Question about Brady 1344 Thermal Label Printer
Dose not print
I'm useing excel to print lables but each time I try to print I get a Fault led
  • 242 Answers
All you need to do is to remove the drivers of the printers and reboot the computer.
Re-install the drivers with the CD that came in with drivers and again give a reboot to the computer.
Thats All.
Thanks
Jimmy
Posted on May 29, 2010
How do I align my Citizen CLP 7202e Lable printer print head to align with the lables? Currently it starts printing low on the lable and thus the last 1-2 lines print over onto the next lable
Adjust vertical offset in printer properties. If that doesn't fix it, adjust it under "advanced". Or... you can set the offset in the printer itself. Hold down the left two buttons at the same time. Cycle through the settings until you get to vertical offset.
Apr 19, 2015 | Citizen CLP-7202e Thermal Printer
In my application,i want to print the barcode generated from the application.i am using TTP 244 plus printer for printing the generated Barcode.but printer skips two lables and print the generated bar
Please verify the following:
- Driver: If you are using the standard printer driver, maybe you want to try another driver(Download an excellent driver at www.nicelabel.cl, searching by your brand and model name).
When installed, you should go to advanced settings and use the callibrate options.
- Software: Maybe your software has a configuration and the driver has another, set the same length for both and verify if the problem persists.
- Sensor: If the sensor has an issue, then you should try contacting a local reseller or partner for zebra. If that's the case, you probably will have to repair the printer($) or definitively replace it for another($$). Since it's a desktop printer, check your warranty first and maybe you are covered.
Jan 16, 2015 | Zebra GK420t thermal transfer and thermal...
Tricity bendix aw1001w has an unknown error code, the led labled end flashing 3 times, any ideas?
It could be one of the E30 codes which would relate to the pressure switch or an earth fault on the heating element there could be a wiring fault or p.c.b. fault check wires off heater at bottom rear of machine,remove back plate 4 screws.Hope this helps.
Good Luck.
May 07, 2010 | Tricity Bendix AW1200 Front Load Washer
Dell 922 printer will not print on the lines of lables
My dell photo aio 922 says there a communication problem and i try to print i do everything it tells me to do for exaple recconect the usb restart computer and try and take the printer plug out but still i am haveing the same problem
Dec 08, 2008 | Dell 922 All-In-One InkJet Printer
How to generate csv and data file
Archivos CSV son archivos de datos creados en Excel para campos variables que se pueden utilizar en cxwizard. Archivos JOB son archivos de texto que son utilizados para hacer una impresion automatica de etiquetas. CSV files are data files created in Excel for variable fields that can be used in cxwizard. JOB files are text files that are used to make an automatic printing of labels.
Dec 05, 2008 | SATO CX400 Thermal Label Printer
Printing not centered
Check the width of the label format.
Normally this printer will center the printing automatically when it receives the instruction to change the coordinates
Sep 04, 2008 | Zebra LP 2844 Thermal Printer
Will not print on all four lables, and does not print in the same place each time.
for starters you need to calibrate your printer.
Note: If printing in Direct Thermal Mode, default the printer first (4 flashes).
1. Load the labels and ribbon (if used) and close the printer
2. Turn on the printer power.
3. Allow the printer to feed or error out.
4. Press and hold the feed button until the green status LED flashes once, then twice. Release the feed button.
6. The printer will set the media sensor for the label backing being used and then automatically feed until a label is positioned at the printhead.
7. A profile of the media sensor settings (similar to the example in Figure 1) will print. Upon completion, the printer will save the new settings in memory and the printer is ready for normal operation.
8. Press the feed button. One entire blank label will feed. If this does not happen, try defaulting (Hold the FEED button until it flashes 4 times)
Jun 23, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Set up
May be your problems can be solved doing a calibration. To do this, turn off the printer, press the feed key and turn on the printer. When the led flashes in red quickly release the feed key, the printer will start to calibrate and after the calibration will feed one label.
It is explained in the user manual.
Mar 17, 2008 | Toshiba B-SV4D Label Printer
Printing to memorex cd lable paper
the paper feeder cant grip the back side of the paper. It slip through the feeder and the positioning led control cant adjust the correct positioning for printing!
Try another brand of paper!
Jan 18, 2008 | Brother MultiFunction Center MFC-440CN...
Brady 1344 Thermal Label Printer Logo
140 people viewed this question
Top Brady Office Equipment & Supplies Experts
pkwc
Bob Rambo
Level 1 Expert
The Vanguardian
The Vanguardian
Are you a Brady Office Equipment and Supply Expert? Answer questions, earn points and help others
