Question about Samsung CLX-2160N All-In-One Printer
I change the toner but it keep on desplaying waste toner tank
  • 468 Answers
Samsung printers are acepting just genuine toners
Posted on May 29, 2010
You should empty the waste toner box that is placed near the blue toner!
Posted on Jun 01, 2010
I keep cleaning the toner/printer waste tank cartridge and the printer continues to stop printing and the same error message displays saying "Replace/Install waste toner printer cartridge.
How are you cleaning the tank? Just dumping the contents into a trashcan may not work. The printer uses a light sensor to detect whether the tank is full. When the light does not shine through the clear window of the tank, the printer thinks that the tank is full. Sometimes cleaning the window with a cotton swab will make it work, but it can be difficult since the location of the window with respect to the opening of the tank is not a straight shot.
Another way to clean it would be dump the waste toner into ther trashcan. Tap the tank a few time to get as much of the toner out. Then add some soap and water into the tank and seal the tank opening with the green lid. Then shake the soapy water in the tank for a about a minute. Then dump the soapy toner/water out. Rinse again with just water and and allow it to dry. You don't have to get the tank completely clean, just enough to stop the waste tank error message.
Hope this helps.
Nov 17, 2010 | Samsung CLX 3160fn All-In-One Printer
Waste Toner Error Message For Samsung CLP 550
Dr. P,
Printer will display "Waste Toner Tank Full/Not Installed" error message if the waste tank is full of toner or not installed.
  • Open the waste tank door and check for the waste toner tank.
  • If the tank is full or not intalled, install a new tank.
If you have user guide, it will show you how to install the waste toner tank.
Sometimes you will also get this error message if the Waste Toner sensor is covered with toner powders.
  1. Remove your waste tank and look for the black plastic on the right side after removing the waste tank.
  2. You sould find small openings on each side in the black casing.
  3. Use Q-tips or thin cotton object to clean the inside the small opening.
for user manual just click here:
If this solution works, please don't forget to rate it fixya
For any more question just ask me.
Thanks
Iqbal
Apr 14, 2008 | Samsung CLP-550 Laser Printer
CLP-315 - CLP-315 Laser Printer: I have changed all the color toner but not prining...
any error indicated?
run your Smart Panel and check what is the fault that is being detected.
If all the color toner had been replace. what about the OPC & waste toner tank?
note. Please replace the waste toner tank once it is full do not reuse the same waste toner tank. as it will course the internal of the printer to be spread with waste toner and your print out will be dirty and patches.
May 16, 2010 | Samsung CLP 315 Laser Printer
I have a samsung clp500 color printer but it is not working .it show only waste tank is full/ not instaled what should i do.
The "waste tank" is located behind the front panel that has the SAMSUNG name on it. Press on the upper corners of this panel and it will open up to reveal a clear plastic tank on the right side.
This tank pulls out easily and has two holes for excess toner to flow into it.
Look at the side of the tank that has the holes. You should see a part of the tank that extends out from the tank but ends in a clear square. The waste tank sensor "looks" thru this clear plastic square to determine if the tank is full. I.e. if toner is in this area and you cannot clearly see thru both sides, the sensor will tell the printer that the tank is full and needs to be changed.
If the tank is not full, use a long cotton swab and clean out the inside of this area. Once you can see thru both sides, carefully replace the tank back into the printer and turn the printer back on.
If done properly, the error should go away and you should be able to continue printing. I have doen this and it works fine.
(Some posts have had people cut this part of the tank off and simply tape over the hole that is made with strong tape. This bypasses the sensor and would allow the printer to run again. I have not done this as I do not want the possibility of toner spilling in my office.)
Exception:
The sensor could be bad and causing the issue. If this is the case, it may be cheaper to purchase a new printer - CLP-620 ND is a duplex, networked color laser jet that is selling from frys.com for $315.
Apr 30, 2010 | Samsung CLP-500 Laser Printer
My printer keeps putting these annoying black lines on my docs. I have an important paper to print and I cant have black lines on it! UGH! I tried dusting and cleaning the drum and restarting the computer...
As you talk of a drum, I take it you have a laser printer. You say you have checked the drum. Without knowing the model, sometimes the waste holder gets full and will cause this. Some carts have the waste holder just below the toner holder in the cart, and others have a separate waste tank.
Always run the printer on the leanest setting that will print well. Stay away from the rich settings as they waste toner and fill the waste tank needlessly, leading to a needed cleaning.
The lines can be waste toner getting printed rather than going into the waste tank.
Jul 03, 2009 | Office Equipment & Supplies
CLP300 Waste tank
Just found the troubleshooting manual for the printer and emptied out the waste tank. Seems to work fine now.
Aug 31, 2008 | Samsung CLP 300 Laser Printer
Brother printer mfc-9420cn says to change waste toner. how do i do i this?
when you open the front cover, there is a waste toner tank on the bottom right side of the printer.
Remove the tank and chuck out the waste toner, wipe the tank clean with a cloth and slide tank back in position and close the cover.
this wil resolve the message on the screen
May 14, 2008 | Office Equipment & Supplies
Printer not printing
On the machine there is a sensor that looks trough the waste tank even though you have wiped it clean the likely thing is that the sensor cannot see through the plastic waste tank.
I suggest vacuum the waste tank out until all the toner has gone then install it. If you cannot get rid of all the toner then wash the tank out and leave to dry then install it.
Hope this helps you
Thanks J
Jan 05, 2008 | Samsung CLP-500 Laser Printer
Waste motor error
The wate motor transfers (you guess it) waste toner to the waste toner bottle. If the bottle fills up, the motor cannot transfer more waste to it. This is rare, for the printer should ask for a new waste toner bottle when the previous one fills. However,it happens frequently when users try to empty and clean the bottle instead of replacing it.
If a new waste toner bottle is in place, then the printer needs a new motor, which can only be purchased through an Authorized Service Center.
Oct 24, 2007 | Samsung CLP-510 Laser Printer
Waste toner tank full/not install keep displaying
The sensor for the waste toner tank is dirty or defective. The toner sensor is on the right as you look at the panel just below the liquid crystal display. There is a bump in the clear plastic just below the circular right vent port, that's where the used toner pours in. When you clean out the toner cartridge there is some residue left that makes the sensor think it's still full. Take a piece of paper towel and a small screwdriver (I'm told a bent coat hanger will work, too) and clean the inside of the sensor window inside the used toner cartridge (w/ access through the toner port). It looks like a little raised groove on the right. Just wipe it until it's clear on the inside. The sensor can now see through the window and you should be okay. Otherwise, the sensor may need to be replaced by an authorized Samsung technician. Let me know how it works out!
Jun 16, 2007 | Samsung CLP-500 Laser Printer
Samsung CLX-2160N All-In-One Printer Logo
353 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
