Question about Dryers
Maytag Dryer DE713 - Timer works, Tumbles all cycles but does not heat.
    Novelist:
  • 184 Answers
CHECK FOR 240VOLTS AT THE OUTLET. A DRYER WILL RUN ON HALF THE 240 VOLT CIRCUIT BUT WON'T HEAT.
IF THE VOLTAGE IS THERE, CHECK FOR 240 VOLTS AT THE HEATER. IF IT IS THERE AT THE TERMINALS OF THE HEATER, AND THERE IS NO HEAT, THE HEATER IS BAD.
IF NO VOLTAGE IS PRESENT, TRACE BACKWARDS THROUGH THE HEAT CIRCUIT AND CHECK EACH COMPONENT IN THAT CIRCUIT. IF ONE OF THEM HAS 240 VOLTS PRESENT, THAT IS THE BAD COMPONENT.
POSSIBILITIES ARE, HIGH LIMIT THERMOSTAT, CYCLING THERMOSTAT, THERMAL FUSE, MOTOR CENTRIFUGAL SWITCH, HEAT SELECTOR SWITCH, TIMER. POWER CORD.
Posted on Apr 08, 2008
SOURCE:
Maytag Gas Neptune Dryer MDG5500AWW no heat
see this causes and fix it. God bless you
Dryer tumbles, but there is no heat
Sep 27, 2012 | Maytag Neptune MDE5500AY Electric Dryer
Maytag lsg7806aa not stopping
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Oct 25, 2008 | Dryers
Maytag performa dryer model-pdet920ayw will not heat. drum tumbles and timer works
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 20, 2010 | Dryers
I have the Maytag MCG8000AWW gas "drying center", it tumbles but does not have any heat. The burner lights when the cycle is started, and for a few minutes it does heat. Then the humidity indicator changes...
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer not Working Gas Dryer Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 06, 2010 | Maytag Neptune MCG8000AW Gas Dryer
My dryer works ...tumbles ...heat works...timer stay where you put it when you start it..maytag dependable care plus dryer
Your timer motor is bad. It is very similar to a clock motor and it drives the timer on your dryer.
Oct 08, 2009 | Maytag Dryers
MAYTAG DE713 dryer Voltage Option
Yes, the 120 -240 is the range in which your dryer can operate. Many times the standard for Europe is 230 and the 240 allows for power surges that are common.
Aug 30, 2009 | Dryers
Element heats, dryer tumbles, no heat in drum, never shuts off
Hi, If the dryer heats but will not advance in either time or auto cycles, you need to change the timer.
You can test to see if the timer is getting voltage. Remove the top rear panel and locate the two wires going to the timer motor. There should be 120V when the dryer is running in time dry.
Please let me know if this helps or if I can assist you further.
Thanks
Vic
May 27, 2009 | Whirlpool LER5636P Electric Dryer
Dryer tumbles but not heat
here is the link for the wiring diagram... heat is definatly on a separate circuit.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5174194
May 25, 2009 | Maytag MDE308DAYW Electric Dryer
Dryer won't heat--element replaced; tumbles fine
Before you purchase any more parts, you should have use of a multi meter. If the dryer is not heating at all, and of the following parts could be bad.......Operating (cycling) thermostat, high limit thermostat, thermal fuse, timer, or motor centrifugal switch. All but the motor switch can be easily checked with the dryer UNPLUGGED using the ohms feature of the meter.
May 03, 2009 | Dryers
Will not heat up
DE713 is an electric Dryer
Feb 11, 2008 | Maytag Neptune MDG9700A Gas Dryer
Dryers Logo
134 people viewed this question
Top Dryers Experts
Marvin
Marvin
paul
paul
