Question about Fedders Heating & Cooling
Won't start. reading EE on front panel. - Fedders Heating & Cooling
    President:
  • 1,902 Answers
EE error code is your temp sensor. You will need to replace the temp sensor on your unit. You can go to your local appliance store with your temp sensor in hand and they can either order one or they have one in stock
Posted on May 29, 2010
Health O Meter digital scale, model HDR743DQ1-41, reads "EE". What should I do?
The more recent models don't have to be tapped before getting on,if its an older one, the message might mean you took too long or weigh more than the capacity,usually 300,or 330lbs for a digital scale although some go to 400lbs or more. Try switching the battery for a new alkaline or lithium one;digital scales often need more power than a common cell can provide.
Jun 28, 2013 | Health & Beauty
An "E" Readin
E is cuff not applied correctly
EE is cuff not inflated properly
E
E
over each other is too much inflation if inflated manually
See page 25 of the manual.
You both need to sit down and read the instruction manual :>)
instruction manual - Omron
https://omronhealthcare.com.au/pdf/SEM-1_Instruction_manual.pdfThe SEM-1 Automatic Blood Pressure Monitor is intended for home use. SAVE THESE ... If the battery fluid should get in your eyes, immediately rinse with plenty of .... These situations could lead to higher blood pressure reading due to strain or the arm cuff ... If an error symbol "E" or "EE" appears, measurement was not.
Nov 06, 2017 | Walgreens Blood Pressure And Pulse Monitor
We have ducted air which cuts out and shows on the control panel where the clock is says EE.EE
When EE:EE is displayed on remotecontrol , press "Energy Save" &"Zone Control" buttons simultaneouslyfor longer than 3 secs. The error code will then be displayed on the LCD.Then write again. Thanks.
Jan 31, 2011 | Fujitsu Heating & Cooling
It keep giving me a ee reading every time i try to use it
Hi. One of the most common error symbol that appears on this display panel is a EE with a down arrow and two numerals. The reason for the EE Error Indicator is usually caused because the cuff has been wrapped too loose. The cuff was under-inflated during the measurement. This error will also display if the cuff is worn and needs to be replaced. The EE symbol with a down arrow indicates the cuff is over-inflated. In most instances the cuff has been wrapped too tight or you are using the incorrect cuff size. Turn the monitor off. Read the instructions to correctly apply the cuff. Wait five to ten minutes then take another measurement. This should correct the issue.
Aug 19, 2010 | Omron Model HEM 432C Manual Inflation...
Getting a F EE reading
Having received no response in over a month, I assume this is no longer a problem.
Apr 27, 2010 | Nikon D80 Digital Camera with 18-135mm...
Air conditioner will not turn on I am receiving the letters EE on the front panel
Have a service Co. check the connections to relays and or transformer, it sounds like a low voltage problem ( EE is Electric Error) If these are new Units it maybe in the wiring ???.
Jul 14, 2009 | Fedders Heating & Cooling
When the pressure comes up on the monitor the top number was reading EE. It did it three times. I can't find the instructions. The machine is an Omron model: 741CREL. Thanks.
EE=Cuff under-inflated=not inflated enough. While cuff is inflated, keep pressing START button until pressure reaches 15-20 mmHg higher than the pressure when it stops and displays EE. Make sure at least 5 min allowed between readings.
Feb 21, 2009 | Omron Automatic Blood Pressure Monitor...
89 4.5 deville no start problem
I fixed this problem by reading the computer troble codes, the code .E.E 12 indicated no distributor signal. I found the ignition module to be bad. All this with out the "experts" help.
Nov 19, 2008 | 1989 Cadillac Sedan DeVille
Wont turn on. EE on display
It's probably the control board inside the control panel. I had the same problem and it moisture shorted out the board. You can order a new one from Sears Parts for about $45
Jun 09, 2008 | Maytag M6Y12F2A Air Conditioner
Heating & Cooling Logo
48 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
