from the bottom of the door way,run wire thru do the same with the front door, then run wire behind the trim around or near where the emergency release handle is at, run wire behind instrument panel towared your deck. when you go to wiring up the deck and speakers check on the deck to see if it has a wiring diagram on it if not: most decks come as follows ( white wires front right ,blue or purple rearl left, brown front left, grey rear right red is + black is - yellow is constant +( always on so your deck is able to stay programedwith your presets and audio settings and clock)one single blue or purple wire is the remote for your ampif the colors dont match the ones on your deck then hook up your deck to the power only when the deck comes on go ahead and set your speackers to only the rear right speacker and take your wires from your speacker and touch them to the wires on the back of the deck, once you hear the audio coming thru go ahead and mark this as right rear or rr then using the same speaker change the settings to rear left speacker and do the same as with the other one mark it rl and do same for front speackers
Feb 28, 2009 | Pioneer TS-A6962R Car Speaker
Need help no sound out of speackers
Presume you mean 790 not 970, if so you can download a manual under product detail on this page.
http://www.amazon.com/Boston-Acoustics-BA790-Multimedia-Computer/dp/B00005AR7N
Check power supply is plugged in correctly and switched on at the socket, then turn or push the button usually on the right speaker to turn it on,
good luck HPC
Sep 27, 2008 | Boston Acoustics BA790 Computer Speakers
Speacker problems
cheak sound card settinsg for 4 ch 5.1 output or in audio main menu ok
Feb 01, 2008 | Logitech X-530 Computer Speakers
Hook up old speckers to a dell pc
DOES IT HAVE MINI STERIO JACK OR PLUG INTO OUTPUT OF SOUND CARD
Jan 22, 2008 | Audio Players & Recorders
HP Creative Sound Blaster Audigy 5.1 Logo
154 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
