Question about Kodak EASYSHARE 5100 All-In-One Printer
My printer wont scan when i command from pc - Kodak EASYSHARE 5100 All-In-One Printer
  • vikasingh335 May 29, 2010
    reinstall your printer cd and maybe it'll be a problem of virus
    Problem Solver:
  • 9 Answers
Have you tried going through the paint in accessories? If not go to your start button then accessories then paint. hit file then go down to 'from scanner or camera' choose your device and then follow the directions.
Posted on May 29, 2010
RX425 wont scan
try installing the printer with it original driver it will work
Jan 25, 2013 | Epson Stylus RX425 Multifunction...
How come my pc cant link to scan doc???? this is an office pc. my pc at 1st can link to this canon IRC3220N , it can photostat can scan from the canon to pc into scan doc file. but for right now my pc...
try to reinstall the driver s for the printer/scanner ...and see if the issue is solved.....Another thing ....if the scanner is used by multiple computers you have to give the scanning command from the computer ...and not from the scanner itself...This way you will be able to import the scan result into the library of the program that drives it ..
another thing that may happen is the link to be broke ...so ..get to the fax and printers in the start menu ...and open it ..and redo the link ..by scanning for printers and choose it again from the list ..(by name ) ..and make it the default printer/scanner..
Jul 05, 2011 | Office Equipment & Supplies
Will not scan.printer says downloading application list.dont know if there is a problem with my computer or wireless network. have no idea what to try.any suggesions?
This is normal function and nothing to worry about.
There are two ways to initiate a scan using your machine.
You can use the keypad on the printer to tell it to scan and this makes the printer send the scan to the computer. Using this method lets the printer control the scan command.
To scan using the keypad - press the scan button on the printer. This will bring up the "downloading application list" on the printers display. What the printer is doing is looking for a list of installed programs/software on your pc that it is familiar with and can scan your document to. Your printer can use software like ,Adobe Acrobat, Microsoft Word or internet explorer ect. When it confirms a list of installed software available on your pc it will display them and wait for you to confirm where you want your scan to go. Word will only accept documents. I suggest scanning to a photo program for pictures. If your printer does not find any comptatible software that it can scan to on your pc then the downloading list notice will time out and it will display a scan error or just turn off and power down.
I suggest using the second method below to scan instead.
OR
You can use the software after its installed in your pc and go into the computer to tell it to scan using the printer and store the image in your pc instead. Using this method lets the computer control the scan command.
to use this method, you need to have the dell software for your printer model installed and click on it on your desktop. then just follow the prompts to find the scan command. If you dont have the software, its available on Dell's website. Go to customer support and find download software and drivers and enter your printer made and model number. Then follow the prompts to install the software on your pc and start your scan once more using the instructions above.
Hope this helps?
Mar 03, 2011 | Dell V305w All-In-One R840635AU InkJet...
I recently bought a Canon PIXMA MX320 all in one printer with my macbook. It works fine, but I can't figure out how to scan an image onto my laptop.
You need to control the scanner through your PC with canon software that came with your scanner otherwise you cant scan anything..first open the printer/scanner software ,select scanner,then place your document and command "scan" from the software.
Good luck, do rate the solution if helped
Nov 27, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
Kodak ESP5 AiO Unable to scan to PC. Error code on opening Scanner 2106 Please advise,THANK YOU!
Please clarify a few things for me so I can help you solve this issue.
Are you trying to scan from the printer to the computer? (pushing the scan command on the printers keypad to send the signal to the computer)
OR
Are you trying to scan from the computer to the printer? (Using the scan options in your software by choosing "start" and then "programs" and opening your printers software to choose the scan option)
If your scanning from printer to computer (using the printers scan option on the keypad) and your getting an error code, chances are the problem is you have not set up your defaults in the printers menu yet. To scan from printer to computer, the printer needs to know which program you want your document to scan to in your computer. If its a text document, some people choose "Microsoft Word" and the scan fuction sends your item to that program and opens it for viewing on your computer screen.
There are different programs to use for each type of fax that need to be set up in advance in your printer to be able to scan from printer to computer. Send pictures to a photo editing software and choose the size and resolution you want as "default". Do the same for setting up text documents before you try and use this feature to eliminate the error code.
To configure your options to scan from printer to pc, push the "menu" button on your printer and use the up and down arrows on the printers keypad to move through the choices. Find the command similar to "scan options" and follow the prompts to set the defaults on handling text documents and pictures and then save your choices by pushing the "ok" button on the printers keypad.
Try scanning again with your computer turned on and open to the desktop. Push the scan button on the printer and see if it sends the image or document to your computer screen. It should warm up, then scan and show a preview on your screen for you to accept or reject. If this does not happen, please asnwer my questions as listed above and clarify what you see so I can help solve this issue right now.
Sep 27, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Having problem with scanner detecting PC destination when scanning to PC from printer. CS221
Make sure that print and file sharing is on. You must access the command center from your browser. Setup address book with all appropiate infomation for scan to smb. Make sure that the path name does not have the drive ID. ( sample: Path: Scans: not Path: C:\Scans) Hope this helps
Aug 04, 2010 | Kyocera Copystar 221 Black and White...
CANON MX 320 SCANNER PROBLEM
You need to control the scanner thru your PC with canon software that came with your scanner otherwise you cant scan anything..first open the printer/scanner software ,select scanner,then place your document and command "scan" on your PC..thats it..
Jan 05, 2010 | Canon PIXMA MX310 All-In-One Printer
How do i use the scanner on my Canon MX310 ?
You need to control the scanner thru your PC with canon software that came with your printer/scanner otherwise you cant scan anything..
First open the printer/scanner software on PC,select scanner,then place your document and command "scan" on your PC..On this window you can also alter the scanner preferences..thats it..
Nov 13, 2009 | Canon PIXMA MX310 All-In-One Printer
Deskjet F2210 wont scan
Click start
Click programs
Click HP
Click HP support center
Click Scan.
Ths scan button on the deskjeyt itself wont work, but the scand command done directly in the computer does.
Apr 05, 2009 | HP Deskjet F2210 InkJet Printer
Kodak EASYSHARE 5100 All-In-One Printer Logo
93 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
