Question about Seagate Barracuda 7200.10 500 GB SATA Hard Drive
Installing Win XP to my new seagate HDD but cant complete kept on going to install process and cant boot unless boot to CD thats why it keeps on going back to installation process, what is the problem why cant I reinstall my OS?
  • 3,600 Answers
Have you tried replacing the ribbon cable? Did you remove the jumpers off the back? if no to these to then Get a windows boot disk and Fdisk the drive and reformat then install the system. When you do the proceedure above say good by to any files they will be gone. You could have a boot virus that is causing your problem. hope this helps.
Posted on May 29, 2010
  • Bruce Hathcock May 29, 2010
    Forgot to mention s the new drive on a cable that is set for that drive? is it set as the master? if so thats your problem set it to CS cable select. You can have to drives on master one slave or two CS and it will auto configure itself, Thats the easiest.
Dell bootmgr is missing
Most likely cause is that the boot order in the BIOS is set up for the HDD first. When turning on the unit, press the key needed to enter setup. Once in setup, search thru the menus for the boot order. Choose the CD drive as the first boot device, then the hard drive as second. Save and exit the setup. When rebooting, ensure the WIN XP CD is in the drive. When the screen says, "press any key to boot from CD", press a key and the WIN XO CD should take over and start the install. Once WIN XP starts installing, follow directions. On each restart after that, DO NOT press the key to boot from CD. WIN XP setup will handle everything until the reinstall is complete. After you are done, you may choose to go back to setup and change the boot order back, but it is not really necessary. The only time you will get the "press and key to boot from CD" message is when there is a bootable CD/DVD installed in the drive. Otherwise, it overlooks it and goes to the next boot device (HDD).
Sep 07, 2014 | Dell Inspiron 2600 Notebook
My evo610c would not start and failed the HDD self test. I installed a new hard drive. It now passes the HDD self test, but will not go past the screen that says "not-system disk, replace and try again"....
Put the Windows CD disk into the CD-drive.
Turn the computer off.
Turn the computer on, and immediately look for a message like "press F12 to change boot order", or something like that. Tell the computer to first try to boot from the CD-drive. When it boots, the installation process will start.
Jun 23, 2010 | Compaq Evo N610C Notebook
Will not run xp pro i'm stuck in 2000 mode mother board is ak77 pro 133 vt8233 will not run xp pro i've been told im pretty much sol. Is this true?
If you have a valid Win XP Pro CD and want to install the operating system you'll need to format your hard disk drive. If you have allot of data on you're hard disk drive, (In Win 2000) Suggest you create a second partition within the free space of you're hdd and install windows XP Pro. Boot you're system with the XP CD. Pay close attention to the display screens. Follow the instructions for creating a second partition.
Format the new partition. (Quick). Install windows XP on the new partition. Once completed you can copy your personal data to win XP.
If you choose to keep the win 2000 partition and you do not wish to have a dual boot system than remove/delete the root files from the 2000 partition. These files; Autoexec.bat and Boot.ini. You're new XP Boot.ini should read like this;
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect /usepmtimer
Once you're satisfied an no longer need win 2000 use windows diskmgmt.msc from the run command to delete the win 2000 partition.
Win 2000 uses a FAT16 where Win XP uses the FAT NTFS.
Cheers!
Mike
Jan 07, 2010 | Acer AOpen AK77 Pro(A) (91.89A10.104)...
I just upgraded to a Elitegroup A780GM-A motherboard, AMD 64 X2 cpu, and 4GB RAM kit. I kept my 250GB Seagate HDD that has XP Pro on it with all my important data. The problem is all devices show ok after...
It is still trying to load the drivers for your old system board which apparently are not compatible with your new board. You need to boot from the XP CD and repair your existing Windows installation. It should redetect all components and install the proper drivers for the motherboard components.
May 30, 2009 | EliteGroup Computers & Internet
My hard disk was recognised by bios but it cant be accessed by the system. xp is giving a error msg. as it cant recognise the hard disk
dear Saratch...
you must trying re partition ur hdd with 3rd software like Ranish partition or partition magic, or you can try with fdisk from microsoft DOS with cd booting before you try to installed it with another system operation like win XP or win 2000
okey
cropp
Apr 07, 2009 | Seagate Barracuda 7200.7 40 GB Hard Drive
"cant install win-xp on CQ-60"
Hello.
Hope this helps...
These are the normal steps on desktop computers but
should work in your case too with a fresh installation
1. Enter bios settings and set CD Drive as first boot device
2. After reboot if you are asked if you want to start on cd chose yes.
3. start Win Xp installation from cd.
4. delete partiton on C; drive
5. create new partition
6. Start installation and format the c:drive
7. Follow the installation instructions,,,
Feb 10, 2009 | Compaq Presario CQ60-220US PC Laptop
Problems Installing my 160 GB Seagate SATA HDD
you need to go in bios and set sata to legacy for no F6 driver. if its on native it need a driver from floppy on xp cd boot . if its not detected in windowws as a slave. u need to run diskmgmt.msc and fin the unalocated drive and create part then format it ntfs
Nov 05, 2007 | Asrock K8Upgrade-VM800 Motherboard
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
Open Questions:
bricked hard drive? Would folling this lead to a full hard drive format or just unbricking a drive like people sat it does?? Also any other ways that might help would be great to know, heres what i'm talking about! "Fixing The Drive NOTE: Commands for you to type are in red boldface. Pay attention to upper & lower case - it is important. Turn on power to the RS232-to-TTL adapter and the hard drive. After a few seconds, Press CTRL+z. You should then see a prompt like this: F3 T> If not, swap TX & RX wires. Access Level 2 (type /2): F3 T>/2 (enter) F3 2> Then spin down the (disconnected) motor: F3 2>Z (enter) Spin Down Complete Elapsed Time 0.147 msecs F3 2> Very carefully, remove the cardstock that you placed between the PCB and the drive head contacts. Carefully replace and tighten the 3 loose screws. I suggest using a small piece of masking tape to help you hold the screws while you put them back in place. Then start the motor: F3 2>U (enter) Spin Up Complete Elapsed Time 7.093 secs F3 2> Next go to Level 1 (type /1): F3 2>/1 (enter) And do a S.M.A.R.T. erase (create S.M.A.R.T. sector): F3 1>N1 (enter) Cycle power to the drive, then do partition regeneration: F3 T>m0,2,2,0,0,0,0,22 (enter) After 15-30 seconds, you should see something like: Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 14, Max Certify Rewrite Retries = 00C8 User Partition Format 10% complete, Zone 00, Pass 00, LBA 00004339, ErrCode 00000080, Elapsed Time 0 mins 05 secs User Partition Format Successful - Elapsed Time 0 mins 05 secs Do not turn off drive until you see this message. Once seen, drive can be turned off. Power down everything, place drive back into your computer, and confirm that it's working." Thanks.
Apr 12, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Seagate Barracuda 7200.10 500 GB SATA Hard Drive Logo
75 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
terminalcon
John Anderson
John Anderson
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
