Question about Fisher and Paykel GWL11 Top Load Washer
Washing machine starts and stops
Hi well my washing machine turns on with all the lights working,when i press the start button you can hear the water filling the washing machine and then all of a sudden it just stops and starts beeping can you explain to me what the problem is and how i can fix it please.thanks
  • chrizzoclark May 31, 2010
    Can you tell me what lights are on across the top when it starts beeping?
  • Fisher and P... Master
  • 12,061 Answers
Www.docstoc.com/docs/.../Fisher-and-Paykel-Circuit-Diagram-GWL11
http://washingmachinemanual.com/tag/user-repair-manuals-fisher-and-paykel-gwl11-top-load-washer/
Above is your service manual and a circuit diagram, Simply use the troubleshooting steps and you will soon isolate your issue and effect a repair.
Posted on May 29, 2010
Kenmore 11025102310 washer isnt working. I press the start button, and the sensing button lights up for just a second and there is a couple of minutes of a grinding type of noise but then nothing.
SENSING Page 5
When the START/PAUSE/Unlock Lid is pressed, the washer will first perform a self-test on the lid lock mechanism. You will hear a click, the basket will make a slight turn, and the lid will unlock briefly before locking again. Once the lid has locked the second time, the washer will use short, slow spins to estimate the load size. These sensing spins may take 2 to 3 minutes before water is added to the load and you may hear the hum of these spins. If the sensing light is on, then washer is working properly. You will hear the motor turn the basket in short pulses to thoroughly wet the load. The washer will then move the load briefly, pause to allow water to soak in to the load, and resume adding water. This process may repeat until the correct amount of water has been added for the load. You may also hear water flowing through the dispenser, adding detergent to the load.
NOTE: Avoid opening the lid during sensing. The sensing process will start over when the washer is restarted. The sensing light may also come on during the Soak and Wash portions of the cycle. This is normal.
If there's no water, then Page 13
Washer won't run or fill, washer stops working, or wash light remains on (indicating that the washer was unable to fill appropriately)
Check for proper water supply.
Both hoses must be attached and have water flowing to
inlet valve.
Both hot and cold water faucets must be turned on.
Check that inlet valve screens have not become clogged.
Check for any kinks in inlet hoses, which can restrict water flow.
Or you have an inlet valve that is not working
Apr 29, 2016 | Kenmore Washing Machines
We pulled our stacked washer out from the wall to service the cold water hose filter on the back of the unit. when we pushed it back into it's location the washer won't start, won't fill...
I know you don't want to hear this, but either you did something to the hose filter or you didn't get it plugged back in correctly.
If you banged the water inlet valve in moving it back, it might be damaged.
Suggest you unplug everything and start over.
Sep 04, 2011 | Frigidaire FEX831F Top Load Stacked Washer...
I have an Electrolux EWD1477. I have been away for four months and I'm having problems with it. I set to do the quickwash30 program and press start, you hear the clicks, it might put some water in then...
My EWD1477 was doing this a year ago and I fixed it. Then it started doing it again a month ago and I seem to have cleared it again.
Firstly, remove the drain hose from where it is inserted into a laundry sink hole to make sure it is not blocked or sealed in with sludge.
Secondly, make sure the machine is empty of water and clothes and then turn the machine to off with the Program Selector Dial. Then turn off the power at the socket and remove the power plug and leave for five minutes.
Step 1: put the plug back in and turn the power back on.
Step 2: turn the selector switch to the right (Whites/Intensive). The green light of the Start/Pause button should be flashing and the green lights on for Prewash/wash, Rinses and Spinning. Don't press any other buttons or change any other settings.
Step 3: press the Start/Pause button and wait for the machine to empty any excess water. Press it again immediately after you hear water flowing into the machine OR two audible clicks. The machine is now in pause mode with the green light of the Start/Pause button flashing. Only the green light on the Prewash/Wash button should be on. Leave it in pause mode for 30 minutes and then press the Start/Pause button to recommence the cycle.
Step 4: If the Start/Pause button begins flashing, water stops flowing into the machine and the three green lights mentioned above are back on, turn the Program Selector Dial back to off, wait 10 seconds, and repeat the process above.
Step 5: If when you then turn the Program Selector Dial to Whites/Intensive and hear the two audible clicks, immediately press the Start/Pause button to set the machine in pause mode. Wait 30 minutes. Then press the Start/Pause button to recommence the cycle.
Hopefully the cycle will run without a problem.
Mar 26, 2011 | Electrolux Washing Machines
Press the start button,you hear a click,water runs for a second or so, water stops,that's it. Nothing else happens. Any suggestions. Thank you,S.Nielson
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Feb 19, 2011 | Frigidaire Washing Machines
Coffee not brewing after grinding
After grinding did you hear the brew group goes up and pump start? If you hear the pump start and stopped, itis blockage in the brewunit metal screen. Just needs cleaning.
If you don't hear the pump starting, the problem is with the faulty micro switch inside the gearbox , that is behind the plate of brewunit.(service center job)
Apr 14, 2010 | Saeco Odea Giro Plus Coffee Maker
I just moved into a flat with the WMA641 w Beko Washing Machine. I loaded it and turned it on : settings : Delicates 30 degrees. Pushed the on button and nothing happens. after few seconds the on light...
turn the machine off at the wall , leave off for 30 secs , switch back on
and push the start button
give the door an extra shove as this may not be fully closed
the on/off button will be a push in type , the start button is usually much smaller
Oct 23, 2009 | Washing Machines
DRAIN PROBLEM
Here's some things to check: The electric water pump on those machines can be stopped by objects that get under the machine- The pump has a "fan" on it, and I have seen numerous times where a sheet of fabric softener like "BOUNCE" will get sucked into the pump's fan and "strangle" it.
Follow these instructions: Starting with the machine OFF, take one finger and depress the water temperature adjustment button for DECREASE (arrow points DOWN) and hold it down, and while holding it down, turn the machine on by pressing the power button.
If you did it right, you should hear two quick BEEPS. Now release the buttons. This sets the machine in "technician mode"
Now press the REGULAR button (the cycle selector button for a REGULAR wash cycle)
You should hear the water pump start and the water should be going out the drain hose. If you hear a slight "HUM" then the water pump is jammed with either an object inside the tub or the aforementioned sheet of bounce or whatever. If you hear the pump start but the water seems to be recirculating back into the tub, then something is either caught in the machine's DIVERTER VALVE or the valve is physically broken. In rare instances, the machine control has a short and is powering up the diverter valve all the time rather than only when it is supposed to...
If this helps, please rate my answer!
Nov 25, 2008 | Fisher Paykel EcoSmart GWL15
Wash starts it fills with water then stops and wont wash
problem may just be that drum is not turning so you think program is stopped. try cancelling and select spin program and see if you get spin
Apr 01, 2007 | Hotpoint WMA44 Front Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
1,233 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
