Hi I was trying to fix something on my window unit AC and to do so i had to unplug the wires from the on off switch. It consist of 4 wires and I cant remember how to put them back on. Would you be able to help me if I emailed you pictures? I don't have your email so if you could let me know that it would be great!
    Brigadier General:
  • 3,917 Answers
Yes you can attache the pictures and reply to these posts. I would also want you to look into the link posted bellow which gives fair idea how AC power lines are connected.
http://en.wikipedia.org/wiki/AC_power_plugs_and_sockets
Thanks for contacting Fixya and please accept the solution if it has helped you.
Posted on May 29, 2010
My ac is only 4 years old when shut it off the compressor still continue's, I have no control of temp seems the highest cool and only after I unplug does it stop?
Not sure what system(window, ductless, residential conventional split system, package unit??? If it a standard residential system on the outdoor unit there is a 2 pole contactor. Its the component that the line voltage wires, coming from your home, connect to the unit. That contactor closes its "switch" upon demand and is probably stuck closed. If its a window unit its a window unit (you stated "unplug it") its a micro relay on the circuit board and it needs replaced. Work safe!!
Aug 03, 2015 | Heating & Cooling
Ask com lg ac window unit control panel stopped working
Hi Gina, Try turning off the unit at the electrical panel. turn off switch, wait 15 min. turn switch back to on position. Turn on AC unit. Hope this helps.
Oct 21, 2013 | Heating & Cooling
All lights on but fan or nothing works also can't find reset button
Do you have an owner's manual that came with it? If so you should contact the manufacturer and find out what services are available. It is not something the amateur can fix since it is high voltage and solid state on a circuit board or two. Maybe there are error codes you can write down like the "19" may be,
Jan 01, 2013 | Heating & Cooling
I have a Dell Inspiron mini 10 . net book. Out of now where said something about windows and shut off ... now we cant get it to turn on, wont go past the inspiron load screen the little blue only goes...
tryt to do this
1.unplug the ac adapter
2.remove the battery
3.press the power for 30 secs
4.plug the ac adapter back in and after few secs try to turn it on
Oct 04, 2010 | Dell Inspiron Mini 10 Notebook
Ac is tilted out but water still drains in
Hi!!
Look on the bottom back of the unit for the drain hole is probably clogged, use a piece of wire to unplug it.
Don't forget to rate this post!!
Aug 28, 2010 | Frigidaire FAH106S2T Thru-Wall/Window Air...
Cannot turn the unit off with the on/off switch. all other functions work fine
I would replace the switch - which is something you can do I imagine.
1) just make sure all electricity is off
2) you might need to disassemble the unit just a little, but the object is to 'get to' the switch itself and then remove the wires that is plugged/attached to the switch. NOTE:: it's possible that you might have some 'burnt/shorted' wires in which case all you might need to do - is to fix the 'burnt/shorted' wires and try the AC again.
3) be sure you label each wire you take from the switch, i.e. use numbers or color code or some way for you to be able to put these wires back on a new switch.
4) once you've labeled the wires - then remove the switch and take to an appliance/parts store and buy an 'exact' replacement switch -one that has the same connections as the old one.
5) re-install it on your AC and this should fix your problem.
good luck!
Apr 27, 2010 | Kenmore 70125 Air Conditioner
Is not coolyn
The 'cable' you referred to I'm assuming is the power cord,and the fact that it was 'burned bad,' indicates you had something wrong with the AC itself.
This could be something as simple as a shorted/burned wire inside the unit - to a shorted compressor or fan motor.
If you're mechanically inclined you might open up the unit and see if you can find more burnt wires.
It does worry me a little when I see a power cord "burnt," so it might be smart to have a Service Tech check out the AC completely. If it's just a shorted wire, capacitor, relay or switch, the repair bill won't be that bad.
Good Luck!
Apr 06, 2010 | Haier ESA3125 Wall/Window Air Conditioner
Background hum
I fixed the same issue by replacing the original AC power supply with a 13.8 volt DC power supply (Radio Shack) It seems to be more consistent at high SPL and no hum , as the Boston acoustic unit accepts either AC or DC power.
Jan 29, 2009 | Boston Acoustics MediaTheater Computer...
Heating & Cooling Logo
12 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
