You can't "reset" a laptop. You can REISTALL windows but you'll lose all your data and installed aplications.
Now, be specific: WHICH passwoed did your forger:
- The BIOS password, one that appears as soon as you turn on your computer, before Windows starts up
- The password to some Solid Stae Drive
or
- the password to start Wndows
If you forgot your SSD password, your are done. No way to retrive that password.. Gues manufacturer has a "bacdoor" way to reinitialize them so you should go to store where you bought your computer
Bios password can be reset if you do a factory reset to BIOS, removing cmos battery and wait some time till cmos discharges.
If you haven't dont this before, don't do it. Call someone who has experience, you may end with more problems then you have currently
To resete Windows password, depends on your Window version. Some returen from google search; you can specify better and get a better return
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile. send the IMEI no to me and i will reply you with unlocking code. IF Problem not Solved So Please New Software install in the Phone Problem will Solved
Hi, -
To unlock you Nokia X3 (if forgot or lost lock code) you can unlock
it using a master code. - To get the master code i need the IMEI code of
your mobile phone. - With the help of this IMEI code we can get the master code of your mobile and unlock the mobile and reset it with a new password. - The IMEI number can usually be found on the sticker underneath the battery or by typing *#06# into the phone keypad.
Hope this helps, please rate and leave a comment if the solution was helpful, thanks!
To Unlock the Mobile Phones from the Security or Password lock You can use the Security Unlock code or Master Reset Code,You can get the Master Reset Code code at reliable cost at http://www.mobile-unlocker.com/unlocking-services/rs2wp6/6/ and Unlock it safe and secure. You check Code for Your Mobile , MODEL..... ...
