Question about Fisher DD603B / DD603W / DD603H Dishwasher
Top dishwasher drawer will not close - Fisher DD603B / DD603W / DD603H Dishwasher
  • 36 Answers
There are lid motors on both sides of the drawers that are very common to go bad. I would get the tech sheet thats located on the filter board on the bottom back under the bottom drawer and read how to put the unit in diagonstic mode to test the lid motors.
Posted on Jun 15, 2010
  • 159 Answers
As long as there is no plates or anything stopping it from closeing i will then say that there are 2 side rails that the draw glides in & out on,get down on the floor & check up underneath the draw for smooth gliding operation.also is it possible that a fork or peice of cutlery has gotten over the top & fallen down jambing the draw from closing.
Posted on May 29, 2010
Kitchen Aid KUDD03DT top drawer won't stay closed
The lock lever on the unit --- that is shaped like a U --- if you have it ---may be bent a little. You can move it to the correct position - usually down a little --and your door will stay closed
Mar 04, 2014 | KitchenAid 24" Double-Drawer Dishwasher...
Dishwasher beeps but won't run
There could be several reasons for the beeping. The dishwasher checks for sensor to make sure it is in good health before it starts. Most likely the drawer close sensor is detecting fault. This is to ensure the drawer is closed fully to avoid water leaks when dishwasher is on. Sometimes sensor itself has failed and has nothing to do with position of drawer. Open top cover carefully to make sure the drawer is travelling ok on the rails. TAKE MAINS POWER CABLE OUT BEFORE WORKING ON DISHWASHER.
Mar 17, 2013 | Fisher and Paykel DD24DCTB6 Builtin...
Top drawer won't close
After completing a cycle the top drawer feels like it will not open or the top of the drawer has fallen down. I've since forced it open but, now it feels like it will not close. I did not force it to close. How do I remedy this problem?
Mar 02, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Top drawer of my 8yr old fisher paykel dishwasher got stuck opening and now cant get it back in , botom drawer works but no power to top drawer can it be fixed ?
Not sure if your dishwasher problem has been fixed yet.
The lid seal actuator motors on the top drawer are stuck due to lack of power and therefore you cannot close the drawer. Don't try to force it in as this will cause damage.
First thing to do is to restore power to the drawer. The power comes from the filter board sitting at the base of the dishwasher. You will have to disconnect power to the dishwasher and get both the drawers out. This will give you access to the power filter board.
Refer item 15 in this diagram. It is likely the board is faulty and it supplies the lid seal actuator motor power to both drawers. (separate connections).
You have to take the front cover of each drawer out to remove the drawers from the rails. But be careful not to damage the cable and hose when pulling out. Keep a chair or something next to dishwasher to hold the top drawer.
Once you fix the filter board and restore power to actuator motors, push the lid seal up by hand to make sure it does not block the lid.
Hope this fixes the problem.
Oct 24, 2011 | Fisher and Paykel 23 in. DD-603 Built-in...
The top drawer won't stay closed. Keeps opening just by barely touching it. It will run as long as you hold it closed.
There are few possibilities
1. the dishwasher is not sitting correctly on the floor mountings. Could be a slight lean forward. Secure dishwasher per instructions.
2. the drawer has slightly come off the rails. Need to take it front cover off (remove pin on each side) and re-adjust.
3. the drawer seal is not sitting properly. Take the drawer out and check seal on top edge of the housing from inside
Please post a comment to confirm if the solution was helpful
Aug 31, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Top drawer obstruction, can not close.
Pull out the drawer.at the bottom near the front panel at both sides, press the square tabs in and pull the drawer further. When you have the clearance from the edge of the drawer, lift it up out of the rails then put it down to floor. It may not be the hose. I think the top lid seal is sagging down causing the resistance. If this is a case, you need to replaces both actuators to lift up and down the lid to overcome this problem.
Good luck.
Apr 24, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Top drawer seems to off track, tough to close, etc
check to see if wheel rollers are broken . Or off track . Then if off track allign it .
Aug 18, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
The top drawer of my Fisher Paykel two drawer dishwasher will not close all the way. Something appears to be stopping it. How do I fix it?
To find out what might be blocking it, you can remove the drawer. There are two tabs one on each side of the drawer near the bottom front. Push those in and pull the drawer out. You can lift the drawer up and push the slides in to get them out of the way. Then you should be able to see into the cabinet and what if anything is stuck behind the drawer
Apr 22, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
The top drawer intermitantly makes the drawer opening noise
On the right side, near the top. there are two light pipes on the drawer. One sends an infrared beam of light to a reflective area on the cabinet, the other receives this light. Wipe these areas with a clean dry cloth.
May 31, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Open Questions:
Fisher DD603B / DD603W / DD603H Dishwasher Logo
129 people viewed this question
Top Fisher Dishwashers Experts
Tony Houde
Tony Houde
Alan Matzke
NOEL
NOEL
Are you a Fisher Dishwasher Expert? Answer questions, earn points and help others
