Question about Frigidaire GLTF2940ES Front Load Washer
What does E70 means? My washing machine have this after it started for a few seconds.
  • cher_salamat May 29, 2010
    E70 is showing when the machine reaches the final rinsing while the water is draining out.what could be the problem? Thanks
    President:
  • 1,382 Answers
hi,
The main cause for this e70 error is that the hoses would have swapped (hot to cold, cold to hot). It means the washer isn't getting cold water.Try to switch between the hoses. Another possibility is the faucets are not turned on.
Hope this solution will fix your problem for sure.
Thank You !!
Posted on May 29, 2010
What is meaning of this error E70
e70 error eh? i would need some more info about your washing machine to further get some info to find about the error code of your washing machine
Jan 08, 2017 | Washing Machines
AEG Lavamat 60810 keeps stopping and displaying error E50 and some time E70. What is the problem and how do I fix it?
Family error code E50 means a problem with the washing motor. Family error code E70 means a problem with the NTC sensor. In my experience, E50 is most common fault in worn carbon brushes. But in any case family error code E50 is shown to the customer. In service mode could be: E51,52,53 and 54. The same applies to family E70 error code that will be displayed in service mode as error code E71 or E74.
E50 error code could be: motor winding, power board, tachymetric generator, motor relay on power board, wiring between motor and power board and wiring between tachymetric generator and electronic.
E70 error code could be: faulty NTC sensor, wrong position of NTC sensor or to much limescale on it and finaly wiring between NTC and electronic.
Dado
May 05, 2015 | AEG Washing Machines
AEG Lavamat 60810 E50 7Beeps Does seem to still work but display shows E50 and some time E70 and 7beeps over and over. Many thanks
E50 does mean problem with motor or tachometer placed on the motor. Could be: worn carbon brushes, motor faulty, wiring, electronic faulty.
E70 does mean problem with heating phase.
Could be: NTC sensor faulty or badly positioned, wiring faulty, electronic faulty.
Dado
Frigidaire washer LTF7000ESO error code E70
Good Morning Jazy, this is JK. I see that you are receiving an error message E70. The E70 error means that the Main Control Board is not seeing the correct water supply. I would suggest swapping the hot and cold hoses. Hope this helps!
Mar 24, 2014 | Frigidaire Washing Machines
Error code E70 What is it?
E70 Stuck key Continuous key read for 60 seconds. Power down (unplug) machine, wait 30 seconds and retry. Use t04 test to test keys. Separate control and control housing from front panel - clean and remove foreign debris. Ensure all keys can be operated freely without sticking. Replace control panel if actions do not resolve. Maybe this will help
Oct 27, 2013 | GE Adora Front Load Washing Machine Washer...
What dose E70 mean
Means if it is Kenmore that the cold water is not entering the machine. Try removing the washer hoses from the shut off valves after shutting them off of course. and check the little metal screens on the back of each hose connection check for dirt inside Hot and cold.
Apr 05, 2012 | Frigidaire ATF6000ES Front Load Washer
It is stopping in the cycle and reading E70 on the screen.
Thank You !!
Jul 16, 2010 | Frigidaire GLTF2940ES Front Load Washer
KEEP GETTING E70 MESSAGE
Are you sure its a E70? If so, the hot and cold lines are reversed.
Apr 25, 2010 | Frigidaire GLTF2940ES Front Load Washer
E70 error
May 15, 2009
I had this exact same problem with my Frigidaire washer (E70) as bubbles100. I called an appliance repairman on 5/14/09 and paid him $60 to tell me my hot and cold water hoses were reversed/not properly installed.
This repairman was the cheapest priced $60 and he would work till he found the problem. I had one appliance repair company wanting to charge me $90 for 30 min and another wanting to charge $120 for 30 min. Hopefully this information can help save the next person some money by trying this first.
Feb 16, 2008 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire GLTF2940ES Front Load Washer Logo
594 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
