Question about Transcend (589307) Media
Write protection on 8 gb pen drive
How to remove of write protection from 8 gb pen drive
    Scholar:
  • 75 Answers
1. Open Start Menu >> Run, type regedit and press Enter, this will open the registry editor.
2. Navigate to the following path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
Note: If the registry key StorageDevicePolicies key does not exist, you will need to create it
Download this batch file called add.bat from here, and double click after download the key will be automatically added to registry.
3. Double click the key WriteProtect in the right pane and set the value to 0 in the Value Data Box and press OK button
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); 4. Exit Registry, restart your computer and then again re-connect your USB pen drive on your computer. That is it, done.
In case you still find an issue, please leave a comment below.
Updated on 28th May 2009
After a lot of user comments telling that the above method does not work for them, we tell you another method which you can follow to solve the “Pen Drive is Write Protected” problem.
If the above method does not work for you, follow the below steps:
1. Copy all the important data from this drive to your computer because this method will format the drive and erase all the data on the pen drive.
2. Now download the Apacer Formatting Utility, Unzip this utility to a folder on your hard disk, preferably on a folder on desktop screen for easy access (Do Not Try To Save it on pen drive). Keep your pen drive plugged in, and double click on the Start.bat file in the folder where you unzipped the above utility. This will start formatting your pen drive, wait till the formatting completes and the LED on your pen drive stops blinking. Remove your pen drive after than and plug it in again.
The above two steps will solve the problem. If you still face the problem, follow the below steps:
1. Goto Start > Run, type cmd and press enter, this will open command prompt.
2. Type the following command on the command prompt replacing X with the drive letter of your pen drive.
CHKDSK X: /F
The above two methods will help you fix the problem.
Note: For all those who are out of luck in fixing the problem with their portable drives, I would suggest you to get your drives checked or replaced by the manufacturer to fix it for you
Posted on May 29, 2010
    Brigadier General:
  • 10,406 Answers
There is a small "slider" switch.
Slide it to the "unlocked" position.
MY 8GB SANDISK CRUZER BLADE PENDRIVE NOW SHOWS WRITE PROTECTED...PLEASE HELP IF U CAN........
My 8 Gb pen drive now right protected how can i remove the write protection pls.....................Pls..............say the solution
Sep 13, 2011 | SanDisk Sansa e270 MP3 Player
Hello ,i have problem with my 4 GB kingston pen drive. whenever i try to copy or delete something it gives me an error that 'The disk is write protected.remove the write protection or use another...
If you have just been taking the pen drive out without going through the "safely remove hardware" option then you have probably corrupted it. you could try the below technique, however, my feeling is that you will have to replace it and try to be more careful how you remove the pen in future.
http://techsalsa.com/solution-to-remove-write-protection-from-usb-pen-drive/
Jan 30, 2011 | Fuji (MAP3367NP) 36.7 GB Hard Drive
How to remove write protect frm pen drive
You should be able to use partitioning software on the drive Just as you would on a failed HDD.
Do a Google search for Free Partitioning software, there are many avail out there.
Once your drive is repartitioned, You should be OK.
Jun 08, 2010 | Transcend 160Gb StoreJet 25 Unveils Rugged...
I have kingston pen drive 32 gb which is write protected .what i
The write protected message appears due to many reasons detailed steps to fix the issue can be found from the following link
http://www.troublefixers.com/remove-write-protection-on-usb-pen-drive-or-memory-card-or-ipod/
May 28, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I have 8 gb trancend pen drive and it is showing
This can be simply removed by changing the position of the write protect lock on the pen drive body. Please refer the figure.
Please come back and rate my solution if turns to be helpful for you or also if you need more clarification. Thnx :)
Apr 07, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I'm using 8 gb USB pen drive. i was unable to remove write protect. i'm looking forward.
This act is due to the anti virus software in your system.it may have detected viruses.First format your pen drive and try it.
Feb 25, 2010 | iLO (2 GB) MP3 Player
4 gb pen drive give write protected error
Save the contents in the pen drive (this process will delete all the files in ur pen drive) and then download this http://www.apacer.com/en/support/downloads/Repair_v2.9.1.8A.zip,unzip it n run.....click "Format". Make sure u have connected only the pen drive u wanna recover to computer,this tool is very blind n it doesnt allow u to choose which removable drive to format..it formats the first removable disk (seems so). Gud luckmoz-screenshot.png
Feb 23, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Transcend 8 GB Pendrive showing write protected
Think this write protection error is due to some virus.
Steps to remove write protection for Transcend users
1) Go to download center of the transcend,here is the link
http://www.transcendusa.com/Support/DLCenter
Type the model no. or part of model number you are looking for.
example: JFV30(all alphabets in Caps )
2) Choose other details like product type etc. and search for your product
3)Then select the product which which is most similar to yours from search results
4)Then download the mFormat utility. You will asked for serial no. if you dont have..enter this no. 1456784523
5) Connect your pen drive
6) run the mformat utility and select full format after full format your write protection will be removed. try twice or thrice if you can't correct at first time.
Thats all...
It worked for me and my friends....
Other pen drive users may visit there vendors site and download any fromat utility present there for your model.
Nov 07, 2008 | Transcend (589307) Media
Removing write protection of USB pen drive
if u format ur pen drive. then use this step
Check out the registry under:
1)click on start button
2)clik on run dialog box
3)type regedit
4) HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies.
The value 'WriteProtect' should be absent or set to '0' and when you try to format it you have to format it as FAT16
Good Luck!!
Palwinder
Oct 31, 2008 | iLO (2 GB) MP3 Player
Transcend (589307) Media Logo
411 people viewed this question
Top Transcend Electronics - Others Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Transcend Electronics - Other Expert? Answer questions, earn points and help others
