Question about Kenmore 64802 Top Freezer Refrigerator
Doors does the doors flip?
    President:
  • 1,902 Answers
Yes you can change the way that the doors open. You will see on the very top that there is a hinge screwed into the top of the fridge and also below the freezer door you will see two hinges, then on the bottom of the fridge is the last hinge. You will see all the new holes on the fridge as to where to locate and place the doors properly. This is a easy job to complete just make sure that you do this one door at a time to make sure not to confuse the hinges. Please rate
Posted on May 29, 2010
I have a Samsung refrigerator RL46WBSW. How can I reverse the direction of the door opening from left-right to right-left?
Most fridges are designed so that the door can be flipped to reverse the opening direction. Look where the hinges are now. Look on the other side of the opening. Are there mounting holes to accept the hinge bolts? If so, unbolt the door, flip it so the bottom is now the top, and re-attach the hinges and bolts.
If you lack mounting holes, the door likely cannot be flipped.
Mar 17, 2018 | Samsung Refrigerators
How do I remove the door on a denon avr-3310
If your referring to the front flip down door press on the top middle section of the flip down panel
to release it
Apr 26, 2014 | RCA Denon Avr-3310ci Receiver Surround...
Door will not close - latch on door seems to be flipped around so that it bounces off the corresponding piece on the frame rather than catching it to keep the door closed.
Easy fix - while pulling out on the door handle (like you are trying to open it), take your finger and flip the door latch around so it opens. The latch has rotated to the closed position. This can happen in unusual situations, but is easy to correct.
Dec 15, 2013 | 2006 Cadillac SRX
Reverse door lock
Pull door release handle while flipping the hook with screwdriver tip, to release.
Nov 13, 2013 | 2000 GMC Yukon
Door will not stay closed
Sounds like the latch is seized or the tension spring is broke.
You'll probably have to replace the latch.
Jul 27, 2013 | Cars & Trucks
1997 lincoln continental
Check the latch itself (on the door) is in the open position, ans didn't accidentally flip to the closed position. This has to be open so it can fit over the stud in the door jamb, where it flips over the stud to latch the door.
If so, while holding door handle (as if you were trying to open/unlatch door), flip latch open, with a finger or a screwdriver.
Jun 24, 2013 | Cars & Trucks
One side of oven door hinge won't fit back in when putting door back on after cleaning
when you insert the hinges back into place flip the small lock tab at the hinge pin the locks the hinge for removal
Oct 19, 2017 | Indesit KP9508EXG Dual Fuel (Electric and...
Part for my oven door: the door will not go back on after my housekeeper removed the door to clean it. I believe it needs a part that will enable the door to go back on . Help?
Look at the hinges. There are 2 small little locking clips. Make sure they set properly. Likely both clipped on in order to reinsert door. Both must be likely flipped toward you. Try it both ways. After door is reinserted. Flip clips back away from you.
Apr 03, 2012 | Kitchen Ranges
The cover of detergent dispenser does not open..
It is most likely the flip spring...you need to be certain that the legs of the spring are inside the door edge and the spring does not swing freely...and there must be tension on the spring so that when the latch releases the door flips...you can also try this with an elastic, put the elastic inside the closed door and up around the drying solution knob, this will let the door flip open showing that the latch does work
Nov 11, 2007 | Kenmore 24 in. 15252 / 15254 / 15259...
Oven door does not close
One of the springs fell off or the door hinge assembly sprin out.
May 04, 2007 | GE JT912SKSS Electric Single Oven
Kenmore 64802 Top Freezer Refrigerator Logo
82 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
