I need to fix the agitator on my washing machine as i it not swirling the washing during the cycle
    President:
  • 1,554 Answers
The agitator dogs are worn and needs replacement if the motor runs and the bottom part of the agitator agitates but the top part of the agitator does not. The motor coupler or drive belt is broken if the washer fills and the motor runs but no agitation at all. The lid switch is faulty if the motor does not run at all. Please let us know which among the cases stated above the washer is in and indicate the make and exact model number for specific and accurate troubleshooting and repair advice and for the exact replacement part numbers.
Posted on May 29, 2010
  • mailing491 May 29, 2010
    the tub where the clothes are gets full of water, however it sounds like the motor wants to work but when i have now looked where the agitator is trying to spin but isnt and so the water and tub are stationary however when it comes to spining the clothes at the rinse stages this happens so i guess the middle part i will call it doesnt happen.
  • Jahn27
    Jahn27 May 29, 2010
    The issue is indeed with the agitator if the tub spins during the spin cycle. Please indicate the make and exact model number for specific and accurate troubleshooting
    numbers.
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
SPLINES STRIPPED
Replace this agitator coupling part number WH49X10042 make sure the inside of the agitator is not stripped.
Feb 05, 2014 | GE Profile WPSR3100W
Machine will not agitate during rinse cycle of normal wash.
The brake is part of the mechanism to function the spinning. The agitation is another mechanism to function in the other direction of the same motor. This mechanism is below of the other. The helix part needs to replace to fix this. This should be done when you change the brake. Of course this is a result from the brake change since you have take this apart before you can get in the spinning mechanism. It is good that now you don't have to touch the spinning mechanism, but only the agitation mechanism. It is not from the tight belt. Hope this can help.
Jan 09, 2010 | Dryers
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Installed new belts, machine will not agitate
Transmission is bad. The transmission is not used during a spin but it is used during agitation. Check your warranty, the transmission maybe covered for 10 years for parts only and 5 years for parts and labor
Jun 16, 2009 | Washing Machines
Washing machine is making a clicking/ticking sound when it is agitating during wash cycle
This is a sign of strained agitator components that are about to be damaged or stripped. I recommend pulling the agitator and clutch. inspect each device for stripped components and uneven ware. replace the agitator and clutch if found to be faulty.
Check the transmission(gear box) for damage as well. fill with oil if needed.
May 27, 2009 | Washing Machines
Washing machine not agitating during wash cycle. Only when rinse
This occurs when your transmission has failed & requires replacement.... Good luck!... Bill
Apr 28, 2009 | Maytag MAV4755 Top Load Washer
Agitator doesn't turn during wash / rinse cycle
top the top off the agitator,remove cap inside,you have 4 plastic dog ears you need to replace,your local appliance store has them for $2,let me know how you do-mike
Mar 24, 2009 | Kenmore Washing Machines
Drum spinning during wash cycle
if when in the wash cycle the tub spins then the brake in the cluch assembly is worn and to be replaced. this holds the tub from moving when in the wash cycle. thanks tallpaul
Apr 14, 2008 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
113 people viewed this question
Top Washing Machines Experts
