My remote wont work withtv
My remote wont work with tv need codes
LOST BOOK WITH CODES FOR PHILIPS REMOTE FOR INSIGNIA TV WONT WORK
INSIGNIA TV Remote codes, use the below codes to control your Insignia TV with a universal remote.
0103
0189
0217
0135
0133
0116
0167
0456
0029
Best idea though is to buy a replacement remote for your television. check the link.
Replacement REMOTE FOR INSIGNIA TV Google Search
Feb 24, 2017 | Philips Televison & Video
The TV will not turn on. I have replaced the power supply board, but it still will not work. Any suggestions?
I would suggeat calling a tv repairman. However, withTV prices continually falling, the cost of rrepair, or evenboard replacement, mde be omore than the TV is worth, ****** sure to get an estimate first.
Aug 02, 2016 | Televison & Video
Code chunghop RM 139ES for TV Mitsubishi?
The Mitsubishi TV codes for this remote are 011 and 051.
Programming instructions:
1. Switch on the TV
2. Press the "SET" button in the top-left corner of your Chunghop remote until the LED next to the "SET" button illuminates.
3. Enter the first code above 0 1 1 using the numerical buttons on the remote.
The LED next to the "SET" button will go out if you have correctly entered a code.
4. Test the remote with the TV. If it doesn't work - or doesn't operate the TV functions as you would expect - repeat the above steps for the other code.
Please note: Not all universal remotes will work with all TVs.
If the codes above don't work please post back for further assistance. It may be that your remote wont work with your TV or you may need to run the code search feature of the remote to find the correct code.
Hope this helps.
Regards,
BElectric
Dec 30, 2010 | Televison & Video
I have just purchased an LG32lcd 450 tv, I cannot get the handset on Sky to work as they do not have a code to do this as the tv is new to the market, can you please help with this
OK, as you already discovered there is no specific code for your remote. You can try the generic codes for LG which I've listed below. Your TV may use the same flash patterns as some other older LG TVs so these codes might work.
Rev 8 remote: 1293, 1206, 0206, 0065, 0904
Rev 6 remote: 0065, 0742, 0502, 0672, 0634, 0136,
Rev 4 remote: Same as Rev 6
RC1600/00 remote: codes not available and unlikely to work with your TV
** Your Sky remote version can be found on a sticker inside the battery compartment. **
Try these codes but if they don't work it's unlikely your remote will work with your TV - you will need to use the remote supplied with your TV to control volume and power functions. Unfortunately, when a TV is newer than the remote and uses a new flash pattern not programmed into that remote, the remote wont work. However manufacturers often keep the same flash patterns for common functions, so the generic codes might work for you.
I'm informed that a new Sky remote version is due - which will hopefully contain a specific code/flash pattern for your TV - but I've not been able to confirm this yet.
Hope this helps - please post back if you need further assistance.
Nov 23, 2010 | LG Televison & Video
I need the code list for a slyvania tv i have a rcu404b remote..
Your remote is programmed with only ONE code for Sylvania TV . . . 4
http://rcaaccessories.com/remotefinder/?sku=RCU404&productType=TV
I think your remote is fairly old. If your TV is newer than your remote, this code probably wont work.
Please rate this solution if you find it helpful. Thank you.
Nov 03, 2010 | RCA Universal Remote Control
Remote wont work i changed the batteries still wont work
first try to buy universal remote ,the TV remote sensor not recognize your remote.
Apr 29, 2010 | Sanyo DP32649 31.5 in. TV
I lost my remote for my rca converter box this remote works with my tv but wont on the converter box. Is there a code i need to make it work? or do i need another remote?
I can help you reprogram your RCA RCR311B for all your converter box.
Please review my Fixya Tip posts for:
  1. Searching for the proper codes, or
  2. Entering the codes you have looked up for your Orion TV on this remote's device code list.
I hope that helps.
Dec 30, 2009 | RCA RCR311B Remote Control
Open Questions:
samsung pn64f8500 boot loop with evoulution kit 3000za installed I had perfectly working Samsung plasma ph64f8500 working fine with Samsung evolution kit 3000 ZA installed. Then we moved I took off the evolution kits so the movers would not knock them off. I powered up without the evolution kit installed accidently. Now both plasma are stuck in boot loop. They power up but go to the smart tv logo and cannot find the evolution kit. I read somewhere a long time ago that I needed to reset the evolution kit to a state where it had not been installed. The current issue is the Main Logic Board eeprom instructs the unit to boot correctly but it cannot find the evolution kit. If you boot without the evolution kit the system halts and indicates on the screen the evolution kit has been uninstalled and you must install it if you wish to view. If it could find the evolution kit one could go thru the menu to uninstall it correctly. One option is to manually reset the eeprom to remove the install instruction that boots looking for the evolution kit. I have been looking for the eeprom on the Samsung main logic board but I cannot download the logic board schematic. I cannot find the logic board number. The main logic board is BN94-0625C. The logic board has tow other part number references.• MFR Part Number 1: Samsung BN94-06205C • Board Number(s): BN41-01998A, BN97-06633G i have been researching the logic board IC Numbers and belive that IC 1701 is the eeprom that requires reset. The youtube videos for similar models indicate a eeprom that is listed as a part nmber for this samsung pn64f8500 unit as 24C512 and shows how to jumber 2 IC locations that will force the eeprom to reset to standard starup without the Evoution Kit 3000
Jul 16, 2018 | Samsung Televison & Video
Televison & Video Logo
202 people viewed this question
Top Televison & Video Experts
