Question about Saeco VIA Venezia
After pressing the 'coffee' button, a lot of noise but no coffee!!
This happens to me when i get air in the line that pulls the water out of the tank (i.e. you forgot to fill it up every now and then). you fill up the tank, wash you hands really well (don't want soap or germ in tank), partially put tank into machine and submerge the tube. then with your index finger flick the screen covered tip until no more air comes out. then, push the tank all the way back with the tube submerging all the way to the bottom. turn machine, push steamer butten, and turn knob to turn on steam for a few minutes to remove any remaining air in the tube. then, turn off machine, unpush the steamer (takes too long if machine on and unpush it for the espresso icon to light up so i just shut it off to reset it), turn on machine, wait for espresso icon to turn on, and then press button. voila. problem solved. i find the finger flicking step key b/c takes forever to purge a line full of air just using the steamer step.
Posted on Jun 18, 2010
The machine goes on but when the button is pushed, it makes noise as if it is making coffee but no water comes out. This occurs periodically. Does it simply need descaling/
you should try that first,,,i do it this way,,,,get some kettel cleaner,, mix it up in a jug in warm water first ,,then tip it in the coffee maker and catch it in the jug when it come out again so you can tip it back in,,,,run it through a fuw times,,,then flush the coffee maker out with lot and lots of fresh water before you make coffee,,,or you could be a little unwell drinking kettel cleaner?
Nov 28, 2010 | Nespresso Le Cube C185 Espresso Machine &...
When I press the Large coffee button it grinds the beans and then starts to flow the water through, then when a small amount of coffee is in the cup it stops. The Medium and Small coffee buttons work well...
Just needs to be reprogramed. Try reprogramming the machine. Push and hold the button for the coffee you want, but hold it all the way through the process. Don't release the button until you get the amount of coffee you want for that button, then release the button. That should get you the same amount next time. You can do this for each coffee button.
If that doesn't fix it, then you might need a new flow meter.
Oct 03, 2010 | Saeco Royal Digital Plus Coffee...
Just need instructions to descale my Lavazza Blue coffee machine
Using a proper coffee machine descaler, create the mix in the water container
Go into the service menu by pressing the 'Stop' button when you turn it on. Scroll throuigh the menu until you reach 4. Descale. Press enter, then scroll to 4.3 Do it now. Press enter and toggle to yes, press enter
It will then run through the descaling cycle which may take some time. After its complete, thouroghly clean the tank and pump lots of water through the system before you brew any coffee, Replace the filter also
Sep 05, 2010 | Lavazza 2210
When you press the button to make coffee, it makes the noise lake to cat the coffee and nothing happen no water no nothing!do i have to go for service?
The vibrating water pressure pump is not working and it migh be stuck due to scale or damage. Howver if you hear the loud noise of the pump then the problem is the coffee solenoid valve which it might be stuck or damage.
Good Luck
Please remeber to vote for this answer
Feb 22, 2010 | Gaggia Syncrony Compact Coffee...
Hello- I have a Saeco Italia machine, about 4
Try this press the pre ground button then the coffee brew button, if water flows from the spout then the grinder chute is blocked, if no water flows then the brew unit is screen blocked.
If grinder, then remove the brew unit and check the chute from the grinder.
Sep 27, 2009 | Coffee Makers & Espresso Machines
Changed Claris Filter-now says
Fill your water tank with Warm Water and then try a few times. Keep Patient and Keep trying for some times and it will work.
May 31, 2009 | Jura Capresso Impressa S9 Coffee...
SAECO Royal Professional no water comes out?
Hi
What is the lever for despensing grounds on the top of the side door reading. If its all the way to the back it probably too far. Pull it back one click and try it. The other thing you should try if its not the grounds it to push the button you want to use and hold it in until the liquid coffee want is reached, then release the button. This is called programing and you can do it to each button for you desired amount.
Mar 30, 2009 | Saeco Royal Professional Espresso Machine
No coffee is coming out of the machine...
in our machine we wanted a stronger coffee so we adjusted the auto grinder (where the coffee beans are housed) to the finest setting thinking the finer the grind the stronger the coffee...after doing this the machine wouldnot make coffee...we sent it away while still under warranty and the tech said that the grind selection was too low so they just turned the grinder back up a notch and it worked fine ....dont know if this will help but it's worth a try!
Mar 26, 2009 | Krups Orchestro Dialog FNF2 Espresso...
Saeco VIA Venezia Logo
227 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
