Question about Dynex 32 in. LCD Flat-Panel HDTV
I cannot program channels on my Dynex Model: DX-LCD32-09. What should the settings be for auto scan?
I JUST GOT A 26 NCH DYNEX FLATSCREEN AND AS I WAS WATCHING FOOTBALL IT JUMPED,SKIPPED CHANNEL'S OR WHAT NOT FROM 1014 TO 46.2 ON ITS OWN. WHAT IS WRONG?? OR WHY WOULD IT DO IT??
Posted on Dec 26, 2010
Please run channel auto scan
Auto channel scan is part of the initial set up procedure. Return to that procedure and repeat auto channel scan.
Jul 29, 2014 | Dynex DX-L19-10A LCD TV
Can't get rid of "Please Run Channel Auto Scan" stays on tv screen
for some reason it is not seeing you cable signal. you will need to make sure you have it set up for cable and not air. check your input options, like tv/av/hdmi/ ect hope this helps
Aug 05, 2012 | Dynex DX-LCD32-09 LCD TV
Finally bought anRCA antenna for my new Dynex TV.Nothing no signal,no way to scan for channels I can see.AGGH.Is it a lemon?
Which Dynex TV do you have? The manuals for most Dynex TVs are available from the product page. Start at http://www.dynexproducts.com/products/televisions.html . If you have an older Dynex that isn't on the main list, check under Discontinued Products. Alternatively search for your model. Then click on the Support tab to find the manual for that model.
For at least one Dynex TV (DX-32L152A11), the procedure to scan for channels is below.
To scan for channels, first make sure that the current input is set to TV. (Press the input button on the TV or the remote). Then press Menu and use the left/right arrows to select TV. Then press Enter or down arrow (the manual says the right arrow). Use the up/down arrows to select the entry to change. First, make sure that the Tuner Mode (first item) is set to Air (use the left/right arrows to change this). Press Menu to go back to the TV menu. Then go down to Channel Scan and press Enter. You may need to confirm the channel scan and press Enter again. Wait for the scan to be completed.
On a discontinued model (DX-32L151A11), the procedure is slightly different. With the input set to TV, press Menu. Select the Channel submenu and press Enter or down arrow. Set the TV mode to Antenna (use the left/right arrows to change the value). Then press the up/down arrows to reach AutoScan. Press Enter. Move cursor to highlight Yes and press Enter again. Wait for the scan to be completed.
I hope this helps.
(There were some Dynex monitors built. They usually do not have a coaxial antenna in port since they didn't have tuners.)
Jul 29, 2011 | Olevia LT32HVE 32 in. LCD Television
Cant get the tv back to channel 03 called dish network tehy couldnt help me said i had to contact u guys to tell me how to do this its a dynex 19in lcd tv
Have you tried programming the remote to the TV? We don't have codes for a Dynex however, this link will take you to what's called a power scan this should help.
http://www.dishnetwork.com/SupportSection/power-scan-instructions
Daniel Busa
DISH Network Customer Service
Dec 12, 2010 | Dynex DX-LCD19-09 19 in. LCD TV
Cannot view VHS/VCR on tv
It may be easier to use the 3 RCA cables for audio/ video. Using channel 3 would require you to do auto scan to get the channel 3 back in the list.
Jul 02, 2010 | Dynex DX-L19-10A LCD TV
No channels
I had the same problem and end up unplugging the power, replugginging and then had to reprogram all of the chanels using the auto program. I still ahve a yy> show uo in the middle of the right had side of the screen when changing channel -- do not know why this happens -- good luck
Dec 14, 2009 | Dynex DX-LCD37 TV
NO SIGNAL . CANNOT FIND ANY CHANNELS WHEN I
You need to use the setup menu to specify the tuning band (specify whether you have cable or an over the air antenna) before doing an auto channel scan.
Dec 01, 2009 | Dynex DX-LCD19-09 19 in. LCD TV
New tv. won't work
Press the input button and select where you have the satellite plugged in.
Aug 12, 2009 | Dynex DX-LCD19-09 19 in. LCD TV
I have a Dynex DX-LCD19-09
You can go to the Dynex customer support website at (http://www.dynexproducts.com/pc-694-23-dynex-19-720p-widescreen-flat-panel-lcd-hdtv.aspx)This is the support page for you model television. Just copy the address and paste it into the address bar of you web browser. The page has a pdf copy of the manual that you can copy. It also has access to the customer support technical service using the e-mail support. You can also call Dynex customer support at this telephone number 1-800-305-2204 between the hours of 7am - 12am CST. Give them the model number of your television and ask them for help with you set-up problems. I hope this information helps you with your problem.
Jan 19, 2009 | Dynex DX-LCD37 TV
Dynex (no database) since power outage
What you have to do it go to the TV Menu and go to channel. Then go to channel scan and do one of those. THe problem is that is just doesnt know where to look for channels, but a quick scan will fix that.
Oct 03, 2008 | Dynex 19 in. LCD Flat-Panel HDTV
Dynex 32 in. LCD Flat-Panel HDTV Logo
424 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
