Question about HP Photosmart 3210 Printer
Hållaren har fastnat - HP photosmart 3210 all-in-one
Får feltext "Hållaren har fastnat. öppen luckan, åtgärda problemet och tryck på OK."
Hållaren, vad är det? Hur gör jag?
SOURCE: out of paper:
I have the same problem. HP support suggested calibrating the media sensor. Here are the steps they provided to me. It didn't work for me, but it may work for you. 1. Press Left arrow and Right arrow simultaneously on the front panel of All-in-One. 2. Press 3,2,9 on the front panel of All-in-One. 3. Press Left Arrow. 4. Press Ok. 5. Press Left arrow. 6. Press Ok.
Posted on Oct 08, 2007
  • 136 Answers
SOURCE: hp photosmart 3210 vista drivers
just click the link below and enter the approtiate model number of ur printer and download drivers.
www.lostmydrivers.com
thanks.
Posted on Oct 13, 2008
Joed911
  • 4338 Answers
SOURCE: Error Message OXc05d2381 on HP Photosmart 3210
Reset the product:
  1. Without turning off the product, disconnect the USB cable from the rear of the product. NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ).
  2. Remove the cartridges from the product.
  3. Wait for the ' Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 05, 2009
SOURCE: HP Photosmart 3210 Printer will not scan any
I had the same problem and this is what I did to fix it.
Go to control panel
choose printers
look to left and find scanners and cameras
click scanner
a pop up should direct you to scanning options and will lead your scanner to scan the item
hope this helps
Posted on May 11, 2009
  • 10406 Answers
SOURCE: Har en nyköpt ML-1640 som använts vid ca
>> Have a his newly bought ML-1640 used for about 50 prints. >> The problem is that suddenly stuck a paper written nearly finished, >> and the red light began to shine. >> The red light Must visa green normally. >> Tips on what the error is desired. A part of a piece of paper is jammed somewhere along the "path" that the paper must travel. Take the printer to a certified technician, and have them repair it. Perhaps, the "warranty" will pay for the repairs, or will provide a replacement ???
Posted on Sep 15, 2009
ATI Rage 128 Pro 32MB ultra GL AGP waar kan ik een driver vinden voor windows 7
http://download.cnet.com/32mb-ati-rage-128/3000-2108_4-63707.htm
lOm paketet inte r?tt http://download.cnet.com/2000-20_4.html p? hemsidan b?r du se en fliken S?k bara in vad du letar efter (att vara exakt) som du kanske m?ste prova en n?gra g?nger f?r att f? det r?tt
Oct 20, 2011 | Ultra ATI Rage 128 Pro Graphic Card
Reparar mi paint drive kinston
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
hope this helps you
Klicka p? Start Kontrollpanelen administrive datorverktyg Management h?rddisk h?gerklicka p? enheten v?lj Egenskaper Klicka p? verktyg du b?r se p? Kontrollera nu Klicka p? Start tv? boxar automatiskt ?tg?rda filer och s?ka efter och f?rs?k att reparera skadade sektorer plats sedan ett kryss i b?da rutorna och v?lj sedan kontrollera nu b?rjar eller s? kan du kryssa i en ruta att sedan ?terv?nda efter avslutade den f?rsta reparationen sedan ?terv?nda och markera den andra rutan ska du inte g?ra n?got medan chkdsk p?g?r n?gon ing?ng kan skada den h?r enheten
Jag tyckte att du f?r b?st resultat genom att kryssa i en ruta sedan ?terv?nder efter att det har slutat sedan markera den andra rutan
hoppas att detta hj?lper dig
Sep 18, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Nao roda o dvd..
Klicka p? Start p? panelen Verktyg administrive, Datorhantering Enhetshanteraren scrolla ner CD-DVD ROM-enheter du kan se ett gult fr?getecken? h?gerklick kommer du att ha m?jligheter att uppdatera drivrutin ?terst?ll tidigare drivrutin, eller v?lj egenskaper Allm?nna fels?ka, v?lj f?raren klicka f?r att installera om drivrutinerna p? Uppdatera drivrutin eller avinstallera sedan installera om detta inte l?ser problemet kan det vara ett problem i registret om du inte kan se din h?rddisk i Utforskaren
St?ng alla ?ppna program
Klicka p? Start, K?r och skriv regedit och tryck p? Enter
Klicka p? plustecknet (+) bredvid f?ljande mappar
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Kontroll
Klass
{4D36E965-E325-11CE-BFC1-08002BE10318}
Denna mapp ?r DVD / CD-ROM-enhet Klass Beskrivning i registret. Leta efter n?got av f?ljande namn i den h?gra kolumnen.
