Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
MOWER ONLY RUN WHEN U PUT GAS IN CAB WANT START
  • 66 Answers
Good chances you either have dirt in one of the jets, varnish if the motor has sat for awhile, float is stuck shut or its leaking by the gaskets. It all boils down to taking the carburetor off and cleaning and a carburetor rebuild kit.
Posted on May 30, 2010
  • 61 Answers
Ok, so your not getting gas to carberator, or thru the carberator. Disconnect gas line from carberator, if gas is present thru fuel line, you have a carberator problem. Your rather meger with your mower information so this is all i can tell you. Wish i could be of more help.
Posted on May 29, 2010
Lawn mower won't start
likely the old gas is gunked up
remove the screw on the bowl bottom an look for a tiny hole thats plugged going across the bottom of screw.
if no screw an bowl then its just gunked up lines.
May 03, 2015 | Troy Bilt 5.5hp Self Propelled Mower
Lawn mower instructions why wont it work
check for spark at plug if spark at plug then squirt some starting starting fluid in carb see if will start it should run long enough to burn out starting fluid if does check for water in gas if is drain tank and carb bowl put in fresh gas not and repeat not old gas you were using strat lawn mower if still dosnt start rebuild carb and add and additive called seafoam to the gas this is good stuff follow instrution on bottle
Sep 02, 2014 | Garden
How do I make my lawn mower run better?
Yes, clean the air filter if it's a foam , washable fliter. If it's not the washable kind , replace it. Also replace the gas filter if there's one on the engine. Buy a can or bottle of carburetor and fuel system cleaner and put it in the gas tank to clean the carburetor.
Jun 10, 2014 | Mtd 22" Yard Machine Push Mower
The riding mower has been used in June. Now when I try to start it I cant. I have checked the battery, gas, etc. before trying to start it. What can I do now?Thanks
put gas right into the carburetor and see what happens. if it doesn't do anything then you have a spark issue, if it runs until the gas you just put in runs out then it is a carb issue. sometimes just priming the carb with gas will get it to run again too
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Sep 25, 2013 | Ariens 21 In Classic Walk Behind Push Lawn...
I ran over my gas cap and it killed the mower. I put a cap from another mower on and it will start but only run for a few seconds. I've pulled the plug and the air filter. Still the same result what is my...
You need to find a "vented" gas cap for your mower to continue running with the cap on. You can buy such a gas cap for most mowers at Wal-mart or similar department store and it will say "vented" on the packaging.
Jul 24, 2010 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
I have a Troy Bilt 675 lawn mower, won't start.
is the gas in the tank old? if so, try to drain it and put fresh gas in. Pull the spark plug to make sure it is not fouled and replace it or put in a new one. Check to make sure that you do not have the mixture or choke set to run too rich or too lean. If you are at an altitude above 2,500 feet you need to run more lean to compensate.
May 30, 2010 | Troy Garden
Lawn mower does not run.
Needs a new diaphragm. Its between the carb. and gas tank. It collapsed and doesn't allow enough gas to carb. to keep motor running.
Apr 10, 2010 | Mtd 22" Yard Machine Push Mower
How do i drain gas from 20hp 42in yard tractor?
The best way will be to take the fuel line off the carburetor or off the fuel pump, if so equiped, and put it lower than the fuel tank on the mower. Drain into a gas container. You can then put this gas in your vehicle to burn, rather than let it sit and go stale over the winter months.
If you are just taking the fuel out for the winter, and not for any other purpose, you can purchase some fuel stabilizer, called "Stabil", and put about 2 oz. per gallon of gas that's in your mower tank. Slosh it around a bit, start your mower and let it run, or take it for a spin around the yard to make sure you get the stabilizer mixed in well and down into your carburetor.
If you do drain the fuel for the winter, after you are done start your mowers engine and let it run the carburetor dry. That will keep it from evaporating too bad and gumming up your carb. Still a good idea to run some stabilizer thru the carb prior to draining the tank.
Oct 26, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
** Help Starting **Yard Machine 21inches 139cc
amiseybold;
First check for spark. Remove the spark plug. Leave the spark wire connected. Hold the plug against the metal of the mower engine so you have a ground and can see the gap of the electrode where the spark jumps across. Have someone pull the starter cord and verify that you have a spark. Hold it by the threads of the plug so you don't get a little spark jolt yourself.
go to an auto parts store and get a can of starter spray (it's actually ether), Remove the lawnmower spark plug and spray a little ether in the plug hole. Put the plug back and tighten it and see if it starts.
It will probably start, run for 5 or 10 seconds and then die. Repeat this procedure once or twice again and eventually it will start to draw gas from the lawnmower tank.
A seasonal tip. when you put the mower up for the winter, **** the remaining gas out of the tank, start the engine and let it run until it uses up the gas in the carburetor. This will make iot much easier to start in the spring
Hope this helps Good Luck Loringh PS Please give me a rating
Nov 08, 2008 | Yard Machines 158cc Push Lawn Mower #11a...
Wrong gas
Since it's not running right I'm assuming the lawn mower is a 2-stroke and the gas had pre-mix in it. It probably just got a strong mix of the pre-mix in the lines and just has to be cleared out. We run some of the old pre-mixed gas from our dirt bikes in our trucks to get rid of it. I put a gallon or so per tank refill of good gas. You may try and rev it up a bit when starting to keep it going long enough to flush it out with the new gas you put in, that or start it a few times till it's clean. An octane booster or fuel injector cleaner might help also. If the lawn mower gas wasn't pre-mix it may just be old and possibly have some water in it.
Aug 17, 2008 | 2000 Dodge Ram 1500 Truck
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
394 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
