Question about Canon PIXMA iP3000 InkJet Photo Printer
Had paper jam. removed paper, now getting 11 flashes, but cannot clear error as per manual instructions. getting service error 6A00.
  • ajkl Jun 17, 2008
    Canon MP750 6A00 error - solved by nudging purge plate back into position
  • 10 Answers
I have the Canon Pixma iP4000R printer. I had an error code of 6A00 and my power light was blinking/flashing green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange (12 oranges).
I tried the “waste ink counter reset reset” procedure: Power on while holding the stop/reset button and pushing the service button twice, then pushing the stop/rest button 4 times to clear the error, but that didn’t work.
My ink cartridge carrier wasn't moving-staying in the center. I thought I had a paper jam.
I looked at a few blogs about my error on other Canon Pixma models and they kept talking about “sponges”.
The following is what I discovered that cleared my error and now my printer is back to printing!
The “sponges” are 2 hard pieces of absorbing plastic or something of the like. I was looking for a softer material like the long thin gray foam strip material in my printer. The 2 "sponges" on my Pixma iP4000R were next to each other-one was rectangular and one was square-like. Originally they were white but the ink made them black/navy.
The "sponges" are located on the right under where the ink cartridge carrier "rests".
I didn't see the sponges at first, as there was a white backwards “L” shaped plastic piece that had a spring attached to it(purge unit). The “L” shaped piece was moved forward out of its place. I used my pen tip and pushed that piece back and found that the rectangular "sponge" had popped out of its place.
I used a pen tip popped both “sponges” out and rinsed them with water and voila they were once again white. I think the rectangular one had so much ink on it it popped itself out of place.
My error is gone and I can print again!
Posted on Dec 30, 2008
I had the same problem on my IP3000, i took out the bottom paper tray and there was the tiniest bit of paper (a corner must have got torn off and found it's way in to my paper) just under the bottom most roller.
I'm surprised at how sensitive the printer is, so when you think paper jam, doesnt necessarily mean a full paper.
Posted on Aug 17, 2008
  • 123 Answers
The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.
When the paper jammed, did you pull the paper out?
A tiny bit of paper could have ripped of and might still be inside. If so, open it up and get it out.
The other reason is that your purge unit could have moved.
The purge unit is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. While wearing gloves, gentlely rock the purge unit back and forth. Close everything up and then try restarting the printer.
Hope this helps. Good Luck.
Posted on Apr 08, 2008
PIXMA MP780 All-In-One InkJet Printer: Getting Printer Error 6A00 light on pinter flashin...
Hi
Error 6A00
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
May 07, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Printer stopped working. I just added new ink supply. Alarm light flashes. Printer status says "service error 6A00"--"check printer" "cancel printing and press the ok button." None of this works. And I...
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Apr 05, 2010 | Canon PIXMA MP780 All-In-One InkJet...
MP830 Error 6A00 Error Code Alarm Flashing and Copy button Flashing. Does not respond to unplugging or turning off and back on.
6A00 means the purge assembly is jammed. That's the unit that cleans the printhead. Sometimes it will last a while when cleaned, but I just replace them.
QM2-3032-000 about $20.00 but much easier at a shop.
Oct 01, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Alarm continues to flash no jams, cords are where
6A00 means the purge assembly is jammed. Look inside to the right where the printhead rests when turned off. Remove any paper scraps. Otherwise you need a new purge unit
QM2-3032-020 around $30 for the part.
Jul 02, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Service error 6A00
It looks like the print carriage was stuck. Turn on off the printer, manually move the ink cartridge back and forth a few times, look underneath for dirt or small piece of paper (usually happens when you have jammed paper) or use a blower to clean any foreign objects.
Apr 27, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
The error message "Service Error 6A00" and cannot fix it. HELP!
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Apr 02, 2009 | Canon PIXMA MP750 All-In-One InkJet...
Error code 6A00
Hi
Try this out
Solution 1:
Solution 2:
Solution 3:
Mar 01, 2009 | Canon Pixma MP500 All-In-One InkJet...
Service error 6A00
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Mar 01, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Please problem solve
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Jun 11, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Error 6A00
Solution 1:
Solution 2:
Solution 3:
May 30, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon PIXMA iP3000 InkJet Photo Printer Logo
416 people viewed this question
old marine
old marine
