Question about Sony KP-51WS500 51" Rear Projection Television
The tv wont turn on and when it did it had thick green lines init
Ok at first out tv had thick green lines throu it and we asked some tv people and thay sead it was one of the bulbs going out then out tv started to shut its self off than it dident turn on at all! Its ben out for about a year and a half and no one will cume out to see us i need help. we think its from to many video games but we could be rong. out tv is a Soney KP-57WS500.
  • Sony Master
  • 5,138 Answers
Green Tube,Sony had major problem with Tubes shorting out,You also need to Check Video IC on the CRT board.
Posted on May 29, 2010
I have a brand new Aquos 52" LED TV and I accidentally locked remote operation and THEN found out the front touch screen panel was broken. Any way to manually reset the TV or remote to gain access to...
While the set is turned on, you need to hold the power button until the set shuts off and the led in the middle of the bottom flashes once. Then quickly release the power button and press the vol - and input buttons together along with the power button. Your TV should then turn on and should show you a blue box with the letter K. Now press the vol- and channel- buttons at the same time. You should now be in the service menu. With your remote arrow up until the top line says industry init. Arrow to the right and hit enter. Screen should turn green and say factory init success. I hope this helps you.
Apr 04, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
"K" in pink background after part installation LCD tv from sharp
When you see the "K," hit channel down and volume down on the tv. Hit the down arrow key once. You should see some the says factory init. Use the channel up and down to select "Factory Init" and hit the right key to change to yes and hit ok. Once it turns green, unplug set for 30 seconds and plug back in.
post back here if I was too vague or if you get confused and I'll write up a more easier one.
May 28, 2010 | Televison & Video
When i turn on my tv the green power light blinks and the tv does
There is a procedure called and Industry INIT. The reason I cannot post it is that if it is done incorrectly it can wipe the memory of your television. Also if you get a yellow screen versus a red screen versus a green screen there are different steps to peform next. To attempt and Industry INIT you would call 800-237-4277 pressing 1 for each of the prompts. If the Industry INIT fails the representative will direct you to your local service provider. If you were interested in performing the repairs on your own partstore.com has parts.
May 10, 2010 | Sharp LC-32SB24U 32 in. LCD TV
Philips tv powered off and wont turn back on
There is a smt located at 7404 [C-6 Bottom] A common problem, does the tv make a sound like it wants to come on? Location 3239 should be small resistor, 3414 another resistor and a driver transformer at 5402 if it looks burned. See MCM electronics website and see if there is a kit to repair this. Or ask for part #s as per location of problem area mentioned. What you will be doing is changing the timing so all the components will come on at the same time. If this is done correctly you will notice the top of tv screen will flash red, green and blue lines. This will be the new norm each time you turn it on. But it will be OK. This is what the flashing green light is telling you. signed the Green Lantern7!!!!!!!
Sep 03, 2009 | Philips 30PW8420 TV
The tv quit responding to the remote
On this unit if you do a fact reset it should fix this problem steps as follows. PS you might need 2 people
1- unplug power cord from back of TV
2- on the key pad on the tv hold the input and vol dowm buttons
3- while holding the buttons plug the tv in, keep holding the buttons until the screen comes up.
4- once the screen is up there should be a white K in a blue or green box.
5- next, on the key pad on the tv press the channel and vol down buttons once.
6- a menu should pop up
7- using the sharp remote,locate the directional pad
8- press the down button once should bring you to a 2nd page
9- top should state FACT INIT press the right arrow once to turn on, next a series of back slashes come up.
10- screen goes green and says INIT Successful
11- unplug power cord from back of tv wait 10 sec then plug back in. tv should turn on by itself. should be back to as new.
Mar 19, 2009 | Sharp LC52D65U 52 in. LCD TV
Sharp aquos lines threw the picture
I've seen this problem before and if caught early (usually only a few pixels), its fixable. But if it has already started forming a "line" it might be too late and you might have a defective LCD panel. Most of the time, doing the factory initialization helps with this problem.
(WARNING: THIS GIVES YOU ACCESS TO THE SERVICE MENU. DO NOT ADJUST ANYTHING IN THE SERVICE MENU OTHER THAN WHAT I PROVIDE YOU IN THESE INSTRUCTIONS. IF YOU DECIDED TO ADJUST ANYTHING OTHER THAN WHAT I PROVIDE YOU IN THESE INSTRUCTIONS, I WILL NOT BE RESPONSIBLE IF ANYTHING WRONG HAPPENS TO YOUR TV.)
  1. unplug tv
  2. press and hold at the same time “Vol –“ and “input” button on the TV set.
  3. while holding those buttons, plug the tv back in
  4. the tv should turn on by itself, keep holding the buttons until the letter “K” appears. Then let go
  5. then at the same time press “Vol –“ and “Ch. Down”, you should see the service menu appear (if it does not appear, try pressing the two buttons again, it needs to be exactly at the same time)
  6. Then use the “Ch. Down” button to navigate down the service menu until you see “Industry Init” (NOT Industry Init +cause)
  7. Then press “Vol +” to toggle it to “ON”
  8. Then “/////////////////” should appear.
  9. when the screen turns GREEN, unplug the TV. Wait about 30 seconds, then plug the TV back in.
  10. Then continue on with the initial setup again.
Mar 27, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Toshiba 40pw8db with colored lines horizontally
there are some boards in the tv that plug in (push down) have the power off and unplugged have a look around, and see if any boards have come loose, stay away from any thick red wires (EHT) DO NOT PULL At the Gray Rubber Caps that go to each gun (tube) RED GREEN Blue, this can carry a heavey charge even if the tv is off and has been for days, regards mark
Mar 15, 2008 | Toshiba 40H80 40" Rear Projection...
Sharp Aquos LC-42D62U VOlume Control
OK guys I'll save you. The tv is in hotel mode. To get it out from there you have to go in service menu but DO NOT CHANGE ANY OTHER THING IN THERE, only what i tell you. With the tv on and the K letter on the screen press in the same time vol- and ch- on the tv set. Now you'll be in service mode. On the remote press down arrow (not -channel) and you'll see up industry init. go there with ch- and press vol+ and enter. let the tv like that for few seconds and the tv will go green and hopefully industry init succsesfull will be on the screen. After that unplug the tv and replug it. Done!
Oct 19, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Horizontal Lines Moving Through Screen
your tv has a carry in only warranty. i would ask philips for the closest authorized servicer. i find i hard to believe there wouldnt be an authorized servicer within a few hours away.
Sep 26, 2007 | Philips 23PF5320 23 in. HD-Ready LCD...
Green lines
This is the convergence amps going bad. You would need some tech experience. But could do it if talked throu.
Sep 11, 2007 | Philips Magnavox 51MP392H Rear Projection...
Sony KP-51WS500 51" Rear Projection Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
