Question about Microsoft Windows XP Professional
Why is it that my cd rom is not functioning well?
  • Raghavendra Nagaraj
    Raghavendra Nagaraj May 29, 2010
    Is it detecting in Windows? is is SATA or IDE Type?
  • 379 Answers
The most common cause of failure of a CD drive is the bearings on the drive motor have trashed themselves, and it cannot reliably spin fast enough, or it won't spin at all.A tip for you - your CD drive is spun by Windows a lot even when you are not using it, just in case you might want to access it, sometimes even when no LED is lit up. It is partly for this reason that no CD drive is warrantied for more than a year anymore. Your CD drive will last much longer if you always take out the CDs when you are not using them.
Posted on May 29, 2010
Risk of losing data by re-booting CD-ROM recovery disk
Copy off your data to another computer before recovering. A recovery usually restores to factory settings and loses all data.
You could boot to Ubuntu or Linux and copy your stuff that way, then when restored, copy it back.
Feb 11, 2016 | IBM ThinkPad Computers & Internet
I have a laptop which is compaq 510, now here's my problem... my cd-rom is not functioning very well....i have tried cleaning it by using disk cleaning.... but then it some cd's can't play... i...
Cleaning the CD-ROM drive's lens using the cleaning disc is sometimes not enough. In your case, you need to clean the lens by wiping it with a dry cotton lint free cloth. If you have a lens cleaning liquid from the CD disc cleaning kit, you can moisten the cloth with a drop of that liquid. Then, you should gently wipe the lens with this cloth.
After this is done, test your CD-ROM drive. If you still experience the same problems, then you will need to replace the whole CD-ROM drive.
Sep 03, 2011 | Computers & Internet
My DVD-CD rom (TSST corp. DVD +-RW TS-L63H) don't function or maybe it was corrupted by virus.
The problem might be that the DVD-CD rom might be having a lens/laser problem, the lens might be weak and cannot read discs anymore. So it would not be functioning anymore. The solution to that is for you to get the laptop opened and remove the DVD-CD rom Then open the CD rom up and replace the lens.
Also the problem might be that the DVD-CD rom might have been disconnected from the inside, so all you have to do to solve that problem is for you to open the laptop up and try a new connector cable and secure the connection to the mother board is tight, then run the CD rom after reassembling the laptop together.
Take care and good luck
Oct 19, 2010 | Computers & Internet
I can't import anything or burn a disc
A cd rom or dvd rom are not functional as burners. You need cd burner or dvd burner.
your question is not clear as to what configuration you have, but confirming that your hardware is capable of burning cd's / dvd's is your first step.
May 27, 2010 | Apple iMac HD, CD-ROM / DVD-ROM Carrier...
DVD/CD will not open on my HP Pavllion s7000 what may cause this?
go to computer and try to right click on CD/DVD Rom and then select Eject there.. if this doesnt helps u then u would have to manually release the CD/DVD rom.. just below the tray there is a Small Hole .. use a Needle or any other device that may go in that hole.. try to press on eject button there.. and try to press using needle.. try doing so 3 - 4 times.. there is a latch that needs to be released to open the Tray..
this normally happens if the eject functionality of the tray is not functioning properly.. if ur computer is under warranty .. get the CD/DVD rom replaced.. let me know if this resolved ur issue regards, guru
Apr 20, 2010 | HP Computers & Internet
Can not boot from cd rom...bios boot order is set
Set all in Boot priorty to CDROM
Set Other Boot Device to No.
Jan 07, 2010 | EliteGroup NFORCE 570 SLIT-A Motherboard
I inadvertantly removed the functional software installed for this device. The icon is no longer displayed when I open "My Computer". Since I do not have a functional CD DVD Rom device am unable to...
try taking out the cd-rom out of the system and then hook it back up. Go into your BIOS and see if its being recognized in there, if it is then let it boot back up into windows and see if the device is okay. If its sitll not then try another known working device in there and see if the cd-rom works now. If it does then you know the original cd-rom was bad. If it still doesn't then it could be the motherboard controller that the cd-rom hooks up to is bad.
in the BIOS, If the cd-rom doesn't show up or if it shows weird symbols then try another cd-rom and if you get the same symptoms then the motherbard is bad.
Jul 16, 2009 | Computers & Internet
Packard Bell Easy note R1000 - CD/DVD Rom
use this tool to reset the cd in the registry
after you run the file - reboot the computer -
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
Sep 09, 2008 | Packard Bell GCD-R580B (gcdr580b) Internal...
Loading Windows 2000 on a formated hard drive
Try detecting cd rom in bios and boot from Cd rom. and then istall windows.
If not you should have drivers in floppy during installation it will ask for drivers F6 [function key]
Best Regards
rafique
Feb 18, 2008 | Fujitsu Stylistic LT C-500 Tablet PC
Microsoft Windows XP Professional Logo
20 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
