Question about Gateway FPD2275W LCD Monitor
How do I close monitor menu for desktop computer
  • 4 Answers
Every monitor has an exit buton on a panel that is generally provided at the bottom or side of screen panel.
Posted on May 29, 2010
Shivering screen
Shaking or trembling of a computer screen is often caused by interference from another device that is within a couple feet.
It can also be caused by another monitor close by.
If the removal of these objects does not stop the trembling, the monitor may have built up magnetism and need to be degaussed.
Find the menu button for your monitor.
This is usually on the front of the monitor.
It is sometimes on the side of the monitor.
Push the menu button. Scroll down until you find the screen option.
Select "Screen."
Scroll down to the degauss option.
Select "Degauss."
Select "OK."
The screen will make a tuning sound, as if you hit a guitar string.
The screen will shake and vibrate.
The shaking should now be gone.
If it is not, it will need to be looked at by a professional.
May 04, 2013 | HP Computers & Internet
My aoc 716vmy monitor have blurred or doubled view. how can i fix it?
a couple things to check. speakers close the monitor. (caused by magnets) run a degauss from the monitor menu, also check the monitor connections back of monitor and back of computer for "tight" fit
That covers external issues. In the computer, in windows XP its typically right click on the desktop , go to properties. adjust your Screen resolution to fit the monitor, see if different resolutions have the same double effect. also go into advanced look for "Monitor Refresh Rate", try increasing the "Refresh rate" from say 60Hz to 75 Hz. this is very common cause of poor screen quality. Hope that helps. Cheers
Aug 25, 2010 | AOC Computers & Internet
A menu keeps flashing on my monitor so fast I can not read it and it will not stop. Black box with grey edge. Compaq 5017M monitor
mrsrobins849, if monitor manufacturing date (on rear of unit) is anywhere close to 2003-2004 then trade unit for new wide screen only if problem of flashing "menu" goes away when you connect a borrowed substitute monitor to your pc. Will your monitor "act" same when connected to "known-good" "fully-booted" pc that will display the WIN-desktop?? Most problems with "cold-cathode-fluorescent-lamp" "back-lit" lcd monitors can be attributed to their internal or external "switch-mode-power-supply" DC voltages degrading over time with use.
12fixlouie
May 28, 2010 | Compaq FP 5017 15" Flat Panel LCD Monitor
The monitor menu appear suddenly in the display and I can´t erase it.
usually this is caused by having your keyboard too close to the monitor and the keyboard bumps the menu button..
look at the buttons on your monitor itself. One of them should say "menu" pressing that one again should close the onscreen menu. if that doesn't work look for another button marked "exit" or an "exit OR close menu" selection within the menu itself. Use the menu button to get in the menu, use the left , right, up or down to navigate through the menu and usually the "menu OR select" button to make chnages.
Apr 22, 2010 | HP L1706 17" LCD Monitor
When booting up my windows is loading and then my screen goes black and come up with an error: recomended resolution is 1280x1024... how do I fix this?
Most probably your computer has a higher resolution or refresh frequencies set in Desktop Settings than supported by the monitor. It might be also, that you have previously installed a monitor driver for a different monitor model, and the computer is using resolutions and frequencies supported by that previous monitor, with which your new one can't cope.
The solution would be to boot the computer in safe mode (hit F8 key when the computer is starting, you can hit it a couple of times, until you see a menu; choose "Safe Mode" and hit Enter).
Go to Desktop Properties, change to Settings tab, and click "Advanced" button. In the new window choose "Monitor" tab and change the monitor to "Plug and Play monitor". Click OK to accept the settings and close both windows.
Now reboot the computer - it should start with a rather low resolution, but the picture should be visible. Now you have to go to your Desktop Settings again, Advanced tab, and move the resolution slider to position 1280x1024. Accept and enjoy.
If the computer still doesn't boot, go to safe mode again, go to Control Panel, System, Hardware, Device Manager, drill down to Monitors, and delete all the monitor devices installed. After a reboot, system should start up and find new hardware, and install Plug and Play monitor. Set the optimum resolution of 1280x1024 as written before.
Nov 18, 2009 | Samsung SyncMaster 710VT TFT LCD Monitor
Computers has power but will not turn on monitor,fans on blue light on, yellow light constant. cd slide opens and closes normal.
First the obvious, monitor is on? Cables are connected securely to back of monitor and PC? Power cable/power adapter are all connected and plugged in? If a power adapter is used, it will feel warm.
I am assuming it was working on some point and then stopped.
If you are getting power to monitor and it's power light is on, then I'd suggest a problem with the video output on PC
If you are not getting power to monitor or it's light is not on, the problem is with the monitor.It may have gone out on you. Try attaching to another computer.
Oct 05, 2009 | E-Machines T6528 PC Desktop
Bottom half of monitor displays top half of desktop
You could try a different resolution for the monitor.It's possible the monitor cant support the resolution your trying to display your desktop at.
Jun 01, 2009 | ViewSonic GS773 (White) 17" CRT Monitor
Need to change vidio mode to display input to 1024-768 @60hz to use my new monitor dell 2400 diminsion and acer monitor please help me''
go to control panel. look for personalize or display menu. select display settings and change your resolution and apply. then go to advance settings and see if set to 60 hz
Apr 24, 2009 | Dell Dimension 2400 PC Desktop
Brightness contrast screen appears
is this from your computer or monitor? if from your monitor settings, you are hitting the monitor menu button with your keyboard as you type. If from the computers' display settings, change the desktop resolution once or twice , hit apply and ok. this should break the opening cycle.
Regards.
Nov 04, 2008 | Computers & Internet
Emachine T3414 monitor
Turn off the computer and monitor. Disconnect the monitor. Turn on the monitor. You should get some indication the monitor is on, if not it is probably dead.
If the monitor seems to be on, try to enter the menu by using the buttons or knobs on the monitor. If the menu comes up, the monitor is probably good and you have a computer problem.
If you think the monitor is bad, hook it up to an operational computer. If it works, you definitely have a computer problem; if not the the monitor is definitely dead.
Either way try to have the problem resolved under the warranty.
Nov 01, 2008 | E-Machines eMachines Desktop PC
Gateway FPD2275W LCD Monitor Logo
41 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
