Question about Kensington SlimBlade Wireless Keyboard and Laser Mouse - Graphite
Just purchased a kenginston slimline track ball mouse. Installed last night worked ok however the track ball did not work like my Orbit Optical trackball mouse does. Started the computer today and the mouse does not work at all
SOURCE: GE wireless optical mini mouse
i also have a mouse pad with a wrist rest, and i had it before i purchased my mouse, so i know it does not correct the problem
Posted on Jan 04, 2008
SOURCE: Stiff trackball rotation
I forgot to mention one other possibility. It's a bit messy, but it sometimes helps...at least in the short term. A friend of mine found that if you eat some fried (basically 'greasy') chicken with your hands and them rub the grease on the ball it works better for awhile. Unfortunately it also tends to gather more dirt into the sunken areas around the metal nubs quicker and the ball movement becomes sticky again rather soon.
Posted on May 07, 2008
cpenzes
  • 1102 Answers
SOURCE: Logitech Cordless TrackMan Optical Trackball connection
you are probably better off buying a new one
unless you are lucky enough to find a used one
Posted on Jan 15, 2009
  • 43 Answers
SOURCE: mouse will only move left and right not up and down
Your mouse is not detected when boot occur.
It could be that your mouse wire lacks of continuity.
It also could be that the driver is corrupted.
Things to do:
Do continuity testing for your mouse wire.
Reinstall driver of your mouse.
Restart the Computer
Posted on Mar 18, 2009
  • 220 Answers
SOURCE: microsoft optical mouse repair
if you know electronics,it won't be a problem.need to find which component is faulty.
Posted on Jun 24, 2009
I can't control where the mouse goes unless I keep working with it. It's all over the place: kensington orbit mouse 64221. I have taken the ball out and tried to clean it.
It's not the ball that's dirty...
Take the ball out and look in the hole. You will see two rollers that control the cursor movement. The ball spins the rollers. These rollers probably have a bunch of gunk/**** on them. Remove the gunk buildup from the rollers and the mouse will work fine (fingernail is a good tool for this). Turn the rollers with your finger to make sure all the gunk is gone. If not, replace it with an optical mouse (no ball).
Hope this helps!
Regards,
Joe
Jan 02, 2011 | Computers & Internet
My mouse does not work ?
If you are working with track ball mouse than you have to service it properly
  • First remove the back cover by twisting it and take the ball out and clean it you have to clean the mouse inside also
If you are using optical mouse than check that you are working with a mouse pad it is necessary with optical mouse
If yet not working check the connecter of the mouse with green color fix it properly
At last if it does not work it means that its optical sensor has gone so u have to buy a new one
thanks
May 25, 2010 | Computers & Internet
My mouse pad is erraatic and jumpy, wont go where ...
If you are using a track ball mouse then service it properly and also remove the ball and clean it
If you are using a optical mouse than change the pad or keep any book under it if again your mouse doesn't work buy a new one
May 21, 2010 | Computers & Internet
Optical track ball is sticking. How clean it and what to avoid?
An "optical" mouse has *NO* track-ball.
If you do have a mouse with a track-ball, then rotate the "ring" that holds the track-ball inside the mouse, to "unlock" the ring. Remove the ring. Look inside the mouse. You'll see two rollers.
Look for accumulated "gunk" in a ring at the center of each roller. Gently scrape each roller, to clean it. Re-insert the mouse. Re-insert the ring. Rotate it, to "lock" the ring into place.
May 19, 2010 | Logitech 931249-0403 Mouse
Mouse cursor shown on desktop but it's not moving.
Remove the four screws from the bottom casing of the track ball. Carefully push the ball from the topside causing the case to come apart. Remove the ball and take an alcohol wipe and gently clean the area where the ball sits and the optical eye that the ball rest against...it looks like a little window that is on the side of the area in which the ball rest in. Put ball back in the recess and put case back together. Replace screws and you should be good to go!
Mar 05, 2010 | Computers & Internet
Pointer jumps
That's not a lot of information there...
How far does it jump? How often? Since when? Is this a new mouse, an old one, an optical or a ball mouse? Do you use a mouse pad? Have you installed any of that cursor mania stuff? Is it a USB mouse?
I'd recommend (If you have a ball mouse) to take out the ball by turning the circular plate under the mouse then blowing the dust out and wiping the ball clean. If it's an optical mouse i'd suggest a new mouse-pad designed especially for this optical mice. Also you might wanna try re-installing it. Or if it's a USB mouse trying it in a different slot and cleaning out that connection too.
Dec 24, 2009 | HP Wireless Optical Mouse
Ds-3200 wireless optical slimline deskset mouse works keyboard doesnt
Normal 0 Make sure the batteries are installed and are good.
Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Aug 02, 2008 | Trust Wireless 11676 Keyboard
Open Questions:
Kensington SlimBlade Wireless Keyboard and Laser Mouse - Graphite Logo
42 people viewed this question
Top Kensington Computers & Internet Experts
dctocali
Level 1 Expert
Pierre Legault
Are you a Kensington Computer and Internet Expert? Answer questions, earn points and help others
