Question about Microsoft Office Professional 2007 Full Version for PC
What is the last column name of excel
Ms-excel
  • Microsoft Master
  • 4,737 Answers
I think there's no specific name for that column, but we can say it's A1048576.
Posted on May 29, 2010
Columns in excel using only certain data ex city names fill in if I've already typed the name once and other columns I have to type the same thing over and over. how do i make excel recognize this.
go google and type in---user manual for excel program---
basically you type a heading at the top of a column
then select that column ( black arrow over top of column)then control C
move the black arrow over the next column that you want the same heading to appear and press control V and so on
ant information in the first column will be copied to other columns
it is all explained in the manual or in a excel for dummies book
Oct 24, 2016 | The Computers & Internet
Unhide column a in MS Excel 2007
The solution is slightly different depending on the version of Excel. For Excel 2007 here are details:
http://www.techonthenet.com/excel/columns/unhide_cola2007.php
Oct 10, 2014 | Microsoft Office Excel 2007
Hyperlink other document in excel button
The easy way (but labor intensive) is to put the file names in a column (can be any name you want or the pdf file name), right click on a cell, hit insert hyperlink, and in the address field at bottom, put in the file pdf file name. You would have to do this for each of your 100 files.
If you want to automate it, create a column with the directory path name, a 2nd column with the full file names, a 3rd column where you concatenate the two previous columns to create the full path, and then use the hyperlink command to provide the link:
Folder name Filename Concatenated LINK ../excel/ file1.pdf ../excel/file1.pdf file1.pdf ../excel/ file2.pdf ../excel/file2.pdf file2.pdf ../excel/ file3.pdf ../excel/file3.pdf file3.pdf
Here are the formulas behind this:
A B C D Folder name Filename Concatenated LINK ../excel/ file1.pdf =CONCATENATE(A2,B2) =HYPERLINK((C2),B2)
../excel/ file2.pdf =CONCATENATE(A3,B3) =HYPERLINK((C3),B3)
../excel/ file3.pdf =CONCATENATE(A4,B4) =HYPERLINK((C4),B4)
This should work like a charm and the other advantage is that excel won't rename your path locally depending on weather a file is open or not).
Feb 21, 2014 | Microsoft Excel for PC
Sorting a single column with both first name and last name
are you using mssql then it must be something like this
Select firstname + ' ' + 'lastname' as 'name' from tablename order by lastname
Sep 26, 2009 | Computers & Internet
Dear Sir, In case there are atleast 80 files or more having same format containing datas in columns in each file with different figures, I want to merge all file in a single sheet in one shot. Kindly...
If the column names and orders are same across files, then you can directly use the MS Excel's import data function, this will do your job.
Alternatively, if you want to do it manually, import each file in separate excel worksheet using data import wizard or simple copy paste of data (in latter case you have to use Text-to-Col feature of excel), and then manually append all figures (copy-paste in one go) to any external excel sheet.
Then finally, export/save as that external sheet to any filename of your choice.
Hope this helps.
Thanks.
Mar 24, 2009 | Microsoft Excel for PC
Input data
If you want to transfer your data into SAS, SPSS, or some other program, follow these guidelines:
The cells in Row 1 should contain the column's eventual data set name. Each name should be a relatively short and unique acronym that clearly identifies the data. It should begin with a letter and contain only letters, numbers, or an underscore ( _ ) where spaces would naturally fall. Avoid using special characters such as $, &, @, in variable names. Since each row represents the values from one subject, the first column(s) should contain one or more variables that give each subject a unique identifier. They become especially important if you need to merge two or more data files.
In Excel, data formats are defined for a range of cells rather than for a complete column. For this reason it is important that each entire column, including cells with missing or uncollected data, have one, and only one, format. Actually, you do not need to format the entire column, only the portion you will eventually use. Highlight that portion and select the appropriate format from the Format/Cells option. Do not select formats that will enter commas, dollar signs, or other visual enhancements. Numeric, text, and date formats (e.g. mm/dd/yy is often a good choice) are probably the only formats you'll ever need.
The "Split" option (under the "Window" pull-down menu) keeps the row of variable names and the columns of identifiers in view, whatever range of cells in the worksheet you may need to review. First place the cursor at the most extreme upper left-hand corner where data entry begins (e.g., the intersection of Row 2 and the column in the upper left-hand corner where data appear) and then select "Split" from this menu. For any row or column of the worksheet you move to, you'll know exactly which variables you are observing (column names) and their associated ID values (rows).
For versions of Excel later than 4.0, one file can contain multiple worksheets. By default, the tabs at the bottom of these sheets are supplied names ("sheet1," "sheet2," etc.). You can change these names by clicking this space with your mouse and entering a new name. Use the same conventions for first-row variable names: use a short acronym of the page contents that begins with a letter, use only letters or numbers, and enter the underscore ( _ ) where a space naturally falls.
Jan 05, 2009 | Sage Instant Accounts 8.0 (013604ug)
EXCEL VLOOK Function
Just noticed a small syntax problem, try this:
VLOOKUP(S9,$S$14:$T$18,2,0)
I always add the last parameter of "0" to insure that that an exact match is found.
Jul 27, 2008 | Computers & Internet
Using NOW() in excel formula
That sounds like Excel. You may have to get someone locally to fix that problem.
Jun 10, 2008 | Microsoft Windows XP Professional
Sorting within a column
This page covers how to manipulate columns when the data is formatted as "LastName, FirstName MiddleName"... I'm guessing you could just tweak it:
http://www.cpearson.com/excel/FirstLast.htm
This google group goes more in depth on the topic:
http://groups.google.com/group/microsoft.public.excel.misc/browse_frm/thread/49bf87ffdc31a9d3/954544ded2b2f620#954544ded2b2f620
Jan 04, 2008 | Computers & Internet
Microsoft Office Professional 2007 Full Version for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
