Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
3 pt. hitch hydrolics have hard time lifting. used and auger and couldn't lift it out of the ground.
  • 66 Answers
Check the fluid level and any filters in the line
Posted on May 30, 2010
My 3 pt hitch goes down very slowly if at all. The fluid level is correct. Please help. It lifts without any problems.
Is there enough weight on it to pull it down Also there is a drop valve that can be set to increase the drop speed
Nov 24, 2015 | Cars & Trucks
PTo will spin post hole digger but three point
If the ground is extremely hard. more weight may be required. A small amount of vegetation on the cutting surface of the auger will stop it from digging.
Oct 05, 2014 | Garden
2007 Yukon Denali XL lift glass is opening when I use the fob to open the rear hatch. This causes me to be unable to then close the rear hatch via the fob
This sounds like you have a grounding problem with your hatch circuits. This type of malfunction usually occurs when two systems (the hatch lift and the Lift glass release) are supposed to be sharing the same ground, but one of the systems has a bad connector or a broken wire. It then "activates" the other system by grounding THROUGH the system that it is supposed to be sharing ground with.
What I would do in your case is to take a HARD look at the wires that are in the conduit that runs between the lift gate and the body. These wires flex every time the lift gate is opened and closed, and are prone to breakage.
The way you describe it, it sounds like the lift gate motor is losing contact at about 1/3 to 1/2 of the way up, and that is when it grabs ground through the glass release solenoid.
Jun 13, 2012 | 2007 GMC Yukon XL Denali
Where do you put hydrolic fluid on a fifty's fordson dexta tractor
what hydraulic fluid are you trying to add gearbox of the lifting gear ?? if the lifting gear i think its under the engine cover but its been 40 yrs since i done one
Nov 23, 2011 | Cars & Trucks
I want to replace the hydrolic trunk lifts but don't know what their called or where to get them. There is one on each side of the trunk lid that help lift to open and compress to close the trunk. My trunk...
This part is call Trunk support lift, Napa has these, part # 8194178, to remove at each end there's a mental clip that fit around the end, remove clip out and support will pop out of mounting support pin, be car full trunk is very heavy, used a stick to hold trunk up.
Jan 19, 2010 | 2001 Cadillac Catera
When in reverse and uphill the hydraulic lift(three pnt hitch) will not operate, but will on level ground
See if there is enough hydraulic oil in the system,check the level,this is probably cause there is not enough oil.
Dec 02, 2009 | The Times Case Corporation Tractors...
Hydrolic lift. Fluid is leaking from breather
Hydraulic lift seal needs to be replaced so that the fluid
will not be pushed out. Okey, God bless you.
Oct 12, 2009 | Plumbing
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
109 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
