Question about Microsoft Windows XP Professional SP3 Full Version OEM for PC
Video card is not working? - Microsoft Windows XP Professional SP3 Full Version OEM for PC
  • 379 Answers
Check this link and answer/follow the problems in chart: http://www.fonerbooks.com/video.htm
Posted on May 29, 2010
MSI Video Adapter Cause Blank Monitor
From a cold boot- go into safe-mode. Install the drivers for the MSI video card and do a warm boot.
Mar 07, 2014 | MSI Computers & Internet
No display
try swapping or borrowing a different monitor first- doesnt work pull out video card turn on computer then shut it off, put back in video card- does not work- replace video card with borrowed video card - doesnt work.try different vodeo card in different slot.
Oct 05, 2012 | Dell OptiPlex 380 PC Desktop
Loaded new video card on computer but motherboard video card will not let it work. The motherboard video card does not show up in the device manager and the computer says the new video card is working.
Device Manager is showing correct.
Try connecting the display cable to the Video card and restart the computer.
If that doesn't work, check which display adapter is selected in BIOS.
If it is selected as the Video card, then u need to check whether the new video card is good.
Nov 18, 2010 | Computers & Internet
Video card does not work and PCIe red light remains on
To isolate, put your video card to the other pcie slot then see if it works. Try also to enable the video output of your motherboard either thru HDMI, DVI-D or vga since it is a H57 mobo to check if the motherboard is working properly and will output video ( not using your video card ) . Also reseat your RAMs ( remove and put it back again). If your video card does not work on the 2nd pcie slot after reseating your RAMs then the problem is with your video card and not your motherboard.
Nov 04, 2010 | ASUS P7H57DV EVO Motherboard
ASUS P5VDC-MX Motherboard video card nv4 error
Go into the bios area and ensure that the video is switched to the slot your new video card is using, (PCIE, AGP etc)..
Dec 30, 2009 | ASUS P5VDC-MX Motherboard
Video cards are causing 3 beeps
The 3 short beeps indicates a video card memory problem.
The video card uses video RAM that is part of the video card. Try reseating the video card and if the problem is not resolved then the fault is the video card and it needs to be replaced.
Aug 30, 2009 | PC Chips (M925G) Motherboard
Dell Optiplex GX620 not recognizing PCIe video cards
One of two things could be doing this:
1: Bad Video Cards
2: Bad PCIe slot(s)
If avaliable, I would test the video cards on a PC with a PCIe slot to verirfy if the cards are good/bad. If they work, your PCIe slot is bad and need to have the motherboard replace to correct.
Good Luck
C2Solutions
Aug 27, 2009 | Dell OptiPlex GX260 PC Desktop
Cannot get a g force 5500 to work in a new hp a6700y its plugged in but will not work it has a integrated gforce 6150 in board but will not recognize the new card
Hi..
Make sure that your motherboard can support your new installed video card. Check also that it is plug correctly, try to remove it first and reinsert it again. Remember that the video card are not working properly if your video card driver is not installed.
You need to installed the video card driver.
ICmanServer
Jul 03, 2009 | Nvidia GeForce FX 5500 Video Card Graphic...
Monitor does not come on
The video card you used may work for the 2nd computer but not for the 1st because of the system requirements. They might be different simply because they are different models. check which video card is RECOMMENDED, NOT MINIMUM, and get the recommended video card.
However, if it is the right video card, then get it checked at a pc shop, like pcworld or somewhere like that and see what they think of it.
Sep 14, 2008 | Apple 64MB NVidia NV-11 Video Card for...
Need to disable internal video that isn't working
With internal video cards they normally automatically switch to PCI video cards that you put in without the need for switches or settings on the board. Just plug in the card and plug in the monitor on the card and you should be good. now if your board is one of the select few that require a change in the BIOS then you are out of luck. BUT, take note that 90% of the time that internal video cards do not work because of the memory. Take note that the memory that the internal video cards use is the memory on the board so you might want to check if your memory is working.
Aug 26, 2008 | FIC Computers & Internet
Open Questions:
See all Microsoft Windows XP Professional SP3 Full Version Questions
Microsoft Windows XP Professional SP3 Full Version OEM for PC  Logo
32 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
