Yes you indeed need to check all fuses. I would expect though that if it is.was going OFF after hitting a Bump, then it MUST be some sort of bad Connection. You should check ALL Joints, Power Speaker and any other NON-Soldered Joins, or places where wires terminate to the units. Use your meter and perform a Continuity test between the Amp and the Speakers/Xovers... Check to see if they are 100% OK. I would wonder if there isn't a Joint or some such thing in the "Run" of wiring. Either that or you may have a bad solder join. a "Dry" joint on your Output devices in your AMp itself? You need to check all those, and it never hurts to give them, the output pins on the main Output IC, or Transistors, a good going over with a nice hot soldering iron. Work on ONE channel at a time, and prove that one, then move on to the next..What I often do is get some wires and hook it all up, to the amp, and Xovers, and speakers, and make a new little installation, this will prove an faulty components, sorta do a working "Mock up" of it all to prove whats what.
Basically the wiring of the large harness corresponds to the pins like this.
Starting in the upper right hand corner and working down the right side from A12 down to A1.
1=Left rear output-red
2=Left rear output-blue
3=Right rear output-black
4=Right rear output-yellow
5=empty
6=Left front input-black
7=Left front input-yellow
8=Left rear input-orange
9=Left rear input-green
10=Amp 'ON'-blue&orange
11=empty
12=Amp sensor-black&orange
Back up to upper left hand corner on the large plug
13=Right front tweeter output-red
14=Right front tweeter output-blue
15=Left front tweet output-red
16=Left front tweeter output-blue
17=empty
18=Right front input-red
19=Right front input-white
20=Right rear input-blue
21=Right rear input-red
23=Right front sub (+) output-yellow
24=Right front sub (-) output-black
The small harness is the same above with the upper right position being pin 1 going down to pin 4 then back up to the top for pin 5 down to pin 8.
1=Memory Power-Lrg White
2=Amp Ground- Lrg Black
3=Left front sub (+)output-yellow
4=Left front sub (-) output-black
5=Left front mid (+) output-white
6=Left front mid (-) output-brown
7=Right front mid (-)output-brown
8=Right front mid (+) output-white
Hope this will help you.
Thank you