?vre Filter
L?gre Filter
?vre Filters.bak
L?gre Filters.bak
Om n?gon av ovanst?ende knappar som visas i steg 4 visas, h?gerklicka p? dem och v?lj Ta bort
Efter bort nycklarna, st?ng Registereditorn
Starta om datorn
?ppna Den h?r datorn och kontrollera om din cd-eller dvd-enheter har ?terv?nt. Du kanske ocks? vill ?ppna Enhetshanteraren och kontrollera att den gula utropstecken och felkod p? CD eller DVD-enheten ?r borta. eller
du kanske m?ste fysiskt koppla ur leder till denna CD / DVD sedan in dem igen detta b?r aktivera guiden Ny maskinvara eller
kanske du m?ste avinstallera starta om datorn installera din DVD / CD sedan installera om drivrutinen f?r denna enhet
Om datorn levererades med ett moderkort disk drivrutinerna kan vara p? det
Klicka p? Start Kontrollpanelen administrive verktyg Datorhantering Enhetshanteraren scrolla ner cd DVDROM enheter om du ser ett gult fr?getecken eller utropstecken? ! eller ett r?tt X h?gerklicka m?ste du uppdatera drivrutinen eller
v?lj Egenskaper allm?n fels?kning, v?lj f?raren klicka f?r att installera om drivrutinerna p? Uppdatera drivrutin
Sep 09, 2011 | LG GSA-4160B DVD±RW Burner
Hej jag har prolim med lexmark cover open
Det kan vara patronerna i bärselen. öppna skrivarens lucka och ta bort bläckpatronerna. Kontrollera cylinderampullen område för några hinder i bärselen vägen. Om inga, stäng locket. Koppla ur och tag bort skrivaren till strömkällan att återställa sig själv. När skrivaren slås , sätt tillbaka bläckpatronerna och kontrollera att de sitter i rätt och säkrade. Stäng locket. Försök skriva ut igen.
May 04, 2011 | Lexmark X3480 All-In-One Printer
Kan inte instalera skrivaren Lexmark E232 till min dator, Fujitsu Simens. Finner inget installationsprogram att ladda ner.
Du f?r tillg?ngsupport.lexmark.com webbplats f?r att ladda ner och installeraskrivardrivrutiner. Kontrollera att du valt r?tt filter f?r dittoperativsystem, n?r du installerar drivrutinen, dubbelkolla anslutningen mellandatorn och skrivaren. P? skrivare och fax kontrollera att r?tt skrivare ?r valdsom r?tt standardskrivare. F?r ytterligare hj?lp,kontakta Lexmarks tekniska support.
Jan 20, 2011 | Lexmark E232 Laser Printer
Hur gör jag för att skydda min router genom att ha ett lösenord????
TR?DL?S TRYGGHET FR?GOR
Steg 1: Anslut router - Computer (Wired)
Steg 2: ?ppna Router Setup genom att skriva http://192.168.2.1 i adressf?ltet i Internet Explorer
Steg 3: P? v?nster under tr?dl?sa Klicka p? Wi - Fi Protected Setup
Steg 4: L?mna l?senordsf?ltet tomt och klicka p? skicka
Steg 5: Inaktivera det och klicka p? Verkst?ll f?r?ndringar
Steg 6: P? v?nster under tr?dl?sa klicka p? S?kerhet
Steg 7: Aktivera 64 bitars WEP
Steg 8: Skriv ett 10-siffrigt nummer p? nyckeln 1 (2 i varje kartong)
Steg 9: Klicka p? Utf?r ?ndringar
Steg 10: till v?nster under tr?dl?s klicka Kanal och SSID
Steg 11: ?ndra den tr?dl?sa kanalen till 6
Steg 12: ?ndra SSID till ett annat namn (utan mellanslag)
Steg 13: Klicka p? Verkst?ll ?ndringar
Steg 14: Nu Scan och ansluta till detta n?tverk (tr?dl?st)
L?t mig veta om det fungerar
Oct 19, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Tvättmaskin stannar mitt i tvättning med felkod C9 och lamporna för "Förtvätt" och "Skjölning" blinkar. Har ni några förslag? The washing machine stopped mid-wash...
Change motor brushes and reset by doing the following
press first 2 buttons 1 & 2 keep it pressed and turn program switch 1 click to the left (against the click)
all LED’s lights up.
realise the buttons
turn progam switch to off
Only do the above after replacing the brushes and still doesnt work
Oct 25, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Har en nyköpt ML-1640 som använts vid ca 50 utskrifter. Problemet är, Att Plötsligt fastnade Ett papper Nästan färdigskrivit och den röda Lampan började lysa.Den...
Sep 15, 2009 | Samsung ML-1640 Monochrome Laser Printer
Pentax istd autofocus actuator stopped working repare advice ? where to get parts ?
Hej!
Jag kör Windows vista opertivsystem 32 / 64 med en moderkort P573-CM ASUS, Grafik cort V621 ASUS med Vga driver V721 ASUS .
Vid start av data visas felkod c800002 och samtidigt har jag fel med tillfälliga avbrytning i pågående seral / film inspelningar både med ljud och bilder, därför undrar jag om dessa problemet är i sammband med felkod av c800002 också ?
*Tack för tips och rådgivning.
Mvh
Jul 22, 2009 | Pentax *ist DS Digital Camera
Need to make my radio recive even freqencys
Hej,
Jag har beställt en shop manual till 2003 Town car.
Kanske det står något i den hur fixa problemet.
mvh
Peter
May 19, 2009 | 2003 Lincoln Town Car
HP Photosmart 3210 Printer Logo
922 people viewed this question
Seeker5211
Seeker5211
